Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 29, 2024 at 11:56 AM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Catch cans are dumb
    Vacuum is dumb
    AN fittings are dumb
    That is all
    Good day
  2. Jul 29, 2024 at 12:18 PM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Brown and Miller crimped hoses all day long.
  3. Jul 29, 2024 at 12:21 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Can had too many vacuum lines coming in
    And the chase to find a leak was driving us all bonkers
    Was making pressures fluctuate all over from day to day and drive to drive
    Massively was effecting power and fuel consumption
    Likely even effected the tuning at time of logging
    mind you, can was set up entirely how manuf instructed.
    the solution:
    Close off completely the intake port and the line from that to the can,
    Idle instantly resolved
    Power band instantly smoothed
    Now just needs a proper log and adjustment
  4. Jul 29, 2024 at 4:03 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    I’m no longer on the JD SUA. But always always cycle. No matter what. This is a step that should not ever be skipped!
  5. Jul 29, 2024 at 9:14 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Nobody said anything about skipping. I was just hoping to reference someone else who’s all knowledgeable like yourself…
    What rear kit are you on now? Why'd you move away for the JD SUA?
    I have a lot of questions being your response was very informative.
  6. Jul 29, 2024 at 9:15 PM
    YotaFAB
    YotaFAB Well-Known Member
    Any one comment on alignment spec for LT Dirt King Heimed upper with KPO octagonal LCA bolts? What specs are you getting ?
    Im at Camber L.6 and R.9 caster 6.7 Toe total .1
  7. Jul 30, 2024 at 2:45 AM
    906taco
    Cory
    08 Taco
    Ok, misunderstood what you meant. Sounded as if you were questioning if it were necessary. But it’s always best.
    I’m now on my own rear kit. Jd just wasn’t for me.
  8. Jul 30, 2024 at 8:47 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    I got mine in about a week, they may have been backordered? Still should have replied to your emails though.
  9. Jul 30, 2024 at 8:50 AM
    906taco
    Cory
    08 Taco
    Wait. You had vacuum running to a vented can? Did I read that right?
  10. Jul 30, 2024 at 1:42 PM
    Pittsy
    Pittsy Ex car guy, currently in rehab
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    Said in stock in their site. Still haven’t heard anything from them, but I filed a chargeback soooo
  11. Jul 30, 2024 at 4:04 PM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    So what's the idea behind people not running duals springs on short coilovers? Seems to be gospel to only run one spring on 10in coilovers or less but i don't see why it wouldn't work the same as with longer coils but just not as well. And i haven't seen any real explanations either
  12. Jul 30, 2024 at 4:06 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Simply not enough space. Stack height for two coils plus the spring separator is too tall for the fully compressed shock, or you would have such a short helper spring that it would be basically pointless.
    Naveronski likes this.
  13. Jul 30, 2024 at 4:10 PM
    desertjunkie760
    Shane
    Check My Sig.
    Spring rates are limited in the lengths that would be required to make it effective.
    IFS setups require a lot of spring due to the motion ratio. There's only a few options out there to get a combined spring rate that will hold the desired ride height.
    SoCaltaco65 and JTFisherman like this.
  14. Jul 30, 2024 at 5:35 PM
    not_nick
    Even with like a 10" and 6" or a 10" and 8" ?
  15. Jul 30, 2024 at 5:39 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    you’re talking about a 16” or 18” shock …your truck only has a 5” up front stock and an 8” with a lt kit
  16. Jul 30, 2024 at 9:26 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
  17. Jul 30, 2024 at 9:56 PM
    not_nick
    ohhhhhh i guess i'm misunderstanding how the spring lengths are listed then
  18. Jul 31, 2024 at 2:51 AM
    906taco
    Cory
    08 Taco
  19. Jul 31, 2024 at 7:20 AM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    If the can doesn’t pull vacuum
    The crank case pressurizes
    the can taps into the PCV that normally goes elsewhere
  20. Jul 31, 2024 at 8:35 AM
    906taco
    Cory
    08 Taco
    You’re not going to pull vacuum from a vented can. You’re simply going to have a massive vacuum leak. Either sealed can (if pulling vacuum is desired) or a vented can with large enough hoses from each valve cover. -10 or -12.
    You do not need to pull vacuum from the crank case to eliminate crank case pressure.
