Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 9, 2023 at 12:16 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I don’t think it was before… maybe a little. Either way the tundra rack was such an improvement from the stock failing rack with shot bushings i may not have noticed.
  2. Jul 9, 2023 at 8:06 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Anyone removed the pink vent cap things from a gas tank? Im replacing my tank and the new used one is cracked, so if possible, I could swap the old vents on to the new tank. They look to be sealed with some hard plastic or sealant.
  3. Jul 9, 2023 at 8:57 PM
    Sterling_vH111
    Sterling
    socal
    https://youtu.be/UPYuT-anW9Y
    Here’s a video of the rag joint / upper intermediate shaft.
    I torqued the rack bolts again, and they weren’t any loose. Not sure if they could’ve moved. The rack doesn’t look off center visually.
    One big thing to note, is when I looked up the torque for the upper/lower intermediate shaft coupler just outside of the fire wall, as well as the pinion shaft coupler, I found 35nm. I firmly believe that I torqued those 3 bolts when installing the tundra rack, as well as 500 miles later when I re-torqued all the suspension I had off at the same time… however from my recollection and notes I did 20nm. Almost half.
    I’m hoping this dumb mistake solved my issues of loosing alignment.
    Still — the whole shaft sitting so off center from the firewall hole is odd. I think it’s from where the rack is sitting, pushing the shaft outwards due to the larger size of the tundra rack…
    not_nick likes this.
  4. Jul 9, 2023 at 10:10 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Yah that makes sense to what I was thinking. My setup is +2” so 69 would work. unless I plan to pull it all and slap a 3.5” or 4” front setup. 69” sounds like the money shot. For this truck likely keep it. jD setup could happen but I’ll beat up on the TC more before that happens.
    Thanks! @01 dhrracer
    01 dhrracer[QUOTED] likes this.
  5. Jul 10, 2023 at 7:46 PM
    Stagarm
    Stagarm Well-Known Member
    Trev
    Fj
    Me behind the wheel
    Installed wc 5" over mid travel kit with dirt kings spec Fox 2.5 8". Today on the highway I noticed it's very "bumpy" almost like driving a 90's lowered Honda civic. Still running my Oe bumper. Will be building a tube bumper but that will only be adding 40-60lbs over stock weight up front. Plan to keep the front lite.
    From my last rig that ran kings it is very different feeling.
    Any suggestions?
  6. Jul 10, 2023 at 9:32 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Go get your shocks tuned
    RonRon23 and nudavinci64 like this.
  7. Jul 10, 2023 at 10:30 PM
    Stagarm
    Trev
    Fj
    Me behind the wheel
    Couldnt agree more. Tuning is everything. Once I get the bypasses, steering and finished weight out front.
    I guess I should've asked if others have experienced bouncing with fox?
  8. Jul 10, 2023 at 11:07 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    On certain stretches of freeway
    Almost every LT truck I’ve been in bounces
    Dekoy909 and Sterling_vH111 like this.
  9. Jul 11, 2023 at 1:27 AM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    Haha cool that you actually made a video. That's a bit less movement than mine had but i'm not sure i'd call it good either. On mine the intermediate shaft had about equal amount of play with similar force but the pins wiggled a lot more. But I haven't had a chance to compare to a new one so ultimately idk maybe the rag joints come with as much play as yours has
  10. Jul 11, 2023 at 6:15 AM
    Sterling_vH111
    Sterling
    socal
    I ended up finding the 2 bolts that hold the intermediate shafts together, on that coupler just outside the firewall — as well as the bolt that holds the shaft to the steering rack “loose”.
    When I originally torqued them down and double checked and 500 Miles later, I had it in my notes they were 20nm…
    When I looked it up last night online, I found a diagram that said 35nm…
    Not sure where I got 20nm before, but they were all at that. I took them all to 35nm and marked everything.
    I am hoping that this dumb mistake allowed the shaft to slip on the pinion spline on the rack - and that’s my problem.
  11. Jul 11, 2023 at 7:09 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Bump, anyone?
  12. Jul 11, 2023 at 8:01 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    They are part of the tank. You’ll never be able to swap.
  13. Jul 11, 2023 at 10:00 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Thanks, thats what I figured but hoped otherwise.
  14. Jul 12, 2023 at 2:41 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
  15. Jul 12, 2023 at 2:45 PM
    Sterling_vH111
    Sterling
    socal
    Count me in!
    Missed this last one, but definitely want to meet more LT guys to hit the desert this winter.
    djthicks and DIRT YOTA like this.
  16. Jul 12, 2023 at 4:13 PM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    Watch out for Honda civics that will back into your bumpers. Ask @Airdog @Yotamac or @Jerez
  17. Jul 12, 2023 at 5:05 PM
    brandonstocool
    brandonstocool Well-Known Member
    Brandon
    California
    2001 Silver Tacoma Double Cab TRD
    Camburg LT Kit King 2.5 8" Coilover Mcneil Fiberglass 6"&Hood Billstein 5100 OME Leaf Spring Fiberwerx 4.5" Bedside
    If I can get my truck finished by then I am down!! Even though I’m only front LT for now…
    DIRT YOTA likes this.
  18. Jul 12, 2023 at 5:34 PM
    nudavinci64
    Robert
    50% more than the crowd!
  19. Jul 13, 2023 at 9:16 AM
    nudavinci64
    Robert
    Coming back to the width. Should I line up the rear to the front or have it a tad narrower? Rear axle is already bent so measuring is a bit off but front track is 86.5~ and rear is 82~ end to end on the current wheels (4.5" but could be closer to 5" since the rear wheels have some negative camber right now). Most I have seen are 69" or 70" on a +2" - +2.25" setups. One person suggested 67" to keep it narrower than the front. Seems like I should at least have it 3" (68") if not 69" but seeing 70" makes me curious how much this will factor into the turning and overall handling.
  20. Jul 13, 2023 at 9:48 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    A narrower rear end creates oversteer ( good in moderation ) whereas and equal width tends to create an understeer ( bad ). I believe most folks would tell you to be 2" narrower in the rear end ( 1" per side ) to create a bit of oversteer = quicker turning
