Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 2, 2023 at 5:02 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Hi…it’s your local dummy back with some valving questions.
    I have a good handle on the rear with sole stuff I messed with and gets pretty close to perfect now. But the front could use some work. Since I have a coilover and a bypass I’m not sure where or what changes i should try.
    From you guys’ help before we made some huge progress. Here is where I am now.
    Coilovers have 600 pound springs with 10/10 valving. The bypasses (2.5 triple tube) have 0.018 compression and 0.010 rebound.
    I’d like to soften up the daily driving and small bumpy stuff. I don’t have any giant whoops around here that would need a little more stiffness.
    What are some suggestions?
    tacotunner06 and Buttskevin21 like this.
  2. Mar 2, 2023 at 5:04 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Sell it
    Buy a stock truck
    :rofl:
    Jk
  3. Mar 2, 2023 at 5:13 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    how open are your tubes?
  4. Mar 2, 2023 at 5:42 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    I’ve been told he’s super slutty so I’d assume all his tubes are open
    erok81 and Bandido like this.
  5. Mar 2, 2023 at 5:43 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    All three.
    Recently learned the live valve 3.1 I have are quadruple in front and triple with an open bleed in the rear.
    erok81 and Caboose117[QUOTED] like this.
  6. Mar 2, 2023 at 6:28 PM
    erok81
    Imposter
    Both of the comp tubes are fully open and I think the rebound is two turns in from fully open.
  7. Mar 2, 2023 at 6:30 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    I would hate to suggest dropping compression to 12’s that’s a big drop. You could try running 12’s on your first couple big shims than stack it to 15’s for higher speed or do a flutter stack.
    erok81[QUOTED] likes this.
  8. Mar 2, 2023 at 6:35 PM
    erok81
    Imposter
    YotaFAB and Y2kbaja like this.
  9. Mar 2, 2023 at 6:37 PM
    erok81
    Imposter
    Maybe I’ll give the 12’s and 15’s a try first and see how it goes.
    I need to order a couple new shafts so I figure while I have it apart I might as well swap some stuff around.
  10. Mar 2, 2023 at 6:50 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Quit worrying about road handling on a pretty well built off road truck?
    Is there a flutter in the coil over?
  11. Mar 2, 2023 at 7:42 PM
    erok81
    Imposter
    I only care about road handing because 90% of my driving is on road. But still small stuff road it’s not great at.
    Coilover is straight 10’s. No flutter in either.
    Caboose117 likes this.
  12. Mar 2, 2023 at 8:02 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Make a DC swaybar or get a variable arm
  13. Mar 3, 2023 at 5:47 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    How many bleed holes are open on the coil over?
    MI-FLoffroader likes this.
  14. Mar 3, 2023 at 9:05 AM
    erok81
    Imposter
    I am pretty sure only one. They are standard coilovers from DSM spec’d for a DK kit.
  15. Mar 3, 2023 at 9:27 AM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    I know with the 16” travel shocks you gotta go through the bed to achieve full stroke…would you need to do the same with a 14” travel?
  16. Mar 3, 2023 at 10:08 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Not if you go with the JD shock mount & SUA kit.
  17. Mar 3, 2023 at 10:10 AM
    desertjunkie760
    Shane
    Check My Sig.
    Check the bleed on you C/O. You have staggered tube layout, correct? I'd probably go to a .015 on compression in the bypass. You have hydro bumps so you can get away with a little less compression damping in the bypass.
  18. Mar 3, 2023 at 11:38 AM
    MulletTaco
    Kevin
    Somewhere in AZ
    Copy that. Because I really don’t know anything about it, what makes the 2” difference a big deal between the 14” and 16” stroke shocks and needing a bed cage or not?
  19. Mar 3, 2023 at 11:50 AM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    cause its 2” of shaft and 2” of body as well. So it’s actually 4” extra extended.
  20. Mar 3, 2023 at 11:54 AM
    MulletTaco
    Kevin
    Somewhere in AZ
    That make a lot more sense, guess I could have looked at the shock specs too lmao. I appreciate the info. Just gotta figure out the info accutune needs for me to add these to my cart lmao
