Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 22, 2024 at 9:13 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    All of the Jd LT stuff including shocks.
    Naveronski likes this.
  2. Aug 22, 2024 at 9:15 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The oil from shockseals.com gets super sticky too if you leave it out. According to them it's something used in aircraft hydraulics so who knows maybe it's something about the high heat modifier additives
  3. Aug 22, 2024 at 9:38 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I checked out your build page. I would have been interested if it was 2.25" over.
    Airdog[QUOTED] likes this.
  4. Aug 22, 2024 at 10:24 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Who wants to build the first v10 Tacoma?
  5. Aug 22, 2024 at 11:01 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    They’re gonna part it out? Don’t quite understand that. LFAs are million dollar cars now. Doubtful that would sell for any less than 200k-300k.
    To weigh in on wheel weights, I found some wheels from Modco. Flowformed, with some knurling similar to methods bead grip. 24lbs a wheel. Can’t wait to get them on. I like the forged rays all the cool kids have, but those are like $4.5k a set and without beadlock. But they only weigh like 16lbs.
    SoonToBeOn39s likes this.
  6. Aug 23, 2024 at 5:41 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    @Pittsy keep it in the Toyota fam for your next engine swap?
  7. Aug 23, 2024 at 5:45 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    I think he needs a well being check at this point in time, if it weren’t for bad luck….
  8. Aug 23, 2024 at 5:58 AM
    906taco
    Cory
    08 Taco
    Crazy to think I’ll be doing a 5k mile check over on this thing already today. First time I will be deep diving into the swing set since it was completed. Not expecting to find anything, but you never know. Everything has been treating me so dang good this year!
    Tango Bravo, Naveronski and essjay like this.
  9. Aug 23, 2024 at 6:26 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    :eek: Jelly and stoked
    SoonToBeOn39s and Airdog[QUOTED] like this.
  10. Aug 23, 2024 at 6:31 AM
    JTFisherman
    JTFisherman Well-Known Member
    Jake
    Texas / Missouri
    4Runner
    Yea from what I have seen online and comparing listed properties I bet shock seals oil, fox red jm92, Bilsteins oil, and locked offroad oil is all F&L ultra extreme. I use the shock seals stuff most of the time now.
    I think king is shell tellus T22, but the F&L has a much better viscosity index so I swap most stuff to it. Just annoying when it makes everything sticky.
    Maxima makes even better stuff but the 3wt I used to use doubled in price since last summer.
  11. Aug 23, 2024 at 6:39 AM
    906taco
    Cory
    08 Taco
    One worth checking out is Lucas shock oil as well. I’ve been running the 7.5w. It definitely takes significantly more abuse than king oil before turning black. It’s also available in numerous viscosities I believe from 2.5 all the way to 10 which is beneficial for different climates and controlling fade.
    JTFisherman[QUOTED] likes this.
  12. Aug 23, 2024 at 6:45 AM
    Speedytech7
    My rear Kings became so much more predictable and less harsh in cold weather when I swapped to the shockseals stuff. Their factory oil if it is Shell, seems not great for the application
  13. Aug 23, 2024 at 6:55 AM
    906taco
    Cory
    08 Taco
    King oil is like 40w oil when it’s cold. It gets unbelievably thick and makes things harsh. In winter I never could get them warmed up enough to smooth out. Both the fox oil and Lucas definitely changed that.
    Lots of stuff out there basically saying king oil is pretty bottom of the barrel stuff. I doubt any race teams run it.
  14. Aug 23, 2024 at 7:03 AM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    It took almost a year for him to get his portals. Bought his in September last year didn’t get it till June when he was told he’d get it after KOH. So who knows, as long as we know it’s going to come out.
  15. Aug 23, 2024 at 7:41 AM
    JTFisherman
    Jake
    Texas / Missouri
    4Runner
    I think the king stuff is just a lightweight hydraulic oil
    I can’t really find stats on a 7.5wt shock fluid for shell. Hard to tell if it is a fork oil or shock oil but just heads up a lot of fork fluids don’t have as good of a viscosity index because they are more focused on not foaming. I do use them in bumpstops to prevent foam but it probably doesn’t really make a difference.
    lucas 5wt shock fluid is like 320VI which seems in between fox and maxima.
    and none of this really matters for me because my shocks haven’t gotten over 200 according to the temp stickers haha
  16. Aug 23, 2024 at 7:49 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    This is the key. Most don't push their vehicles hard enough to notice a difference in oil.
    The ones who do move to one of the better performing oils, but you have to pay for it.
    Even sponsored race teams will use a different shock company's oil for the performance benefit. Assuming it's in their budget of course.
  17. Aug 23, 2024 at 7:58 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    I missed this......Damn it.....im looking at the site....
    Airdog[QUOTED] and Speedytech7 like this.
  18. Aug 23, 2024 at 7:59 AM
    Speedytech7
    King also makes a distinction between their Race and "Prerunner" series of shocks and that may have a difference in oil as well, I'm not sure. I don't have any intention to purchase more king shocks in the future, I've been mostly unimpressed.
  19. Aug 23, 2024 at 8:01 AM
    SoCaltaco65
  20. Aug 23, 2024 at 8:05 AM
    SoCaltaco65
