Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 20, 2024 at 11:40 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Understand, however Jesse may have some insight on what could be going on. Was actually thinking about heading up Friday to see if they want to quote out a project on my truck.
    MonkeyProof[QUOTED] likes this.
  2. Aug 20, 2024 at 11:41 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Late to the party but my camburg kit cycles 16” metal to metal. W/ coilovers, bypasses, and custom setup bumps + straps I have it about a tad above 15”.
    That said their lower uniball adapter thing is odd.
    Full uniball pivots even on the frame side are nice however.
  3. Aug 20, 2024 at 11:44 AM
    SoCaltaco65
    4wd?
  4. Aug 20, 2024 at 11:51 AM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    Fulltime Overlanding
    Long travel house on 35s with a custom aluminum utility bed and FWC
    some welding required
    having the LCA under the uniball means the steering isnt limited by the control arm 'neck' hitting the adapter.
  5. Aug 20, 2024 at 12:09 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    True. The DD kit is awesome. I didn’t know as much at the time I went with dirt king as they were very comparable to the TC race kit but significantly cheaper. No regrets though. Their customer service has always been amazing and I’ve heard the same about TC. DD kit is up there with the best options you can choose out there. Just always forget about them because they aren’t as mainstream.
    tacotunner06[QUOTED] likes this.
  6. Aug 20, 2024 at 12:13 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    yeah being able to change from a 8" to 10" coilover and heim the upper arms to get adjustment has been awesome to push from the 12-13" of travel to 16.5" while keeping the same kit. next just gotta decide if i wanna build my own kit or see how much further i can push this existing kit.
    906taco likes this.
  7. Aug 20, 2024 at 12:17 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    My next move is a 12” coilover/bypass setup. But first I need to figure out driveline. If I bail on 4wd which is looking more and more likely, things may get wild.
  8. Aug 20, 2024 at 12:18 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    ditching 4wd is the easy route....lol. i deal with too much soft sand if i do oregon dunes to ditch 4wd.
  9. Aug 20, 2024 at 12:22 PM
    906taco
    Cory
    08 Taco
    2wd guys play in sand all the time. Without paddles, too. I just know, no matter what we do. We will never have a diff strong enough to put solid power through.
    Sterling_vH111 likes this.
  10. Aug 20, 2024 at 12:40 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    they also get stuck....alot....
    snowsk8air2 and WormSquirts like this.
  11. Aug 20, 2024 at 12:43 PM
    SoCaltaco65
    Can confirm...typically I am the "hey dude can you pull me out guy"
  12. Aug 20, 2024 at 12:56 PM
    Sterling_vH111
    Sterling
    socal
    That’s the catch… 2wd lol.
    I’m not sure what 4wd would cycle.
  13. Aug 20, 2024 at 1:00 PM
    Sterling_vH111
    Sterling
    socal
    2wd. Lots of dune time.
    Lots of fun, but lots of stuck too.
    Live and learn to drive in the sand.
    AShive92, MadTaco461, TSAVO and 3 others like this.
  14. Aug 20, 2024 at 1:01 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Fabricated spindles???
    SoCaltaco65 likes this.
  15. Aug 20, 2024 at 1:04 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    i mean nothing is self recovering from that first one....lmao
  16. Aug 20, 2024 at 1:22 PM
    Pittsy
    Pittsy AKA LS6Taco - Ex car guy, current truck guy.
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Stroker Swap - LS6Taco
    I finally got an alignment last night on my truck.
    -0.4 degrees of camber, 4.0 caster, -.01 toe
    truck drives so much better now it’s not even funny. First time aligning this thing since LT install. Lower pivots are locked out, all adjustment done from the uppers.
    Bandido, SoonToBeOn39s and YotaFAB like this.
  17. Aug 20, 2024 at 1:23 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Wow I actually don't remember any front kit discussions like that ? I'm super curious to go cycle mine this weekend because my Solo +2 kit cycled 12" clean so I'll be a wee bit pissed off if my +4 kit is cycling less than that !? I'm pretty sure that wayyyy back in this thread there are photos from when the kit was being developed showing it cycling 14-15" ?
  18. Aug 20, 2024 at 1:26 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Center mount 9” like the ultra 4 guys. That will be my eventual move if I ever ditch the current setup. But also at that point just build a 4400 car and slap a taco cab over it
    Naveronski likes this.
  19. Aug 20, 2024 at 1:32 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I'll let you know how mine does when it's eventually done. 39s, 500hp, and 9" diff should hopefully work out okay
    snowsk8air2 likes this.
  20. Aug 20, 2024 at 1:38 PM
    WormSquirts
    Braeden
    BC
    That's what I'm building, should be pretty cool hopefully!
    snowsk8air2[QUOTED] likes this.
