Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 16, 2024 at 7:11 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
  2. Aug 16, 2024 at 7:14 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  3. Aug 16, 2024 at 9:32 AM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    You guys are super helpful thank you
    SoCaltaco65 likes this.
  4. Aug 16, 2024 at 9:53 AM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    I have got a dumb question for y'all. How come we don't see front long travel arms made by anyone with rubber bushings and ball joints, with travel limited by the factory style shock top out and bump stop bottoming? I've done a tiny bit of looking around and it seems like all of the various kit setups require custom coilovers and limit straps, and they all run uniballs and poly bushings so the price climbs out of control. I live somewhere with seasons and would rather not have to replace those bits after every salt season, plus the idea of dropping 20k up front is always scary. I've seen ball joint LCAs for sale that do caster corrections by BTF, it just seems odd to me that nobody has taken that idea one step further by going a little wider and packaging a long travel ball joint UCA with it.
    Is it just because once you're buying extra travel most guys are going for every inch?
  5. Aug 16, 2024 at 10:10 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    1. The things you are mentioning do not really affect travel #'s
    2. JD Fab does offer the option for OE bushings & ball joints on some kits
    3. The reason people go to poly or delrin or uniballs is because it is a huge performance & durability upgrade, that factor is not causing a price jump. OE bushings cost more that a set of off the shelf poly bushings & there is no reason you can't use your stock bump stop locations every kit is designed to use those ? it is highly advisable to get a better bump stop though
    4. All of the kits do require a different coil over, there is zero point in getting longer arms but still using stock coil overs you would be adding travel capability and then immediately taking it away. A stock coilover is only 5" stroke and a LT coilover is 8"...there are a lot of other factors such as static, compressed and extended lengths
    5. Limit straps are not " required " but you should honestly use them even on a stock set up, they prevent all of the force from your rebounding suspension going 100% to the coilover
    6. JD fab offers sealed uniballs and sealed bj's
  6. Aug 16, 2024 at 10:26 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    I like all these answers, thanks! My only follow-up is #4, can't you just mount the coilover closer to the bushing pivots? It seems like you could mount those coils at the factory distance or closer even, which would need less shock travel, but would necessitate stiffer shocks and springs to deal with the motion ratio and hit desired wheel rates. Basically you'd match OEM downtravel angles, but get more wheel travel from the extended lever arm.
  7. Aug 16, 2024 at 10:30 AM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    You want the shock angle to match the travel of the arms
    If you scoot it up like you’re suggesting, it would work in very short intervals
    Maintenance on those shocks would probably blow cause the heat buildup would boil the oil inside in a pretty short turn
    the motion ratio of the shock would basically cook it
    EubeenHadd[QUOTED] likes this.
  8. Aug 16, 2024 at 10:34 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    I hadn't even considered heat buildup, that makes a lot more sense. Can you elaborate on "You want the shock angle to match the travel of the arms"? Is there a specific measurement here, or moreso matching the demands of wheel rates, shock heat/load, and control arm strength?
  9. Aug 16, 2024 at 10:51 AM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    The way it’s determined is by cycling the suspension
    In most cases you get an arm where a smarter person has already done that math
    But in rare cases
    You have to tab the arm yourself and the way you determine the shock placement on the arm is by cycling the travel of the whole suspension until all parts travel and cycle clean/efficiently
    Ideally you want like a 50/50 placement
    But some CARS run it further away like 70/30
    Additionally
    Most schools of thought want you to get somewhat of a straight up orientation on the shock as opposed to it leaning over super hard like old sand cars
  10. Aug 16, 2024 at 10:52 AM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Someone way smarter in here will likely dress up what I’ve said later since I’m pretty dumb compared to our real builders in here
  11. Aug 16, 2024 at 11:11 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    I'm doing what I can to look around at places like Race-dezert.com, and I think I've found what I'm looking for, it seems like most people aim for 1-1.5 motion ratio, never straying past 2 because the shock load/body diameter requirements become prohibitively large. Admittedly this is into racecar stuff and my mind is more focused on a daily driver, but that explains why LT systems seem to always stretch the shock mount and arm, you'd be climbing past 2 and need mahoosive bodied shocks, even for a DD first, wheeler second. I'm still curious about a system using OEM shock/coil configs for the primary and a longer/lower ratio shock/bypass for the secondary but that's pretty clearly suboptimal compared to a proper matched kit with both shocks using the same MR.
  12. Aug 16, 2024 at 11:18 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    motion ratio aside, most LT shocks are running a longer stroke than stock-width coilovers can provide, so you're limiting travel one/both ways [up or down travel]
  13. Aug 16, 2024 at 11:29 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    you’re over thinking an entire industry with decades of tried and true design principles… rule of thumb - if an entire industry does not make what you are looking for = you’re wrong :rofl:
  14. Aug 16, 2024 at 11:30 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Yup, sure am, love being laughed at for it too!
  15. Aug 16, 2024 at 11:34 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    That's where that question was coming from, it's really easy to make a lever arm translate 5" of motion into 15 so a stock style shock wouldn't limit travel, but if you can't make shocks/springs handle those loads then there's no point. It seems like ratios over 2-1 are just asking to destroy normal sized stuff, and there ain't no way you're fitting 4 inch shocks that would live in that space lol.
  16. Aug 16, 2024 at 11:36 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    The Camburg Trail LT series kit does just that.
    https://camburg.com/products/cambur...s-suspension-long-travel-kit-cam-310154-k-gry
  17. Aug 16, 2024 at 11:42 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
  18. Aug 16, 2024 at 11:50 AM
    desertjunkie760
    Shane
    Check My Sig.
    I don't agree with this mentality but to each their own. Just because it's been done a certain way, doesn't mean it's the best.
    I find that people are pursing performance when they go to LT, so sacrificing certain performance gains isn't appealing for the amount of money you're spending.
    It's a newer kit. I haven't heard much feedback but they designed it with the exact same concept in mind.
    Personally, I'd rather just sell my OE length shocks and purchase an LT spec for the performance aspect but that's just me.
  19. Aug 16, 2024 at 12:01 PM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Yeah there's two parts to this idea that have been bouncing around in my head. The first is getting extra performance, and the the bit that's already been done plenty, the formula is already out there as @Evenflow so elegantly pointed out. The other half is the maintenance half. I live in and daily a vehicle in areas with seasons, and occasionally hit trails that have mud pits and such. The idea of needing to replace unsealed joints every year or two kinda sucks so I'm really interested in stuff that's both rugged and gives actual performance gains, even if you're only getting 70-80% of the gains you would otherwise get from going full monte. I'm not looking to hit whoops like a trophy truck could, I'm driving the wrong platform for that lol. Just add a bit of capability to an already capable vehicle.
  20. Aug 16, 2024 at 12:33 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    I would like to say tho…
    A dirt king upper arm
    And a stock lower arm
    With a properly tuned king OEM replacement SMASHES
    It is good for 99% of the stuff UP TO where you’re actually beating the suspension off the truck from holes
    not_nick and YotaFAB like this.
