Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 27, 2023 at 10:00 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    231
  2. Mar 29, 2023 at 5:32 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    So ive watched the vids and read the forums...(King 2.5) To set an IFP depth, all I have to do is bottom it out in resi (after cycling to remove air), and let shock body overfill while pushing in seal cap? And that will in turn move the IFP back some?
  3. Mar 29, 2023 at 5:37 PM
    erok81
    erok81 Well-Known Member
    Imposter
    That’s what I did, which I learned here.
    Remove shaft from shock, pump up reservoir with bike pump (be careful because when it moves it might shoot oil everywhere so put a rag over it). Once that’s done release pressure and valve core. I top off the shock to maybe 1/2” below the top. Insert shaft and jiggle/move up and down to bleed. Wrap shock with a rag, push seal body down and spill oil everywhere.
  4. Mar 29, 2023 at 5:46 PM
    IvanhoeTaco
    Eastern NC
    I was going to get a piece of threaded rod for pushing/pulling the ifp, I assume thats acceptable in place of air pressure?
  5. Mar 29, 2023 at 5:54 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Yes. You need to cycle the IFP regardless to bleed the air out. Fill oil to the clip seat. Slowly push the seal cap down, then I like to push the IFP in one more time as it usually pushes some air out around the seal cap, then just jam it in.
    I bent 1/4-20 threaded rod into a T handle and put heat shrink tubing on most of it.
  6. Mar 29, 2023 at 5:55 PM
    erok81
    Imposter
    YMMV. But the bike pump was way easier for me than the threaded rod. When I did it that way it was a bit hard to move. Either way works though.
    IvanhoeTaco[QUOTED] likes this.
  7. Mar 29, 2023 at 5:57 PM
    erok81
    Imposter
    That’s a good idea. I was just using pliers on the rod. Didn’t work great.
    906taco[QUOTED] likes this.
  8. Mar 29, 2023 at 5:58 PM
    906taco
    Cory
    08 Taco
    Yeah, you have to cycle the IFP regardless if the oil was dumped. You’d be amazed at how much air pushes out sometimes. Skipping that step is no good.
    erok81[QUOTED] and IvanhoeTaco like this.
  9. Mar 29, 2023 at 6:03 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    Agm also makes a really nice tool for moving the ifp and has a tape measure built in to help set depth.
  10. Mar 29, 2023 at 6:03 PM
    IvanhoeTaco
    Eastern NC
    So when it comes time to push the seal cap into the shock body, the ifp should be bottomed out correct?
  11. Mar 29, 2023 at 6:05 PM
    906taco
    Cory
    08 Taco
    Yes. But it won’t be fully bottomed after pushing the cap in.
  12. Mar 29, 2023 at 6:07 PM
    IvanhoeTaco
    Eastern NC
    Is there a spec'd measurement I should be seeing? Or just 1/4 to 1/3 of the resi depth?
  13. Mar 29, 2023 at 6:09 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    Fox has their depths posted online but king you would have to call and ask about but yeah 1/4 to 1/3 sounds about right.
    IvanhoeTaco likes this.
  14. Mar 29, 2023 at 6:15 PM
    IvanhoeTaco
    Eastern NC
    Thanks everyone
  15. Mar 30, 2023 at 4:08 AM
    906taco
    Cory
    08 Taco
    King is just going to tell you to bottom it out. Depth is mostly important for non reservoir shocks.
  16. Mar 30, 2023 at 6:30 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Most important thing about setting ifp depth is that it’s not too far out and the shock hydro locks. I always do the bottom it out before pressing the seal in method. But I still check that it isn’t going to hydro lock after assembly. Just throw like 50 psi in the shock and compress it fully. If you can then you’re good. If you can’t, something’s wrong
  17. Mar 30, 2023 at 7:33 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    I’ve always compressed the shock fully then added air to the resi….if the shock shaft fully extends then you’ve done it right. If you can pull the shock shaft any amount out after adding pressure to the resi something is wrong.
  18. Mar 30, 2023 at 8:44 AM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Usually that will mean there is air in the shock body and it wasn't bled correctly
    Airdog[QUOTED] likes this.
  19. Apr 1, 2023 at 10:07 PM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    Drop an update in here when you do, please. This is next on my list
  20. Apr 2, 2023 at 7:40 AM
    906taco
    Cory
    08 Taco
    I too am curious. But one thing that has me a little apprehensive is the size of the bearing used. It looks to be about equivalent of the OE bearing. With how much room there was, why not go with something bigger which would definitely add life.
