Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 10, 2022 at 9:04 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Basik has some too, think hes been talking about it for a couple years. Putting of his racks in this weekend with his offset bushings so will see how that goes/how that feels, going to be plating the whole crossmember as well so I dont rip the rack outta the frame
    whatstcp and erok81 like this.
  2. Oct 10, 2022 at 9:04 AM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    @Airdog did his and my bumps to 1”. It’s doable.
    erok81[QUOTED] likes this.
  3. Oct 10, 2022 at 9:06 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    What is there reasoning behind not being able to do it? I feel like there is some missing information here. Do you have a standard King bump or their short threaded style?
    I wasn't able to confirm the King PN but here is a link to the FOX variant. Should be a very similar product.
    https://www.polyperformance.com/17528-parent-item-fox-20-air-bump-stop-shaft-spacer
  4. Oct 10, 2022 at 9:13 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    I think their biggest issue is the loss of fluid volume with a 1 inch spacer added in. I do agree with them…when I did mine it was noticeable when adding in the fluid. But since I did it myself I know the risk. No issues so far and I beat the fuck out of them. Though if I wasn’t running a bypass I’d probably would not shorten mine.
  5. Oct 10, 2022 at 9:43 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Now I can save my pennies for the Tundra rack, those offset bushings will be game changers for this.
    whatstcp and not_nick like this.
  6. Oct 10, 2022 at 10:23 AM
    erok81
    erok81 Well-Known Member
    Imposter
    These are the bumps I have:
    https://downsouthmotorsports.com/i-19986929?q=Bump+stop+shorty+
    No missing info. At least I don’t think. I said I had those bumps and wanted to shorten them to 1” stroke.
    First time they said it’s due to oil volume. I didn’t press it and just took them off using only my bypass for bumps. That kind of makes me nervous so I threw them back on, remembered why I had removed them, so I asked again but this time said I didn’t have any other options and needed to shorten.
    Still said no with the reason being 2” is the shortest they can go and still work properly.
    Worst case I can just remove them again and either run bypass only again or put in sole superbumps I have sitting around. Orrr…maybe some low profile poly bump like Marlin uses and use my bypass for bumps and the poly one for an “emergency use only” bump. :)
    I’m pretty sure this is the reason. I feel like they are thinking this idiot wants to slap in a spacer then blame us when it doesn’t work or breaks.
    If I did add the spacer any idea how long it needs to be?
  7. Oct 10, 2022 at 10:47 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    so you only have 2” of up travel !?
  8. Oct 10, 2022 at 10:48 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    The question I would have is, does the bushings move the rack far enough forward to allow tie rods to clear the springs if LCA's have been moved forward? I assume you still need to alter the length of the steering shaft. One thing about staying with the stock rack and stock steering shaft is that they readily available. Going with the Tundra rack I believe everything is custom. With the JD Fab set up maybe Harry can chime in hear. If the slide rack failed or got damaged, could it be eliminated from the system on the trail and go back to tie rods (spare tie rods) directly off the rack. As long as the tie rods would clear the springs.
  9. Oct 10, 2022 at 10:58 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I like that they're actively looking out for customers and not just making changes. You make the spacers long enough to take up the distance you want to subtract from the travel. So if you have 2" stroke bumps, and you want 1" stroke, then you get 1" spacers.
  10. Oct 10, 2022 at 11:00 AM
    DocME
    California
    '07 FJ Cruiser
    He's bumping off the inside of his arms. So the outside path of travel could be a lot more than 2-1/4". I have the same problem and I have a lot more than two inches of travel.
  11. Oct 10, 2022 at 11:30 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    oh duh, everything he has been posting lately was about the ass end so I thought he was in lowrider mode in back
  12. Oct 10, 2022 at 11:40 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    What is bump pressure at? Do you ever fully stuff a bump on your hard hits?
  13. Oct 10, 2022 at 11:41 AM
    dwphoto
    dwphoto Well-Known Member
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
  14. Oct 10, 2022 at 11:47 AM
    desertjunkie760
    Shane
    Check My Sig.
  15. Oct 10, 2022 at 12:05 PM
    dwphoto
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    shhhhh... Every one of us that took a ride in this thing... was like what in the actual fuck :eek:
  16. Oct 10, 2022 at 12:23 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    That was my reaction when I first saw the video lol
  17. Oct 10, 2022 at 12:36 PM
    desertjunkie760
    Shane
    Check My Sig.
    I just want my truck to be able to do the same. I don't see why that's too much to ask. lol
    nudavinci64 and TOTAL CHAOS like this.
  18. Oct 10, 2022 at 12:37 PM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    I refuse to believe there will ever be a situation where someone breaks their steering shaft and still has a remotely repairable truck :rofl:
    I could see sheering the splines at the bottom or skipping some maybe. I'm still a strong believer that that's what's really happening sometimes when people mention their rack skipping teeth. But i don't see how you could damage a steering shaft that bad without a rollover or having at least half your suspension ripped off
  19. Oct 10, 2022 at 12:42 PM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Hes talking about just being able to swap a stock steering rack back in on the trail, and not breaking the steering shaft. With a Tundra rack, you only option is to swap in another modified tundra rack, unless you have the ecentrics or an adjustble steering shaft to adapt back to a stock rack.
    01 dhrracer likes this.
  20. Oct 10, 2022 at 12:46 PM
    01 dhrracer
    Still Shopping
    The point being is that with the entire steering system using modified parts if something does fail the more likely of longer down time waiting for replacements. I also like to keep the week link (there will always be one) an item that is easy as possible to change.
    Sterling_vH111 likes this.
