Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. May 21, 2024 at 8:53 AM
    Pittsy
    Pittsy AKA LS6Taco - Ex car guy, current truck guy.
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Stroker Swap - LS6Taco
    Chipotle fucks
  2. May 21, 2024 at 9:02 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Good god.....Indeed,
    My Built Rights have been on my Taco since 2012 only rust is where I smacked or drug them over rocks. And its minimal.
    SoonToBeOn39s likes this.
  3. May 21, 2024 at 9:46 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Who made/coated these arms?
  4. May 21, 2024 at 10:19 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    This guy
  5. May 21, 2024 at 11:06 AM
    YotaFAB
    YotaFAB Well-Known Member
  6. May 21, 2024 at 11:10 AM
    dwphoto
    dwphoto Well-Known Member
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    Doing a fundraiser Raffle for Brandon Sloan/Sloan Motorsports.
    Raffling off a recovery kit and a offroad trash bag.
    100% of proceeds go to Brandon and his family.
    https://www.instagram.com/p/C7OA686uErx/
  7. May 21, 2024 at 3:35 PM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    Not bad for a buncha amateurs
  8. May 21, 2024 at 3:40 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
    Picked up my truck from JD this morning. Howe TC kit, SUA and frame brace, 2x bed boxes, Auxillary 25gal fuel tank and relocated Battery and ARB compressor to the new JD bed boxes. Work in progress but making great progress thanks to JD. All the Bling!
    HoweTC.jpgHoweTC1.jpg BedBox2.jpg BedBox5.jpg BedBox4.jpg BedBox6.jpg JDFUELTANK6.jpg JDFUELTANK5.jpg JDFUELTANK4.jpg JDFUELCAP1.jpg JDFUELTANK2.jpg JDLT.jpg
    Squatting a little extra due to all the take off parts in the bed. Will probably need to adjust rear ride height auxiliary fuel tank only has about 13 gallons in it. Will be making the tough decision of getting rid of the rack and tent as well as the swingout. Bed mount the spare and back to ground tenting.
  9. May 21, 2024 at 4:01 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    why are you going to ditch the rack and tent ? if you use it keep it , adjust your springs to handle it all
    MonkeyProof and TWTaco[QUOTED] like this.
  10. May 21, 2024 at 4:06 PM
    SoonToBeOn39s
    Ahh so you're the one with the truck that I've been geekin over Everytime jd posts on insta
    JasonT87, YotaFAB and TWTaco[QUOTED] like this.
  11. May 21, 2024 at 4:10 PM
    TWTaco
    Dave
    I haven't decided on it yet. I'm more concerned with the spare tire (100+lbs) on the swingout. Hitting any bumps at higher speeds it's bouncing really bad.
  12. May 21, 2024 at 4:10 PM
    TWTaco
    Dave
    Yeah that's me! :rofl:
    SoonToBeOn39s[QUOTED] likes this.
  13. May 21, 2024 at 5:09 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I carry my 2nd Spare in the Bed. Soon Ill be making a cargo cage/rack thingy of sorts that will be above the spare which will be near the dimensions for a couple of ActionPacker boxes. That will add the space lost from the spare while keeping CoG as low as possible. Maybe something to consider as an alternative to having a spare on a swing out bumper.
    TWTaco[QUOTED] and essjay like this.
  14. May 21, 2024 at 5:13 PM
    Pittsy
    AZ
    I’ve really been wanting the JD fuel cell deal but like my bed would be such a massive pain in the ass to remove. I wish they’d make it in such a way where it could be installed from underneath.
  15. May 21, 2024 at 5:25 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Cuánto cuesta? I've been thinking about doing rear-mounted batteries and an aux tank.
    TWTaco[QUOTED] likes this.
  16. May 21, 2024 at 6:03 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Yeah all that weight far out back will have a negative effect on your handling as well. You could most likely keep all the gear, but just adjust the weight location to be over the axle instead of that far behind it. I liked the utility of the swingout when I had one, but even on SOA it made the truck drive sort of like a boat. That being said, I say embrace the way of the Prelander!
    Naveronski and TWTaco[QUOTED] like this.
  17. May 21, 2024 at 8:56 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Am I seeing that you have to fill fuel from inside the bed? Seems like a pain, no?
  18. May 21, 2024 at 9:16 PM
    TWTaco
    Dave
    No it's not bad at all. I thought the same thing at first but its fairly easy.
    Naveronski[QUOTED] likes this.
  19. May 21, 2024 at 10:23 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Is this tank hooked up to feed your oem tank or is it a standalone tank that replaced the oem?
    I understand that the kit can be both
  20. May 21, 2024 at 10:37 PM
    TWTaco
    Dave
    It feeds the stock tank. What's great is you can transfer fuel on the fly.
