Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Apr 11, 2024 at 2:32 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Curiosity question, what was the culprit to your wandering issue?
    Y2kbaja likes this.
  2. Apr 11, 2024 at 3:12 PM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Mine was a bent rear housing.
    906taco[QUOTED] likes this.
  3. Apr 11, 2024 at 3:37 PM
    Anteupp
    Anteupp Mega Member
    I think it was a broken leaf center pin, when my pin broke my truck had some the same symptoms but only when getting on the throttle and letting off. Give gas and the truck would load up and want to push me into the right lane, let off at speed and the truck would settle back down to the driverside.
    SoonToBeOn39s likes this.
  4. Apr 11, 2024 at 3:39 PM
    906taco
    Cory
    08 Taco
    That was my assumption the whole time as well. Just never heard back what it ended up being.
  5. Apr 11, 2024 at 4:05 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Agreed as I’m setting aside cash for a replacement pack because I’m too poor to switch to links
  6. Apr 11, 2024 at 4:13 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Shackle uniballs , and very tight rack, inner and outter plus new( UCA/LCA) uniballs in the front( all replaced at once). once those got broken in and the new rear shackle uniballs the truck has been amazing.
    basically when you corrected say to the left...it stayed left and had to be physically correct by the driver.
  7. Apr 11, 2024 at 4:16 PM
    SoCaltaco65
    The center pin was not broken, moved slightly but was intact
  8. Apr 11, 2024 at 4:22 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Your truck is nearly back-halved already isn't it? With all the work you've done to the rear portion, I'm surprised you haven't switched. But perhaps that's because your out using the the truck versus having it down for months of install. Plus costs lol.
    Links seem like a full send in-and-of themselves. Don't really see anyone half-assing a linked build. ...Unless that's the reason some of us have gone leafs because we can't send it all the way for links :rofl:
  9. Apr 11, 2024 at 4:23 PM
    906taco
    Cory
    08 Taco
    Honestly never would have guessed shackles causing that. Glad it’s fixed either way!
    SoCaltaco65[QUOTED] likes this.
  10. Apr 11, 2024 at 4:24 PM
    Anteupp
    Anteupp Mega Member
    Links are for chains anyway! everyone knows leaf springs party harder
    Naveronski and SoonToBeOn39s like this.
  11. Apr 11, 2024 at 4:48 PM
    SoCaltaco65
    I posted in this thread a video of them clunking and moving alot, you commented it was the uniballs in the shackles
  12. Apr 11, 2024 at 4:54 PM
    906taco
    Cory
    08 Taco
    I probably did. Just didn’t think it would cause rear steer issues I guess. Makes some sense though
    FishingInSand likes this.
  13. Apr 11, 2024 at 5:02 PM
    SoCaltaco65
    if you think about it, the shackle moving a lot laterally coupled with a tight front end that wont center on its own would do what my issues were. Once the shackles were fixed the darting stopped but the drifting all over the road continued until my first dirt trip.
    Now down the road even with the alignment off just a touch I can drive with 2 fingers at hwy speeds.
  14. Apr 11, 2024 at 5:58 PM
    906taco
    Cory
    08 Taco
    Makes me wonder if the fresh uniballs were just that tight or? I know one of mine I had to make a new crush sleeve. Would tighten the bolt and the shackle was almost impossible to move. Had a buddy cut one a few thousandths longer.
  15. Apr 11, 2024 at 6:21 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Are you guys torqueing that Upper 3/4" Bolt the +200ft.lbs according to the bolt torque charts? I did mine at 200ftlbs plus another 45° with Blue Threadlocker
  16. Apr 11, 2024 at 6:42 PM
    SoCaltaco65
    the bolt for the shackle to hanger? I tighten mine to "I dont want it to loosen up while driving in the desert". I use the biggest wrench I could find and a breaker bar and go crazy.
  17. Apr 11, 2024 at 8:09 PM
    Pittsy
    Pittsy AKA LS6Taco - Ex car guy, current truck guy.
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Stroker Swap - LS6Taco
    Ive been driving my wife's raptor a bit, and it really makes me think this. Imagine I did what I did to my tacoma, but to a raptor. Im not saying performance is all that much better, im sure the tacoma would still probably do some things better (cheaper, lighter, V8), but it would be nice to be prerunning with AC seats, and looking so much cooler while doing it.
    That being said, im still really happy with my truck minus the whole 3 motors and 3 transmissions thing
    Sterling_vH111 and SoonToBeOn39s like this.
  18. Apr 11, 2024 at 8:25 PM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    If my truck ever gets totaled by someone else, im getting a raptor.
    I could've bought a pretty clean 1gen raptor for how much I bought my truck brand new for.
    1st Gen raptors with the 6.2 and a 2nd gen front clip has my name written all over it haha
    YotaFAB and Caboose117 like this.
  19. Apr 11, 2024 at 8:28 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Let me give you context that gives you the true difference between WHY you’d pick the full size truck over a Tacoma.
    Center mount
    other than that, the taco is fine
    Cause if you do to your raptor what you do to your taco
    You’ll be even wider than the taco and have the exact same issues from the taco
    But now the fix is a premium because the person working on it is now working on a premium truck
    Ie 30k truck
    80k truck
    Aside from that
    Linking a taco is fun if you hate money
    But otherwise it will never perform the same as a full size chassis even with matching tires, motor and wheelbase because to make a taco do full size shit
    You would be stuck to a 2 MAYYYYYBE 3 seater max
    And the compromises would be endless
  20. Apr 11, 2024 at 8:31 PM
    Pittsy
    AZ
    Idk man, I’m sitting in the raptor right now and the interior is super nice. And big. And my mirrors fold. And I have memory seats, electronic power steering, lockers, adaptive cruise with lane assist.
    I wonder how all those systems would act with a full LT setup lol. Wonder if it could still drive itself.
