Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Nov 3, 2023 at 7:00 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Haha, most of my local buddies drive jeeps with tons and 40’s, or the 4800 car lol. Few years ago we drove 800mi each way to the rubicon, drove the trail and drove home. It does “moderate” crawling trails amazing
    IvanhoeTaco[QUOTED] likes this.
  2. Nov 3, 2023 at 7:53 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Your rear setup is custom correct?
  3. Nov 3, 2023 at 11:32 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    I’m sure he’ll correct me if I’m wrong, but Ryan’s setup started life as a DMZ kit, still uses the springs I believe, and then he redid the rear mount with a large flipped shackle arrangement. Definitely works well from what I saw at Cinder hills :thumbsup:
    MI-FLoffroader likes this.
  4. Nov 4, 2023 at 7:37 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Correct
    Nailed it
  5. Nov 4, 2023 at 3:59 PM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    I have that. Archive hangers and shock relocate with Deaver stock location spring under springs U644. Pulls a lil over 12in travel, maybe more once i change my bump setup. Works really good. I would do an inverted shackle if i could start over (probably will eventually)
  6. Nov 4, 2023 at 4:02 PM
    IvanhoeTaco
    Eastern NC
    Finally somone running it...any cons? Hows your ride height? How are those springs? I never carry any substantial weight and never tow, i dont even have a hitch.
  7. Nov 4, 2023 at 4:29 PM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Springs are too short and the ride is harsh @RonRon23
  8. Nov 4, 2023 at 5:23 PM
    IvanhoeTaco
    Eastern NC
    Even with a light duty spring?
  9. Nov 4, 2023 at 8:05 PM
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    What do you intend to use the truck for primarily? We established that full long travel spring under trucks can still wheel if you’re trying to build a “best of both worlds” rig. I researched mid travel SUA for about a year which led me to the conclusion that the ride quality and performance doesn’t justify the cost of upgrading from mid travel SOA.
    Aside from cost, I found the biggest negative to be that the stock location spring under pack options are limited and not that great. Probably due to the spring length of the stock location? The lighter duty springs tend to sit flat. Deaver has the U539/540 HD that I’ve heard are harsh and have mixed reviews at best (not much arch or travel). I’m sure there are other options that work, but you have to know what you’re doing when setting them up because most of them are longer springs. At that point, I found it more reasonable to buy a kit that already locates new spring locations and cycles clean travel.
    For cost, the DMZ and dirt king kits are impressive. There’s also the camburg kit, but a couple members have had issues with it eating bushings. I’m happy with my JD kit for how versatile it is, and I still get to keep my bed.
  10. Nov 4, 2023 at 10:49 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    I was really happy with my 539/540’s when I had a 2” kit but once I did my 3.5” and really started pushing the truck it just wasn’t enough.
  11. Nov 4, 2023 at 11:34 PM
    not_nick
    It's good for what it is. And good for the terrain on all the east coast i've come across so far (run out of space/power about the same time i run out of suspension usually). I'll second trekker that they're a bit harsh and the standard shackle travel is kinda an odd path. Like can't quite get that 'feels like nothing is there' feeling even with my shocks fairly dialed in. I run the springs with the very bottom leaf pulled and that puts me right at 6 up 6 down currently but it's just a tad too much spring for my trucks weight. Though my truck is very light so that's probably more of a specific issue with mine.
    I mainly went this route because it worked out better for me to piece it together one piece at a time and this is still plenty for my use so far
  12. Nov 5, 2023 at 3:06 AM
    IvanhoeTaco
    Eastern NC
    The fact there are only 2 companies that even offer any sort of mid travel SUA says alot. The geometry of having a spring under the axle and keeping it under the frame rails always confused me.
    I will stop asking questions I already know the answers to lol
  13. Nov 5, 2023 at 8:19 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    They do fine, at least my JD rear works(HD Leafs) very well, I was on the fence if it would still take us over our typical trails but last outting it was rather surprising how well it worked, trail was moderately difficult with some pretty deep rutts and rock section.
  14. Nov 5, 2023 at 2:58 PM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    I had archive sua with 539/540s. It was fine for running along with oem front. Loved weight, but unloaded was harsh for me. Never went light duty springs so I couldn’t say. Once I had the +4 up front and tried to push that, it was just no fun with the rear being unable to keep up.
    Camazon and IvanhoeTaco like this.
  15. Nov 5, 2023 at 11:42 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    https://www.instagram.com/p/CsuVVBgJVO7/
    Here's my buddy Travis wheeling his JD Sua + 2.25 kit on a local trail that's pretty gnarly. Pretty sure he's the first ifs truck to do it no winching.
    Check the third clip in the sequence. He has other moments from that trail on his ig page.
  16. Nov 6, 2023 at 5:39 AM
    IvanhoeTaco
    Eastern NC
    Damn. That left rear wheel just sucks up in there so cleanly.
    YotaFAB and JasonT87 like this.
  17. Nov 6, 2023 at 8:07 AM
    SoCaltaco65
    Love how the videos shows the passenger side shackle and leaf are on the log/pole and still able to move. This is exactly why I went JD fabs rear, no shackle hanger sticking down to hang up on.
  18. Nov 6, 2023 at 9:09 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Damn ya'll are making me wanna go spring under.
    Even with MT front and a built out rear with alcan leafs and valved 2.0s, it's not totally copasetic.
  19. Nov 6, 2023 at 9:42 AM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Less axel wrap on SUA too
    SoCaltaco65 likes this.
  20. Nov 6, 2023 at 9:43 AM
    betterbuckleup
    Ian
    Concord, CA
    I don't really have any axle wrap issues, but then again I should put a gopro back there and actually check out what's going on under load.
