Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Sep 15, 2024 at 9:59 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    This sounds like we’ve had the same adventure before
    sicki[QUOTED] likes this.
  2. Sep 15, 2024 at 11:40 PM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    Do balance beads freeze up in the winter?
  3. Sep 15, 2024 at 11:45 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Do BB’s?
  4. Sep 16, 2024 at 3:46 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Mostly because chicks dig 5/8 studs as much as they dig bypass tubes. Also my Ford 9 inch axle has 5/8 studs and my TR beadlocks are drilled for 5/8 studs add that all up and my fronts need to be 5/8 studs and ya……wanna be race truck.
  5. Sep 16, 2024 at 4:47 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    How much of a certainty is driveshaft modification with a frame notch?
    Double cab short bed.
    Dmz
    Dirtking bump stop mounts with notch.
    This is my plan, I know every truck is different.
  6. Sep 16, 2024 at 5:06 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Shouldn’t need driveshaft mods for extra bump travel. Droop is when things become an issue. USUALLY.
    IvanhoeTaco[QUOTED] and Airdog like this.
  7. Sep 16, 2024 at 5:12 AM
    906taco
    Cory
    08 Taco
    No issues with freezing up whatsoever.
    The cool thing with beads is they adjust to change constantly. By speed, tire wear etc.
    Beads will prolong tire life to an extent as well. Over time with weights you will come out of balance to a certain degree just because of tire wear. This can cause unwanted wear patterns.
    Pittsy and not_nick[QUOTED] like this.
  8. Sep 16, 2024 at 8:14 AM
    orbot
    orbot Well-Known Member
    No pic, but you can tell because the body looks way shorter
  9. Sep 16, 2024 at 8:19 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    if i remove the straps, bumps, and coilovers, my drop limit is the u-joint at the differential. and my compression limit is the driveshaft hitting the underside of the cab. that is with a two piece drive shaft. in general, if you have a one piece, you will be able to get more drop, but will hit the cab sooner. that is however, cycling about 24 inches of travel in total with a stock driveshaft, so i doubt you'll need to worry.
    IvanhoeTaco[QUOTED] likes this.
  10. Sep 16, 2024 at 8:38 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Off to make changes to my truck...
  11. Sep 16, 2024 at 10:34 AM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Interesting. These fit perfectly as far as cycling goes. Upper ball joint taps out exactly where the shock stroke ends. CV is barely binding at that point, too.
    colinb17 likes this.
  12. Sep 16, 2024 at 4:28 PM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Tell me a bit more about balance beads. I had them in my rv tires and they still shook. I have a tire that has a cyclic vibration after balancing...shakes the truck on and off about 3 times a minute at freeway speeds.
  13. Sep 16, 2024 at 4:48 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Anyone here running a topper or camper on fiberglass? Looking for ideas to start designing something that supports the bedsides underneath so my composite bed and glass don't instantly shatter. Thanks in advance
    sicki and IvanhoeTaco like this.
  14. Sep 16, 2024 at 4:54 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    i have all of the above, check my build thread
  15. Sep 16, 2024 at 6:34 PM
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    That's right, forgot you had the whole setup. I have some ideas of building it off the JD frame brace/towers but I want to see what other people have done. I'll check it out!
  16. Sep 16, 2024 at 7:31 PM
    Sterling_vH111
    Sterling
    socal
    Anyone here good with a/c systems ?
    or could @ a member who is?
    I have a basic understand of how the system works but not much idea of how to troubleshoot it
  17. Sep 16, 2024 at 7:35 PM
    YotaFAB
    YotaFAB Well-Known Member
    Anyone add trac bar and stay SOA to get rid of axel wrap? I wanna go SUA but it’s out of the budget. Currently on U402 S1 and I get wrap anytime under load, did drive shaft thinking the shaking under load was bearing. Nope any suggestions?
  18. Sep 17, 2024 at 6:24 AM
    Sterling_vH111
    Sterling
    socal
  19. Sep 17, 2024 at 6:39 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    What’s going on with your AC?
  20. Sep 17, 2024 at 8:16 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Sua and yes I have an anti-wrap bar
