Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 2, 2024 at 2:43 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Soo weight wise I want to be heavier in the rear or near the same as the front?
  2. Aug 2, 2024 at 3:08 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Depends what you want. A well balanced vehicle will always have better handling characteristics. At your split, I certainly wouldn’t be pursuing more to the rear. Personally. But I like a vehicle I can throw around on and off road.
  3. Aug 2, 2024 at 3:40 PM
    SoCaltaco65
    oh I can throw it around, windy washes and such the truck is a dream, long medium whoops it does fairly good, but over deep whoops and jumps it noses over.
  4. Aug 2, 2024 at 3:43 PM
    906taco
    Cory
    08 Taco
    A lot of it is going to be valving related. With the area you live. I would 1,000% be paying a pro to tune your shocks for you. It will get the majority of things under control. Quickly.
    The reality is, the out of the box valving is nothing more than a “base” to get you somewhat in the ballpark. But I certainly wouldn’t call it close.
  5. Aug 2, 2024 at 3:50 PM
    SoCaltaco65
    I get that, the rear we went one step up per kings chart. the front I left alone with the "total chaos" spec valving, CO I have no idea whats in them.
    Unfortunately I have to wait for cooler weather as the des is blistering hot.
  6. Aug 2, 2024 at 3:54 PM
    906taco
    Cory
    08 Taco
    Changing whole stacks is fine and all. But something I’ve learned (from a pro that I have been blessed with learning from). Is it’s not always a change from say .012 to .015. A lot of my current valving involves say double stacked .012’s or .015’s with certain shims removed entirely with plates etc. Things get a little bit interesting outside of just swapping straight stacks.
  7. Aug 2, 2024 at 4:03 PM
    SoCaltaco65
    yes, we went from standard to Medium Firm and up in thickness on a few in the stack, comp tubes are almost in all the way too. with recent changes I havent had a chance to take videos so I can see the attitude of the truck over terrain, just have the seat of my pants guess...
  8. Aug 2, 2024 at 5:20 PM
    906taco
    Cory
    08 Taco
    You’re probably having issues when you hit the bump zone. That’s the same battle I’ve been fighting. Weight is one solution to that. But there are some others as well. Shoot me a DM on the gram if you want.
  9. Aug 2, 2024 at 10:49 PM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    How fast does the rear go through all it's travel. Sounds like maybe too much spring if you tried more damping but it still bucks too much
    Caboose117 likes this.
  10. Aug 3, 2024 at 7:18 AM
    SoCaltaco65
    I have cranked near all the comp tubes in, I have added a few on rebound, makes no difference, think its time for more comp re-valving, or just wait for cooler weather and hire a tuning company to adjust in the des.
  11. Aug 3, 2024 at 4:10 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Prep for sand hollow at the end of the month underway. Love these jack stands. Can get the truck fully drooped with tires on in the garage finally.
    But on the downside…..
    That used main I threw in before koh didn’t last too long. Starting to be a recurring theme with this truck and busting main leafs. Wouldn’t be an issue with links :crapstorm:
    Springs were starting to sag anyways after about 2 years of abuse. So gonna order up some freshies for this trip and keep this thing going.
  12. Aug 4, 2024 at 4:54 AM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Going to try to explain this the best I can without pictures. I’m cycling 14” smoothies (not coilovers) on my 3G4R. 3 link kit with outboard shock relocation.
    Any time I set up and cycled coilovers, I never let them pass over vertical when looking at them from behind the truck. I heard weird things happen when they do. That’s at full articulation. Question now is the smoothies do pass vertical at full articulation. Full droop side swings over past vertical maybe 6 degrees…not sure if weird things only happen with coilovers or if valving is what gets weird. Also, will it even matter a great deal if that’s true? At the point I’m fully articulated enough to pass vertical I won’t be going more than a few MPH crawling…
  13. Aug 4, 2024 at 7:01 AM
    906taco
    Cory
    08 Taco
    Starting to question if you have more than meets the eye here. Possibly from the anti wrap?
  14. Aug 4, 2024 at 7:45 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    I thought the issue with shocks going over center is the possibility of it not going over center while articulating then most likely it will at minimum break the shock shaft.
  15. Aug 4, 2024 at 8:04 AM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    Fulltime Overlanding
    Long travel house on 35s with a custom aluminum utility bed and FWC
    some welding required
    Pay attention to the motion ratio through stroke of your shocks. If they are constant, amazing, and much easier to tune shocks (also pretty damn hard to package)
    If they trend in one direction without major changes, especially if at jounce they are a better ratio than at rebound, okay to tune. But if the motion ratio goes up and then down through the stroke, it’s gonna be a giant headache to tune.
    Or in simple internet terms, don’t let your leaned shocks go perpendicular and then lean the other direction through the suspension travel. But that’s generalizing a lot. Plus it’s just trigonometry so the longer your links and shocks, the ”slower” angle deltas you get.
    Dayman Karate likes this.
  16. Aug 4, 2024 at 8:45 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I’m doubtful it’s more than wear and tear. Talking with a buddy that used to race leaf spring trucks he says he would break a main every race almost and have the pack serviced every race. When I joke about driving my truck like it’s a race car I’m not really joking and 90% of its life now is spent in the cinders in the whoops which is just brutal on things.
    Pittsy, nv529 and Caboose117 like this.
  17. Aug 4, 2024 at 9:54 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    sounds like alot of work.....links sound so much easier....while changing rod ends a couple times a year...sadly i dont run my truck enough to warrant changing anything once a year...lol
    Pittsy and snowsk8air2[QUOTED] like this.
  18. Aug 4, 2024 at 10:08 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    the concern with a shock going past vert is that it can get stuck past 90 on the next compression and bind the suspension and create fantastic destruction…what you are describing is normal though and no risk of that happening with articulation
    Dayman Karate[QUOTED] likes this.
  19. Aug 4, 2024 at 10:18 AM
    SoCaltaco65
  20. Aug 4, 2024 at 10:25 AM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    I see what you mean. I don’t think I’m over far enough to worry either way. Axle fully stuffed there’s no going past vertical, just full tilt.
    JTFisherman likes this.
