Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 8, 2023 at 10:28 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    oop. I Hope I didn’t ruin it either…
    I put some blue lock tight and didn’t crank on it too much. This is the 2nd time I’ve hade them off - but I bought the rack used from a member here.
    I’ll have to double check the smell lol. Pump doesn’t sound bad, and there was brand new fluid in that system about 3 months ago. DEX VI ATF.
    I forget if I mentioned in my last post, but I found a leak coming from where the return tube comes off the rack. I think it may be sucking in dirt or something. It’s a slow small drip that doesn’t spray or anything while engine is running or turning the wheel.
  2. Aug 9, 2023 at 3:44 AM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    It's hard to tell. Basically replace the fluid and see if the leak is still causing you contamination problems. Depending on how much wheeling you did, the fluid should stay more on the transparent red side pretty much and not so blackish in 4k miles. If the rack was used maybe it's a good time to flush anyway. Or the expensive-r route, remove and replace everything to remove doubt but it's not that big of a system. Let me know if you need a second pair of eyes on it. I'm no guru but happy with the way my steering ended up
  3. Aug 9, 2023 at 6:07 PM
    JasonT87
    JasonT87 Well-Known Member
    Southern California
    '16 TRD Sport DCSB
    Total Chaos mid-travel front. JD Fab SUA rear.
    Wow you have a ton of room between your tire and rear shocks. AND on 35s? I’m jealous.
    Although your backspace/offset might be slightly off but a 4.0BS looks more like -20 offset.
    I’m running a 287/75/17 tire with 0 offset (4.75BS) and I’m a lot closer to my bypass. @81Trekker recommended me 1.25” spidertrax wheel spacers but I’m also going to look at a different wheel setup too just so I don’t have to run as big of a spacer.
    Supra4x4[QUOTED] likes this.
  4. Aug 9, 2023 at 6:13 PM
    cdex8357
    cdex8357 “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    Not long travel but got 12” triple on the rear. 315/75/16 (4.5 BS) and a 1.25 spacer. Clears all day.
    Supra4x4[QUOTED] and DoulosXP like this.
  5. Aug 9, 2023 at 7:24 PM
    TrapComa
    TrapComa Well-Known Member
    Mason
    Cedar Park, TX
    07 Indigo Ink LT PreRunner
    Wannabe prerunner, wannabe overlander
    I’m glad this came up, I’m in Cedar Park. Not due for a rebuild yet but will be in touch when I need one
    ian2016[QUOTED] likes this.
  6. Aug 9, 2023 at 8:33 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Cool, thanks. I should be good then.
    Yeah despite being a 315 they don’t seem much wider than my last set of tires. I don’t think these are as wide as 35x12.5” spec tires, despite 315 supposedly equaling 12.4” wide.
    4.00 bsp is what SCS specs their 16x8 wheels at for the Ray10. :notsure: Either way, I’m happy with the offset, seems to be a good balance with the 4” kit up front. That reminds me, Harry said I should get my shocks clocked, tubes are a little close for comfort with the mounts.
  7. Aug 9, 2023 at 8:53 PM
    ian2016
    ian2016 @shockteq
    Ian
    Kyle, Tx
    2016 4x4
    Sounds good man, whenever you’re ready just send me a message on here!
  8. Aug 9, 2023 at 9:23 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    I will post a picture for you tomorrow morning.
  9. Aug 10, 2023 at 9:31 AM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
  10. Aug 10, 2023 at 9:37 AM
    Pittsy
    Pittsy AKA LS6Taco - Ex car guy, current truck guy.
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Stroker Swap - LS6Taco
    the 3 laws of CQB. word
  11. Aug 10, 2023 at 2:40 PM
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    MitchMade from IG got his carrier bearing finished for 2wd and 4wd. Thought this was going to be a solution since the stock carrier wears out so fast, but it says you have to modify the drive shaft for it to work? Am I reading that right? Seems a little backwards to modify a problematic driveshaft for a carrier bearing that itself costs $300. Would it be smarter to fix the shaft instead?
    https://www.mitchmadeinc.com/product-page/toyota-center-support-bearing
  12. Aug 10, 2023 at 3:50 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Only 2wd needs to be modified to add a slip yoke on the rearshaft. 4x4 already has it so you’re good to go. I have had one on my 2wd from his first batch and not a single issue
  13. Aug 10, 2023 at 5:47 PM
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    Ahh yes, I was wondering about that. Thought that’s what it had already. May try to pick one up before the cinders meet. If I can Mickey-mouse a u-joint press.
  14. Aug 10, 2023 at 6:20 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    Amen.
  15. Aug 10, 2023 at 7:14 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    Shit….I used a hammer and a socket to do my ujoint. But I just had them replaced when I had my drive shaft lengthened for my ford9 axle so they came apart easily.
    tacotunner06 likes this.
  16. Aug 10, 2023 at 8:11 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    When you guys are not killing it in the dunes or trails where do you have your shocks set, compression and rebound. The bypass shocks
    I was told to run everything open on the road.
  17. Aug 11, 2023 at 1:21 AM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Hammer and a couple sockets is all you need, but if you have a vice it makes it a lot easier.
    Y2kbaja likes this.
  18. Aug 11, 2023 at 7:59 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Same place as when in the dirt.
    tacotunner06 and Tango Bravo like this.
  19. Aug 11, 2023 at 8:19 AM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    awesome thanks
  20. Aug 11, 2023 at 8:53 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Not worth the effort to adjust the bypasses for road/dirt use. If you have like the quick compression adjusters on the coil over than maybe you’d adjust that if you really wanted.
