Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Dec 16, 2023 at 9:33 PM
    Pittsy
    Pittsy Ex car guy, currently in rehab
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    Ditto
  2. Dec 16, 2023 at 10:24 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Best thing to do is shorten the stroke to 1". I shortened mine with my LT setup and ran around 150psi, but rarely noticed hitting them
    2" bumps off the LCA don't really work well on these trucks
    Edit: if you don't want to shorten them, I'd try around 80psi, because the pressure ramps up considerably in a short space
  3. Dec 17, 2023 at 7:00 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    This is what I would suggest as well. I’d go as far as to say shorten to 1” and drop pressure but definitely at least do one of them.
    Sterling_vH111 likes this.
  4. Dec 17, 2023 at 7:03 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    x3 this
  5. Dec 17, 2023 at 7:27 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Cool, thanks guys.
    I think I’ll try dropping the pressure to 100 right now, and see how that goes.
    Shorten then if I still don’t like it !
  6. Dec 17, 2023 at 8:34 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    I still have mine at 2” stroke but have them mounted pretty far out, just upped the pressure to 185 from 150. Makes up for no shock tuning lol, will eventually tune shocks and de stroke the bumps.
  7. Dec 17, 2023 at 10:00 AM
    desertjunkie760
    Shane
    Check My Sig.
    The high motion ratio of an IFS makes this a common topic. Typically bumps are mounted pretty far inboard on the arm so they engage way to early. I prefer to shorten them so they engage in the last few inches of wheel travel.
  8. Dec 17, 2023 at 10:45 AM
    JTFisherman
    JTFisherman Well-Known Member
    Jake
    Texas / Missouri
    4Runner
    On the topic of shortening bumps, any suggestions on the best way to get the retaining clip that holds the seal cap in place in and out when the stroke is shortened?
    I had a hell of a time having room to get it in place with about a 1.2" stroke and have no idea how I'll get it back out when I want to open them again. It was super tight between the wiper cap and body to reach in with the clip when the seal cap pushed down to get the clip in place.
    Is there a way to remove the shaft end that I might be missing?
  9. Dec 18, 2023 at 7:25 AM
    desertjunkie760
    Shane
    Check My Sig.
    It takes finesse and it's not necessarily easy. I have found that it's helps to purge the trapped air multiple times throughout the process.
    JTFisherman[QUOTED] likes this.
  10. Dec 18, 2023 at 7:40 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Anyone have a part number for the King spacer to destroke from 2" to 1"? What about oil volume recommendations, for the 2" compact bumps specifically?
  11. Dec 18, 2023 at 8:38 AM
    desertjunkie760
    Shane
    Check My Sig.
    King uses an aluminum spacer on their bumps that takes up more volume. Not sure of the PN.
    Fox used to use a steel spacer that would take up less volume. Might make shortening the bump easier. PN 233-00-046-B.
  12. Dec 18, 2023 at 9:29 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Thanks, any idea on oil volume?
  13. Dec 18, 2023 at 9:32 AM
    desertjunkie760
    Shane
    Check My Sig.
    Unfortunately no. Volume will change depending on what spacer you use.
  14. Dec 18, 2023 at 4:59 PM
    WormSquirts
    Braeden
    BC
    I just used a piece of scrap steel tube I had and cut to length. I believe it was 1.5x.180 tube, but I could be wrong. for oil volume, just add enough that it doesn't hydraulic lock at full bump and thats all you need to do. they are just emulsion shocks basically, so you can fill it with oil, put it all together, then remove the valve core and just compress the bump all the way, and that should leave you with the exact right amount of fluid inside. Just don't look down the hole when you compress the bump or you'll get an eye full of oil.
  15. Dec 18, 2023 at 5:14 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Thanks, thats kinda what I figured was involved but thought there might be some more scientific way to do it!
  16. Dec 18, 2023 at 7:00 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    5 years in with a piece of pvc for my limiting spacer. Haha. But good advice on the oil level.
  17. Dec 18, 2023 at 7:46 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You sound like you speak from experience.
    JasonT87 and WormSquirts[QUOTED] like this.
  18. Dec 18, 2023 at 8:03 PM
    WormSquirts
    Braeden
    BC
    The oil can shoot surprisingly high! (If your face isn't in the way)
    EatSleepTacos[QUOTED] likes this.
  19. Dec 18, 2023 at 9:25 PM
    JTFisherman
    Jake
    Texas / Missouri
    4Runner
    I have 1.5 120 wall limiting mine it is pretty tight to the shaft.
    The first time I was trying to purge air out of a shock after opening it the bleed holes shot oil right in my eyes and that stuff stings. Now I understand why people cover them when cycling the air from under the piston haha
  20. Dec 19, 2023 at 1:38 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Looking for some measurements from SUA guys running either H70 or H70HD, if you could help it would be appreciated!
    looking for center of front leaf bolt to center of shackle hanger pivot bolt.
    thank you!
