Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Apr 4, 2024 at 9:10 PM
    Pittsy
    Pittsy Ex car guy, currently in rehab
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    Just ordered a complete tundra booster and MC, new lines, adapters, everything. We'll see where that gets me. Hopefully further than I was before. Still don’t have a trans though.
    Dalandser[QUOTED] likes this.
  2. Apr 4, 2024 at 9:21 PM
    mauctopa
    mauctopa Well-Known Member
    Roger.
  3. Apr 4, 2024 at 10:12 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    what was the time quote on the 4l80?
  4. Apr 5, 2024 at 2:33 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Modern brake systems see upwards of 3,000psi under hard braking. Not sure why they would tell you no more than 1200. I’ve always been taught that’s the absolute minimum.
  5. Apr 5, 2024 at 5:32 AM
    Pittsy
    AZ
    Original quote was 6-8 weeks, then they called me 3 days later and told me 4 weeks, which means next week it should be done supposedly
    tacotunner06[QUOTED] likes this.
  6. Apr 5, 2024 at 9:12 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Here is where my cheap, non-baller mind is taking me for better braking since I can't drop $2k on brakes. Referencing the thread below replace the brake master and booster with the Tundra unit. Remove the abs module/ecu and replace with two T's and a proportioning valve for the rear. Replace the front brake pads with 4Runner pads (I may actually have 4R pads anyway) and next time I need rotors install 4R rotors if they clear 16" wheels.
    Am I on track here?
    https://www.tacomaworld.com/threads/my-2006-tacoma-brake-upgrade-edited.652471/
    Sterling_vH111 likes this.
  7. Apr 5, 2024 at 9:27 AM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    I've seen it on a few trucks now, how are people fitting 16" shocks on just a relocation like archive or something? Do they just sacrifice all up travel for more droop?
  8. Apr 5, 2024 at 9:39 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    To add to the brake talks… I’ve got wilwood front 6 piston brakes. And the wilwood rear brakes that JDfab puts on their ford 9 axle. I put in a tundra booster along with the sequoia master. Eliminated the abs and cobbled it all together with a proportioning valve from wilwood in the original ABS module location. It’s not pretty but it works. I also separated the abs module in half to keep the ABS computer since I needed it to be able to keep my speedometer working. The braking is way better than stock with good pedal feel.
  9. Apr 5, 2024 at 9:42 AM
    VikingForge
    VikingForge Well-Known Member
    First Gen
    Uniballs are pretty stiff when new. I've put about 4k miles on a +2 TC kit recently, initially steering was really stiff, and it took effort to keep from overshooting small steering corrections early on, especially at freeway speed, but it has gradually improved over the past 500 miles. Not to say that your alignment doesn't have something to do with it, but you also may just need to wear the components in a little bit.
    Bentrodder likes this.
  10. Apr 5, 2024 at 9:59 AM
    Y2kbaja
    Sacramento
    Total Chaos
    you're not running a Toyota TC, correct? To add to the above about the speedo working I added a Toyota speed sensor to the TC and wired straight to the speedometer. No wheel sensors needed, speedo works great.
    Bandido and FishingInSand like this.
  11. Apr 5, 2024 at 10:45 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I believe most of those relocation kits use a 14" or 12" shock. Not 16". I don't think you're fitting 16" without cutting the bed.
    FishingInSand[QUOTED] likes this.
  12. Apr 5, 2024 at 10:47 AM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    I went 12" after talking to Archive, because 14" will limit your uptravel with most leafpacks. For 16", I think you need to use a different mounting solution and have to cut into your wheel wells.
  13. Apr 5, 2024 at 10:56 AM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    That's what I thought too but now I've seen it and I can't figure out how it's possible. I'll track down the rig I saw
  14. Apr 5, 2024 at 11:55 AM
    906taco
    Cory
    08 Taco
    It’s possible if you cut into the bed or limit travel. Or hang the shock mounts stupid low. Either way, 14” is all you need. SOA packs aren’t going to use all of a 16” regardless
  15. Apr 5, 2024 at 12:09 PM
    Pittsy
    AZ
    If I wasn’t about to buy a Holley dash I’d do this
  16. Apr 5, 2024 at 1:07 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    I’m 2wd
    Y2kbaja[QUOTED] likes this.
  17. Apr 5, 2024 at 1:24 PM
    MI-FLoffroader
    MI-FLoffroader Brett
    Brett
    Merritt Island, FL
    12' T4R LE/2003 SR5 SPORT V8/1988 DLX 22RE AUTO
    2012 T4R LE -Shoreline Blue Pearl 2003 T4R SR5 Sport V8 -Stratosphere Mica
    4Runners 2010 and up 5th gens are larger rotors and will not clear 16" rims in the OEM configuration. The 2003 - 2009 4th gens had a Sport version that also had the larger rotors w 17" rims. I believe all the rest of the 4th gens had 16" rims.
  18. Apr 5, 2024 at 2:07 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    you don’t have abs right ? because without the abs getting individual wheel speed sensor info it can’t work properly ? will that work on an auto trans too ?
  19. Apr 5, 2024 at 2:10 PM
    Y2kbaja
    Sacramento
    Total Chaos
    My ABS sensors crapped out one at a time, usually the wires breaking off from stuff. I never ran with abs anyway as it's a sure way to crash off road. But once the 3rd abs stopped working the speedo also stopped working. I found the this work around with the speed sensor on the TC case. My truck is a prerunner auto converted to 4x4 with an FJ trans and TC.
  20. Apr 5, 2024 at 2:18 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Figure this might get more traction in here.
    3rd gen Tacoma. Wicked creations long travel +3.5 with their axles. Locked offroad coilovers.
    I have to jack up the lower control arm a little to get the spindle bolted in. From their pictures and how their model is the limit strap is placed flush with the top of the frame on the bulge just behind the factory bump stop mount. At full drop not strapped the cv is at an extreme angle and binding. I called wicked creations and they said everything should be good but they don’t know why the axle is binding. They passed the phone to an installer and he said to get the strap in I have to lower the truck off the lift and then bolt it in.
    I know I didn’t have to do that with jd or the tc kits I’ve installed. Something seems off and they were no help
