Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 6, 2023 at 2:23 PM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    See the motion ration is something I’m trying to learn about too, I’ve read the technical explanation and how to find it but I still don’t understand it.
  2. Mar 6, 2023 at 2:29 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    The point was...dont try to reinvent the wheel...I know you've been looking at tons of trucks....do what they do. SUA on our trucks is pretty much been dialed in by almost every fab shop. Though if I were you i'd just go with the JDfab kit and be done with it. It can use either the 14inch under the bed or 16's into a bedcage you fab yourself.
    To throw another wrench into it....leaf springs do not move straight up and down they move in an arc. My rear end moves about 2.5 inches rearward from full droop to full stuff. So...with that my shocks are mounted about 1 degree forward at full droop..then strapped a little shorter so as to protect my shocks from ever going over center. But I can get almost 18 inches of travel metal to metal out of a 16 inch shock because of the rearward movement....somebody can do the math and get the motion ratio out of those 2 numbers.
    MulletTaco[QUOTED] likes this.
  3. Mar 6, 2023 at 3:32 PM
    MulletTaco
    Kevin
    Somewhere in AZ
    This is exactly the info I was looking for. Thanks bro :thumbsup:
  4. Mar 6, 2023 at 4:17 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    How did you change your user name?
  5. Mar 6, 2023 at 4:33 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    Ok...I thought I was losing my shit....I was swearing to myself that the name was different when I replied.
  6. Mar 6, 2023 at 5:40 PM
    MulletTaco
    Kevin
    Somewhere in AZ
    Emailed support lol scroll down to the bottom of any thread and select contact us
  7. Mar 6, 2023 at 5:50 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    clears throat… cough…well technically your axle on your leaf springs move in a variable parabolic arc and your axle housing also rolls as your springs travel through that parabolic arc…So, your lower shock mounts are basically rocking back and forth on an uneven radius as your suspension compresses and droops. That is why if you ever run any sort of traction bar set up you must run the front pivot for the trac bar as a shackle. If you don’t you will bind your leafs and break a main …ask me how I done learnt that there lesson
  8. Mar 6, 2023 at 6:03 PM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    So what you’re saying is just link it
    TacoEspecial, MulletTaco and Airdog like this.
  9. Mar 6, 2023 at 6:13 PM
    MulletTaco
    Kevin
    Somewhere in AZ
    Wanna give me several thousand dollars? Lmao
  10. Mar 6, 2023 at 6:19 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    There isnt really a huge diff in price between a linked setup and SUA anymore. Again to sound like a JDfab fanboy.....they have a kit for either SUA or links....most of it depends on you ability to fab something for your upper shock mounts the rest is pretty straight forward.
  11. Mar 6, 2023 at 6:31 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Yeah but who is linked with a stock rear axle? Anyone pushing the truck hard enough for links isn’t sticking with the 8/8.4 pumpkin and then you’re looking at about 12k in parts. Even those pushing their SUA setups hard do away with the stock axle.
    Airdog[QUOTED] likes this.
  12. Mar 6, 2023 at 6:37 PM
    MulletTaco
    Kevin
    Somewhere in AZ
    I thought about going linked but I’m not planning on pushing it that hard, she’s still my daily lol I wanna go LT because I’ve wanted it since I was in high school and because I live in the desert and going fast on trails is fun. And I plan on having the family vacation be in Baja every year :rofl: I know I don’t NEED LT for all that buuut it sure is a lot more fun
    Airdog likes this.
  13. Mar 6, 2023 at 7:18 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    Putting in the ford 9 full float has been the best upgrade for me considering I blew 4 diffs and bent 2 stock axle housings. It’s a must for piece of mind when you’re trying to keep up with @81Trekker in ocotillo.
  14. Mar 6, 2023 at 7:24 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Links also have double the shocks cost. That was the big deciding factor when I did my back half and keeping with leafs. Also I already had the geometry figured out.
    MulletTaco likes this.
  15. Mar 6, 2023 at 7:25 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    What’s with the giant bump wear pads?
  16. Mar 6, 2023 at 7:41 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    The new axle actually sits lower than the original axle. The spring perches were different. Instead of cutting off the bump cans off I just machined up some taller bump pads to fix the issue temporarily.
    Until I find some time to fix it this will do. Gonna need to do some shock relocation over the summer.
    snowsk8air2[QUOTED] likes this.
  17. Mar 6, 2023 at 8:32 PM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    What’s the multiplier for linking the front? :p
    BEAR_KNIFE_FIGHT likes this.
  18. Mar 6, 2023 at 8:39 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    So after a long hiatus I’m back!! Just over 8 years ‍♂️E9EA6B39-C378-4D3D-9C94-E32027D14187.jpg
    rook her out for a shake down run at Pismo… and shake her down we did! Felt sooooo good!
  19. Mar 6, 2023 at 9:12 PM
    DIRT YOTA
    Cory
    Camarillo, CA
  20. Mar 6, 2023 at 9:24 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Hell ya. Looks awesome!!
    DIRT YOTA likes this.
