Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 15, 2023 at 8:55 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    That’s the appropriate range depending on additional weight and preference. Shock valving also plays a factor. Probably a 16x650 for a 3rd Gen Taco. I think that’s what @AY_ARONTRD went too as the 600s were too soft?
    I run 16x600s on my 2nd Gen but also don’t try and jump it. I’m more concerned with ride quality.
    Are you getting the DSC adjusters or no?
  2. Oct 15, 2023 at 8:57 AM
    desertjunkie760
    Shane
    Check My Sig.
    what’s your rear setup?
  3. Oct 15, 2023 at 9:31 AM
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    That is correct. 16x650’s on my truck and I’ve been happy with them, also don’t try to jump my truck.
    SoonToBeOn39s likes this.
  4. Oct 15, 2023 at 9:49 AM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    Yes I am getting DSC
  5. Oct 15, 2023 at 9:50 AM
    SoonToBeOn39s
    Stock length 2.0s :rofl:theyve held up great
  6. Oct 15, 2023 at 9:59 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I guess so, I’ve never disconnected the battery when messing with the seats.
  7. Oct 15, 2023 at 10:04 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Or just unplug the passenger occupancy sensor and not the actual airbag to introduce a fault.
  8. Oct 15, 2023 at 11:31 AM
    desertjunkie760
    Shane
    Check My Sig.
    :facepalm:
    01 dhrracer likes this.
  9. Oct 15, 2023 at 11:36 AM
    SoonToBeOn39s
    I just wanted something better than stock while I save and decide what I wanna do to the rear end
    BEAR_KNIFE_FIGHT likes this.
  10. Oct 15, 2023 at 11:48 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I would bet the issue some may have is with your desire to jump. Most don't consider jumping their truck without it being a fully caged front to back long travel pre-runner.
  11. Oct 15, 2023 at 11:52 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Air is scary
  12. Oct 15, 2023 at 11:57 AM
    01 dhrracer
    Still Shopping
    Air is not scary it is the landing when things go so wrong.
  13. Oct 15, 2023 at 12:01 PM
    desertjunkie760
    Shane
    Check My Sig.
    At the least having the proper suspension and a boxed frame. A cage would be ideal but I underStand not doing one right away.
    2.0s front/rear are not adequate for big sends. The frame is going to take a lot of that load.
  14. Oct 15, 2023 at 2:54 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    I’ll add, the JD frame braces help a lot with stability in the rear. I was worried about it because my frame isn’t boxed or caged. Would still prefer to have those as well now that I have travel to tune with, but pleased with it so far.
  15. Oct 15, 2023 at 4:37 PM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    The JD fab frame brace is a box kit, right? I suppose it's not a full but it hits everywhere important in the rear and turns the C-channel in that area into a box.
  16. Oct 15, 2023 at 4:41 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  17. Oct 15, 2023 at 4:42 PM
    cowfootball
    2022 TRD OR
    Yeah, that kit boxes the inside of the frame around the shock mount and hangers, per their description:
    > We decided to fix this problem once and for all with a massive 3/16" thick, boxed frame brace kit.
    I assume it's a pretty good bang for buck to box that specific segment of the frame.
    Unless they're just describing that brace as boxed, I guess. JD used to sell a frame box kit for the 2nd gen I think but I can't find it on their site anymore.
  18. Oct 15, 2023 at 4:48 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    This is also an alternative
    https://dmzfab.com/product/2005-tacoma-frame-boxing-kit/
  19. Oct 15, 2023 at 4:52 PM
    cowfootball
    2022 TRD OR
  20. Oct 15, 2023 at 4:57 PM
    desertjunkie760
    Shane
    Check My Sig.
    The frame brace doesn’t box the frame. It reinforces it in problem areas that a boxed frame wouldn’t even fully address. The brace itself is boxed with 3/16” plate.
    One could argue that it’s more effective at reducing frame flex than a boxed frame but I haven’t seen any load force comparisons.
    JD does, or did, offer a frame boxing kit that incorporated their auxiliary fuel tank. I’m not sure if you could purchase separately.
    cowfootball[QUOTED] likes this.
