Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Sep 23, 2024 at 10:21 PM
    Tango Bravo
    Tango Bravo Sailing the Seven Seas
    Thomas
    SoCal
    09 4x4, The Green Rubber Ducky
    Chaos 3.5" Race LT, RJ Fab Cantilever LT
    Didnt tie them in.
    I can see that. The ambers only have an on / strobe option. I could have probably doubled up the high input on each side to tie in with the turns, but I didnt want amber turns in the stock lights, with red turns on the bar. Plus then I only had to tap one brake light, instead of running a signal wire from the other side.
  2. Sep 24, 2024 at 3:57 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Oh, I follow now. I didn't realize this was in addition to the stock lights.
  3. Sep 24, 2024 at 9:10 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  4. Sep 24, 2024 at 10:45 AM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    Fulltime Overlanding
    Long travel house on 35s with a custom aluminum utility bed and FWC
    some welding required
    YotaFAB likes this.
  5. Sep 24, 2024 at 10:46 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    The kc had turn signal provisions built in, it’s what I’ve got as well on my truck.
  6. Sep 24, 2024 at 10:49 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    baja designs must have some better keyword tags on their website then, because i searched for a WHILE and the kc bar didn't come up. it has running, brakes, and a reverse light as well? always good to have a second option if i end up not liking the BD bar for some reason.
  7. Sep 24, 2024 at 10:53 AM
    SoCaltaco65
    true, but does any chase light meet sae/dot?
  8. Sep 24, 2024 at 11:06 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    For one, if removing the factory tails, then nope, cause you’d be missing reflectors.
    Naveronski likes this.
  9. Sep 24, 2024 at 11:07 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    I would think for a chase light you would not want the SAE cut off, am I wrong?
  10. Sep 24, 2024 at 11:23 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Why are people concerned weather chase lights are SAE/DOT or street legal? Just don't use them on the street. I don't tie any auxiliary lighting into factory circuitry. Unless racing do you really need auxiliary brake lights or turn signals?
    MonkeyProof and Sterling_vH111 like this.
  11. Sep 24, 2024 at 11:37 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Shameless plug.
    If anybody is looking for BD, KC, king, fox, icon, wheels, tires yadayadayada. Feel free to shoot me a dm and I’ll see what I can do for pricing.
    Please no tire kicking though.
  12. Sep 24, 2024 at 12:18 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    My dual swingout rear bumper (especially with spare tire) can make it difficult to see the original brake lights and turn signals, so yes… it has a legitimate use on road.
    If it doesn’t apply to you, that’s okay too.
    SoonToBeOn39s likes this.
  13. Sep 24, 2024 at 2:21 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    speaking of chase bar tail lights, i tossed the the battery back into the truck to test all of the new back-half wiring. the baja designs RTL should do just fine! being specifically designed as a tail light, the light output seems much more proportional to factory tail light outputs, vs standard chase bars which feel would blind you on the highway.
    https://youtube.com/shorts/4vK8RkhZuZ0?si=SBotq7OUg90vcdkv
    Naveronski and SoonToBeOn39s like this.
  14. Sep 24, 2024 at 2:48 PM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    I
    Exactly. I plan on running chase lights 100% of the time with no stock taillights.
    The reflector issue could be solved with a $2 pack of reflective tape from Amazon.
  15. Sep 24, 2024 at 3:01 PM
    01 dhrracer
    Still Shopping
    True. I have not considered all scenarios. But there are plenty of available lights out there that would not have the cost of Baja Designs. I am all for high quality lights including BD but for that purpose I would find a less expensive option and tie into the 7pin trailer connector if you have it.
    colinb17 likes this.
  16. Sep 24, 2024 at 3:05 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I second this. I looked at a lot of options before going with the BD bar. And I really just did that for simplicity since I was losing the stock lights all together. If you're looking for supplemental lighting, there are so e really good looking motorcycle tail lights that are small and therefore versatile, and very inexpensive. They're also pretty attractive looking.
    sicki likes this.
  17. Sep 24, 2024 at 3:53 PM
    Tango Bravo
    Thomas
    SoCal
    Yep one of my brake light lenses is broken and has a bunch of dust in it. Been too cheap / lazy to replace it. It's nice knowing people can always see my brakes.
    I work in and around a port. It's nice having higher brake lights when in bumper to bumper traffic with semis all around.
  18. Sep 24, 2024 at 3:57 PM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    Aren't the factory tail lights already leds after 2009 anyway? Instead of hunting around for some holy grail light bar that does it all, why not just fab up a mount for a few smaller ones and run the factory wiring to them?
    soggyBottom likes this.
  19. Sep 24, 2024 at 7:13 PM
    JdevTac
    Josh
    MD/GA
    2nd gen
    would be easy with some KC cyclones.
    SoCaltaco65 likes this.
  20. Sep 25, 2024 at 7:07 AM
    YotaFAB
    YotaFAB Well-Known Member
    California Vehicle Code Section 24600 (public.law) CA has some specifics, it will really depend on the cop behind you.
