Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Sep 24, 2023 at 2:53 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    No, muds dig sand too much and do not float as good as an AT.
    I would suggest the Nitto Ridge Grappler I’ve been running them on my taco and t4r and they work great and are actually the quietest off road tire i have ever owned on road / hwy
  2. Sep 24, 2023 at 3:30 PM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    Anyone build extra taillight supports for their fiberglass? I sent my truck a little too hard last night and lost a taillight... bolts are still there but it snapped the housing right off
  3. Sep 24, 2023 at 4:13 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    The problem is the design of the oe taillights themselves the plastic tabs will always break. A few guys have built different taillights ie: a metal frame with individual leds i am filling in the taillights on my glass and molding in locations for leds
    SoonToBeOn39s[QUOTED] likes this.
  4. Sep 24, 2023 at 4:31 PM
    SoonToBeOn39s
    That's exactly what broke on mine. Maybe someone sells those type of taillights?
  5. Sep 24, 2023 at 4:36 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Something else I’ve seen is some taking that steel band strips they use to secure loads to a pallet and strapping it around the plastic light and securing it with nutzerts on the backside
  6. Sep 24, 2023 at 4:40 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    noone sells them that i am aware, i think @tacotunner06 is one of the guys that has done it
  7. Sep 24, 2023 at 4:43 PM
    pastoreater
    pastoreater doesn't know
    M
    5g 4runner
    @Caboose117 I was asking if there are like non DOT sand tires for 4runners. I was suggesting that I could park off pavement and unload and bolt up two oversized rear wheels. And then put back on the matching set for the trip home.
    Thanks, I will watch closely
    Caboose117[QUOTED] likes this.
  8. Sep 24, 2023 at 4:56 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Don’t have pictures, but before I built custom lights I made a little bracket off the bed and bolted the back of the tail light to it. Basically shaved the “nipple” supports off the bedside and unscrewed the nipples from the tail light. Then screwed the tail lights to the bracket off where the nipple was. Lasted for years like this without issues.
  9. Sep 24, 2023 at 4:59 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I mean you can search for paddle tires in a size that would fit. But you’ll likely have clearance issues.
  10. Sep 24, 2023 at 5:31 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    That makes way more sense
    Actual paddles though will give you clearance issues
    And
    I’ve def seen dudes destroy their body panels because of the paddles
    Tho more so with fiberglass
    Edit: I totally wanna say it’s more stress on your axel too
    I swear someone in here snapped some axels with paddles
    I’d assume it’s the same reason mud truck dudes snap them on their paddles
    pastoreater[QUOTED] likes this.
  11. Sep 24, 2023 at 5:34 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You don’t run paddles with glass for the most part - for that reason
    pastoreater and Caboose117 like this.
  12. Sep 24, 2023 at 5:36 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Yeah right? It’s not just like the paddle tire but the sheer volume and force of the sand being thrown too right?
  13. Sep 24, 2023 at 5:51 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Think it was some guy named Devon......blew out ujoints on the driveshaft while running paddles on his tacoma
    pastoreater likes this.
  14. Sep 24, 2023 at 5:55 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Big yikes
    Driveshaft failures are terrifying IMO
    And those safety loops to catch them are a must
  15. Sep 24, 2023 at 6:15 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Silver lake dudes use these instead of paddles - even these put a lot more load on the drivetrain as well
    https://youtu.be/Q7c7ESbCGiA?t=1035
  16. Sep 24, 2023 at 6:16 PM
    orbot
    orbot Well-Known Member
    Ive had my set for a while and 2 have gouged similarly and hardly any off roading
  17. Sep 24, 2023 at 6:52 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    A/T tires are going to do better than mud tires. But you will also need to consider what wheels you will be using. Airing down (lowering the tire pressure) is what you will have to do. You may find yourself (depending on the tire) needing to go down to 10psi and maybe even a little lower. Therefore using a beadlock type wheel or Method Bead Grip wheels would be highly recommended in order to keep the tire from de beading.
  18. Sep 24, 2023 at 6:58 PM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    Two totally asinine questions that I couldn't find a clear answer to from searching:
    • I can get away without running glass with 35s on the JD 2.25 kit, could I on the 4 or is the geometry bad enough that you'll be slamming into the fenders?
    • Does anyone run the JD inner fenders? It seems overkill but if I'm going to have them do work I'd rather one and done.
    Side note: LT club coolest club. Can you imagine if someone posted a random tire question in an unrelated 3rd gen thread? Dude would regret his existence but look at yall.
  19. Sep 24, 2023 at 7:02 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You’ll have to cut the stock metal. Quite a number of guys run the inner fenders.
    cowfootball[QUOTED] likes this.
  20. Sep 24, 2023 at 7:43 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    @Sixthelement truck is running the jd 2.25 kit and inner fenders and we had to cut the front fenders quite a bit. You could probably do a 4” kit but gonna be cutting more
