Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jan 23, 2024 at 1:36 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Did you call Evan Weller racing though?
  2. Jan 23, 2024 at 2:19 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    yes, lower links are intentionally very close to the u-joints at the carrier bearing side, and the axle ends are just in front of the vertical axle centerline. so any plunge concerns would likely be pinion angle shift related, vs the axle traveling with a varying radius relative to the u-joints.
    . current calcs show about 2.3 degrees pinion change between full bump and drop. id be thrilled if all i had to do to the driveshaft is weld in a longer slip yoke and reballance, but i may not even have to do that if its anywhere near your plunge number.
  3. Jan 23, 2024 at 3:12 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    left a message
    Caboose117[QUOTED] likes this.
  4. Jan 23, 2024 at 4:15 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    You won’t find others.
    But if I were in your shoes and wanted it to be a budget. 9” would not be that. I would be center mounting a GM 9.25 front diff.
  5. Jan 23, 2024 at 4:35 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    This is my plan exactly
    Out of an 07 Sub
  6. Jan 23, 2024 at 4:46 PM
    WormSquirts
    Braeden
    BC
    heard back from evan weller. They said you either run high pinion, or run on the coast side, and he would recommend running a 10" ring gear on the coast side.
    I think I'm gunna go back to my original plan of narrowing a tundra diff. They are just really hard to find and pretty expensive up here where I am. The 9.25 was also an option that I was looking for.
  7. Jan 23, 2024 at 5:04 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    https://www.tacomaworld.com/threads/04-tacoma-turned-buggy.165208/page-11#post-24125012
    https://www.tacomaworld.com/threads/1st-gen-long-travel-discussions.750980/page-11#post-29463458
    JTFisherman likes this.
  8. Jan 23, 2024 at 6:40 PM
    WormSquirts
    Braeden
    BC
    Dalandser[QUOTED] likes this.
  9. Jan 23, 2024 at 9:26 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    If you need me to bring one up in feb i probably can
  10. Jan 23, 2024 at 10:27 PM
    WormSquirts
    Braeden
    BC
    I'll let you know for sure. Would be sick
  11. Jan 24, 2024 at 2:51 AM
    906taco
    Cory
    08 Taco
    Tundra diff isn’t nearly as strong as the 9.25. Don’t really see why it would even be entertained. You can get a used 9.25 for a couple hundred bucks. Might have 3k in the entire setup all said and done. Pretty common swap for people that want to center mount.
  12. Jan 24, 2024 at 5:45 AM
    Adventure4x4
    Adventure4x4 Well-Known Member
    Adam
    San Antonio, TX
    2013 TRD off road MT
    That's true as far as strength. All depends on what people's end in mind is. Since my whole front end will essentially be tundra component parts, it works well for me as far as reducing complexity. Plus, I only paid 150 for my tundra front diff. I won't be center mounting though either.
    Camazon likes this.
  13. Jan 24, 2024 at 8:37 AM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
  14. Jan 24, 2024 at 8:53 AM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
  15. Jan 24, 2024 at 12:59 PM
    WormSquirts
    Braeden
    BC
    TacoEspecial[QUOTED] likes this.
  16. Jan 24, 2024 at 2:14 PM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    Sequoia runs the same shit and nobody is lookin for spare parts for those :hattip: and has irs so you got double the chances of getting a diff
  17. Jan 24, 2024 at 4:28 PM
    906taco
    Cory
    08 Taco
    Just get a passenger drop t-case. Though, I’ve never seen a small D60 housing. I still vote GM 9.25. About the only way you’re getting out of this without dropping 15-20k into a diff, gears, axles and driveshaft. Plus, 934 stubs are already available for them.
  18. Jan 24, 2024 at 5:18 PM
    WormSquirts
    Braeden
    BC
    Already have the driver drop atlas.
    I think our used market up here just kinda sucks. It's hard to find stuff.
    Caboose117 likes this.
  19. Jan 24, 2024 at 5:53 PM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    WormSquirts likes this.
  20. Jan 24, 2024 at 5:55 PM
    soggyBottom
    soggyBottom Well-Known Member
    What about heat treatment? Is there any benefits of using chromolly in an annealed form over mild steel?
