Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 28, 2024 at 12:41 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Doesn’t sound horrible. A lot of rasp comes from the Y pipe though. Being unequal length makes for some funky happenings with exhaust pulses. Time will tell what the equal length does.
    From the y pipe collector it will dump into 3” to a resonator then to the muffler. Realistically there shouldn’t be any raspiness to it. It should be a nice pure note.
  2. Jun 28, 2024 at 12:57 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
  3. Jun 28, 2024 at 1:01 PM
    906taco
    Cory
    08 Taco
    TWTaco, Torspd and MadTaco461[QUOTED] like this.
  4. Jun 28, 2024 at 1:11 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This is what I am talking about! It's going to be extremely rewarding when you get to fire it up for the first time and hear that and all of its excellence.
    906taco[QUOTED] likes this.
  5. Jun 28, 2024 at 1:24 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    WTF the word boost is mentioned and you mysteriously appear :anonymous::rofl:
    Torspd[QUOTED] and YotaFAB like this.
  6. Jun 28, 2024 at 2:12 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    today was very fulfilling. got the 4-link mocked up with PVC and the link locations (frame side) mocked up with some scrap tubing tacked into place. The hours of measuring, spreadsheets, and math paid off, and the suspension cycled exactly as planned on the first try. I trusted the math, but wanted to mock up anyway before cutting and drilling the expensive 2''x.25''wall DOM. it also allowed me to test clearance on what remains of the the frame, and confirm what the up and down limiting factors will be.
    at full compression, the limiting factor is the driveshaft contacting the underside of the cab. at full drop, the limit is the driveshaft u-joints (pinion angle is where it should be). there are of course some ways around both of these limits, but i'm hitting my planned travel numbers without them, so no need.
    between both limits, vertical wheel travel is 25''. bumped and strapped, i'll be limiting it down to about 22''. the photos with the tape measure below show 26.25'' from bottom of drum to concrete where i plan to have the bump bottom out, and 4.25'' from bottom of drum to concrete where i plan to have the limit strap stop things (stretch factored in).
    also tested out articulation to make sure there were no link contact issues. vertical separation was adequate. it will articulate more than the photo shows, but i ran out of Jack, and the heat index is 115 degrees here today, so i wasn't feeling rigging up the engine hoist.
    First photo is the truck at ride height, which will be roughly 1'' of lift over stock. strapped and bumped, this yields 12'' of compression and 10 inches of drop. this is with 18'' axle mounted coilovers.
    photos of full bump.
    photo of full (strapped) drop.
    drop and bump measurements.
    articulation. pleased with how little horizontal axle movement/rear steering there is under articulation.
  7. Jun 28, 2024 at 2:26 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    how long are those links ? they look super short ? how much driveshaft plunge are you getting? di you have a slip yolk ?
    Caboose117 likes this.
  8. Jun 28, 2024 at 2:33 PM
    906taco
    Cory
    08 Taco
    That’s what I said too! Within seconds!
  9. Jun 28, 2024 at 2:34 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Lowers are a little over 40". Forget what the uppers are off the top of my head. Just a hair over 1 inch of plunge. Factory slip yoke on the two piece shaft.
  10. Jun 28, 2024 at 2:35 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    yeah i wouldn’t risk saying torspd 3x or you might have a random texan standing in your living room :eek:
    JTFisherman and Torspd like this.
  11. Jun 28, 2024 at 2:41 PM
    906taco
    Cory
    08 Taco
    :rofl: I have beer!
  12. Jun 28, 2024 at 2:46 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    ill bring Brisquette....
  13. Jun 28, 2024 at 2:52 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    a whaaaat ? you just committed a smoked meat crime…
  14. Jun 28, 2024 at 3:00 PM
    SoCaltaco65
  15. Jun 28, 2024 at 3:02 PM
    906taco
    Cory
    08 Taco
    1000% just banned yourself. How dare you disgrace one of the best smoked hunks of glory in existence.
  16. Jun 28, 2024 at 3:03 PM
    SoCaltaco65
  17. Jun 28, 2024 at 3:04 PM
    SoCaltaco65
    :pout:
  18. Jun 28, 2024 at 4:37 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    SoonToBeOn39s likes this.
  19. Jun 28, 2024 at 4:41 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Boosty sense
    colinb17 likes this.
  20. Jun 28, 2024 at 7:17 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Found another one
    5CED1301-7609-4BC3-9AF3-59DC30605EB3.jpg 3B5ACE2E-589E-4A1F-A08D-192188E09452.jpg
    Torspd, YotaFAB and SoonToBeOn39s like this.
