Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Sep 26, 2023 at 10:50 AM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    I thought that odd too: https://martecnv.com/products/p/2005-tacoma-trailing-arm-3-link-rear-kit
    They're basically running typical mid-travel 12" piggybacks like you'd run on a relocation setup, e.g., PR2512s
  2. Sep 26, 2023 at 10:57 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
  3. Sep 26, 2023 at 11:01 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Looking through their pictures I will mention they are sacrificing a lot of uptravel compared to different setups or a sua setup. Full bump and the axle is almost 6” below the frame
    BEAR_KNIFE_FIGHT and cowfootball like this.
  4. Sep 26, 2023 at 11:03 AM
    cowfootball
    2022 TRD OR
    Yeah, I think I'll pass at least on that kit. Their shock towers are very similar to mid-travel relocations to avoid going into the bed and the loss of uptravel is worth more than the axle strength. I can do most of my crawling with a mid-travel setup anyways, I just need a lil' more oomph for going fast. :)
  5. Sep 26, 2023 at 11:24 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Axle strength? You mentioned getting a “solid axle back there” with this kit. The kit uses whatever axle you have or want to use. You can upgrade your axle with any setup.
  6. Sep 26, 2023 at 11:25 AM
    cowfootball
    2022 TRD OR
    Yeah, I just don't think I'd ever bother upgrading the axle without also linking it. Or run a ton.
    Famous last words.
  7. Sep 26, 2023 at 12:25 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    yeah that kit looks like it sacrifices a ton to meet a few requirements. I will say it probably has good ground clearance which would help a ton with crawling, a real desert 4 link is shit for clearance with canoe lower links, but mine would pull 24” if I had the right bypass on mine.
  8. Sep 26, 2023 at 3:11 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Yeah the ground clearance is pretty good, no low handing links below the axle or low panhard mount. I honestly dont want a higher axle bump location since I dont want the frame on the ground when I'm at full stuff or bumping up a ledge, your frame height is just that much lower thus that much more to frame out. The bump of their kit will be 1.25" higher than my Chevy 63 leafs are bumped at right now, and thats with negative arching my leafs like 3" or so lol
  9. Sep 27, 2023 at 6:15 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Yeah that kit is a little awkward I don’t understand why it’s just 15” ? because i’m using a 12” CO and getting 18” bumped and strapped at very safe positions. If i freeball it it’s 20”. I have recently been looking at mine and thinking of ditching my big ass links and going to more of a short course set up with a tube link and IBP CO’s and my initial look at it i think a 14” CO would fit with the CO raked back almost at the axle and it still seems like it would cycle 18-20 ?
    The position of their CO tower must not be as tucked up as mine is, mine is kissing the wheel well and then my bed cage bolts through…that just made me realize that kit does not have a bed cage ? no way i would run a CO without the towers ties to a bed cage ?
  10. Sep 27, 2023 at 8:10 AM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    https://www.instagram.com/p/CtxlLbqRySq/
  11. Sep 27, 2023 at 10:27 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
  12. Sep 27, 2023 at 10:28 AM
    cowfootball
    2022 TRD OR
    Yeah, they're localish to me and I see them out on Rubicon occasionally. Nick seems to like going fast too but it's definitely crawling oriented.
    https://www.instagram.com/p/CmaYbYPBRcV/
    mauctopa likes this.
  13. Sep 27, 2023 at 12:04 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I see having to deal with bent lowers all too often. The only real advantage I see with it is, is that it makes it easier to bob the frame/bed. If I was to go that route I would consider Ruff Stuff's trailing arms.
  14. Sep 27, 2023 at 11:36 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I'm getting close to tossing the @Basikbiker Tundra rack, JD TC Howe steering kit, and torn if I want to run solid tir rods and inner heims. (I am already running JD double sheer and outer heims. I am running a +2 TC kit now, but was chatting with JD and may grab their solid setup.
    Pros / Cons to running solid tie rods? The part that holds me back is that folks mentioning the diff now becomes the weak point. I have a few weeks at least until my rear axle is done.
  15. Sep 27, 2023 at 11:49 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Diff is unrelated to steering. The rack becomes the next thing to break if you’re running solid tie rods and a stock rack. With an upgrade to the rack you should be good to go. The old argument with the front diff was whether we wanted the cv axles to work as fuses instead of transferring damage to the diff with upgraded axles.
    The plus side to the slide rack is it adds strength while maintaining the ability to still grab any off the shelf Tacoma replacement rack if it ever fails. The tundra rack is propriety when it gets modified to fit the Tacoma.
  16. Sep 28, 2023 at 12:10 AM
    nudavinci64
    Robert
    yah I considered the slide rack. I got a tundra rack with the bolt-in vs weld option and modified goods. In a crunch, i should be able to toss in a stock rack. If it does not work out can always go back.
    Yah def I'm likely mixing up going with RCVs or some other 300 axle up front, which I have also been debating.
    Any cons to going with a solid tie rod setup since ill have a tundra rack and already running outers? Any other kids you or anyone else suggest? Mainly need the inner kit and the rods at this point. I feel I should YOLO and just do it but never ran a full heim setup so unknown to me.
  17. Sep 28, 2023 at 5:48 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Be a real shame to do all that work and upgrade everything just to bend a tie rod.
    With everything else solid there’s no issues running a solid tie rod.
  18. Sep 28, 2023 at 5:48 AM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    I've said it a couple times on the tundra rack pages, but im still just suprised I blew the tundra rack with stock inners and outers. Drivers side slide sideways into a rock face and it popped the seals. Then back to a junkyard stock rack, and I've pretty much done the same situation and just bent like 4 tie rods in the last month lol
  19. Sep 28, 2023 at 8:21 AM
    nudavinci64
    Robert
    exactly that's what I was thinking but replacing a tie rod vs a rack may be more of the debate.
    Recommended solid setups? Mainly need inner and solid. Figure easier to buy a kit than piece together but could hit up Kartek or JD Fab has a nice setup.
  20. Sep 28, 2023 at 1:18 PM
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    Hit up @rc.fabrication on Instagram. He deals in a lot of solid tie rod setups for Toyota. Local guy, he did my spindles.
