Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. May 24, 2024 at 9:56 AM
    TWTaco
    TWTaco Well-Known Member
    Dave
    New motor swap I see coming behind your truck??
  2. May 24, 2024 at 9:57 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    :fingerscrossed:
    SoonToBeOn39s[QUOTED] likes this.
  3. May 24, 2024 at 9:59 AM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    Sorry guys I can't get over the finished product :)
  4. May 24, 2024 at 10:04 AM
    SoCaltaco65
    I foresee an LS mating soon....
    :anonymous:
  5. May 24, 2024 at 10:04 AM
    TWTaco
    Dave
    Those sure look pretty.
  6. May 24, 2024 at 10:06 AM
    SoCaltaco65
    Hey now no spooning with them....
  7. May 24, 2024 at 10:09 AM
    SoonToBeOn39s
    Im not sure I can reframe :rofl:
    SoCaltaco65[QUOTED] likes this.
  8. May 24, 2024 at 10:10 AM
    SoCaltaco65
    Hahaha
  9. May 24, 2024 at 10:18 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    It’s a plastic mock up block……
    Totally not a spec LS3….
  10. May 24, 2024 at 10:19 AM
    SoCaltaco65
    :spy:
    906taco[QUOTED] likes this.
  11. May 24, 2024 at 11:40 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    don’t ruin a toyota with an LS…that’s what god gave us the 2JZ for…
  12. May 24, 2024 at 11:57 AM
    Pittsy
    Pittsy AKA LS6Taco - Ex car guy, current truck guy.
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Stroker Swap - LS6Taco
    Tbh the hardest thing I’ve ever done to a car. It doesn’t help I made it harder on myself by using a fucked engine and a fucked trans. And also the inability to fabricate anything.
    it’ll probably be a breeze for you. :rofl:
  13. May 24, 2024 at 12:06 PM
    906taco
    Cory
    08 Taco
    It could be for that thing parked behind it too. Just know. I’m enjoying the thing for a while. Engine swap is far out!
    TWTaco likes this.
  14. May 24, 2024 at 12:08 PM
    906taco
    Cory
    08 Taco
    I mean, you should still be proud to pull it off!
    TWTaco likes this.
  15. May 24, 2024 at 12:11 PM
    SoCaltaco65
    1uz...
    Supra4x4 likes this.
  16. May 24, 2024 at 12:14 PM
    906taco
    Cory
    08 Taco
    To be honest. 2UR is still a thought.
    However. I’m trying to look at things from a business standpoint too. Not many are going to spend the coin for 2ur. But. An LS swap kit would be pretty tempting for many I feel. Bolt in crossmember, mounts etc….
  17. May 24, 2024 at 12:19 PM
    SoCaltaco65
  18. May 24, 2024 at 12:22 PM
    906taco
    Cory
    08 Taco
    No doubt. But you need to build the hell out of them to make power. 2UR is 472hp in factory form. Or 5500$ buys you a 525hp LS3 long block direct from GM performance.
    tacotunner06 likes this.
  19. May 24, 2024 at 12:24 PM
    SoCaltaco65
    I understand owning a few Vettes, but keeping with the "Toyota" theme.
  20. May 24, 2024 at 12:28 PM
    906taco
    Cory
    08 Taco
    At this point in a build. It’s kinda mundane to spend 10’s of thousands to make a motor work. 1UZ would take thousands of dollars just to adapt a 4x4 trans. Same goes for 2UR. 2UZ has options, but not as many options as the tried and true GM line. Especially considering GM has kept the same bell housing pattern alive from the 50’s all the way to current day. Which makes the support absolutely astronomical.
