Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 7, 2023 at 11:18 PM
    erok81
    erok81 Well-Known Member
    Imposter
    So your shocks had the flutter on both ends from accutune? I can’t find anything on google about “double flutter”. Just Accutune results.
    So there were two sets of flutters on the compression side? My rears I did 0.015 flutter for as the second shim. But fox has it between second and third?
  2. Mar 8, 2023 at 3:56 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    I really really have to disagree with that statement. Linking a stock axle housing is stupid, so there goes 8k for an axle. Have to go to a cell unless you do a 3 link setup, which wouldn’t make much sense in my opinion. Double the shocks, should be caged at that point as well. I reviewed linking my truck during the cage build. It would have been over 20k by the time I was done. I’m like 5 deep in my rear as SUA. Maybe a little more.
  3. Mar 8, 2023 at 4:53 AM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    I can confirm all of the above
  4. Mar 8, 2023 at 6:01 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    I'm not sure if i actually had it, just when king saw the accutune stickers they made the comment that they do flutters on rebound and no one else does.
  5. Mar 8, 2023 at 7:22 AM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    What were in those smooth bodies that came off my truck?
  6. Mar 8, 2023 at 7:32 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I was always under the impression that a "double flutter" was two flutter stacks on the compression side but I can't confirm from experience. A flutter on both circuits seems redundant in comparison to bleed but maybe they are on to something. Can't rag on anyone for trying new ideas.
    Typically, a flutter is a smaller .08-.012 shim right after the largest shim in the stack. There is obviously no standard and you can change this in many ways but that's what you see most commonly. I wouldn't go thicker than a .012 shim or you won't engage the secondary stack nearly as often as needed and create a ton of "bleed".
    Also, you three have nearly identical profile pics. Just an observation.
    RonRon23[QUOTED] likes this.
  7. Mar 8, 2023 at 7:38 AM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    Yeah but Cory’s is still a 2nd gen…so it’s better…lmao
  8. Mar 8, 2023 at 7:53 AM
    desertjunkie760
    Shane
    Check My Sig.
    Yes... :fistbump:
    tacotunner06[QUOTED] likes this.
  9. Mar 8, 2023 at 8:59 AM
    906taco
    Cory
    08 Taco
    Lol what’d I miss?
  10. Mar 9, 2023 at 1:22 PM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    The only time I did a flutter the largest shim sucked into the piston leaving 4 oval pieces floating in the oil. Both sides, rear. Won’t do that again.
    erok81 likes this.
  11. Mar 9, 2023 at 1:31 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    how thin did you go?
    erok81 likes this.
  12. Mar 9, 2023 at 5:04 PM
    erok81
    Imposter
    Maybe I’ll try either a 10 or a 12 for the flutter. I know I have 20’s and 15’s (wouldn’t use the 20). I’m going to measure tonight and see what I have.
    Which diameter do you guys usually use? If I remember on the rear I used the second smallest one on top of the biggest shim.
  13. Mar 9, 2023 at 5:09 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
  14. Mar 9, 2023 at 6:55 PM
    906taco
    Cory
    08 Taco
    Play with diameter. Diameter will also impact things. If the small softens it too much go bigger diameter.
    erok81[QUOTED] likes this.
  15. Mar 9, 2023 at 8:05 PM
    erok81
    Imposter
    Valving is really a never ending list of adjustments isn’t it. Fun to learn that’s for sure.
  16. Mar 10, 2023 at 4:56 AM
    906taco
    Cory
    08 Taco
    Lots of factors at play for sure. What exactly are you trying to accomplish and what kind of terrain?
  17. Mar 10, 2023 at 7:50 AM
    Y2kbaja
    Sacramento
    Total Chaos
    It may have been a 10-fl-10-10etc. I don't recall. Fox shox btw. Now that I have my rear springs I'm in massive need of shock tuning but I think I need to start with replacing the pistons.
  18. Mar 10, 2023 at 11:01 AM
    erok81
    Imposter
    Better over smaller bumps (and street driving). Around here even when I do go off-road I don’t have any huge whoops or anything fun. That and I like messing around with things. It’s pretty close to where I want it just want to see what I can do with the front.
  19. Mar 11, 2023 at 6:35 PM
    Tacoma1192
    Tacoma1192 GD MOTORSPORTS
    Kyle
    Boise, ID
    2015 DCSB Sport
    39's, LT, 4 Link, Spidertrax 9"
    not_nick, Prayn4surf, CGoss and 9 others like this.
  20. Mar 11, 2023 at 6:47 PM
    erok81
    Imposter
    I can’t remember which page we talked about this when I wanted to revalve someone mentioned bleed holes. Apparently on my coilover all three are open.
    Still did the flutter to what it does. Only posting this since it was discussed.
