Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Sep 30, 2024 at 3:48 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I did this for about 3 years.. finally wouldn’t hold any pressure.
    The filter was absolutely filthy too. Probably from all the stop leak.
  2. Sep 30, 2024 at 3:50 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I've got a first Gen, no filters here haha, unless you mean the drier, in which case yeah that things probably straight ruined
  3. Sep 30, 2024 at 3:50 PM
    Sterling_vH111
    Sterling
    socal
    Under warranty at the dealer I worked at, it used to pay 4.5hrs… idk how people do em in that time.
  4. Sep 30, 2024 at 3:52 PM
    Sterling_vH111
    Sterling
    socal
    Interesting, even in the low pressure side?
    I was surprised to find that my 97 4Runner didn’t even have a cabin air filter…
    I know it hasn’t been looked at in 28 years. Scared to even take a peep, but the air doesn’t smell on that one…
  5. Sep 30, 2024 at 4:24 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    ok, I know LSK bolts their LCA in and uses the UCA to adjust alignment. I am getting tired of knocking mine out every single time I hit the des. And always the Driverside.
    Thinking of bolting the LCA in my current kit as they have UCA with thread hiems.
    Or just go with the LSK 4x4 kit.
    thoughts?
  6. Sep 30, 2024 at 4:27 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Do you have the JDfab lower pivot kit? If you dont that is a cheaper alternative. Once I put mine on the alignment never moved again no matter how hard the hit. The LSK kit suggest welding the lowers into place
  7. Sep 30, 2024 at 7:29 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Customer states dashboard rattles…
  8. Sep 30, 2024 at 8:40 PM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    333fab cam lockout plates :thumbsup:
  9. Sep 30, 2024 at 9:28 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    They won't do a thing for very thin and weak brackets.
    SoCaltaco65 and Sterling_vH111 like this.
  10. Sep 30, 2024 at 9:46 PM
    Sterling_vH111
    Sterling
    socal
    I tried those and could not get a good alignment..
    I did marlin crawler gussets and they’ve been solid.
    + Firestone lifetime still takes the truck in !
    SoCaltaco65 likes this.
  11. Oct 1, 2024 at 1:17 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    With the jd mounts only time mine moved was hitting a j out when i ripped the tab off the mount. since then i made some 4130 plates from send cut send and just adjust with the upper now.
  12. Oct 1, 2024 at 1:19 AM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    do they actually fail at the seams of the core? i always wondered if that was the actual problem or at the fittings into the core at the orings that i found out after the fact you can do from the engine bay...lol. but i have a vintage air hvac in now which is like 1/2-1/3 the size of the factory setup. doesn't output nearly as much but i also don't daily my truck anymore so oh well.
  13. Oct 1, 2024 at 3:13 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    I have never seen the inlet/outlet connections leak. Pinholes in the tubes or sometimes a leak at a seam/crimp. I do tons of camrys and avalons mostly
  14. Oct 1, 2024 at 6:49 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Your warranty admin needed to find you z time. That's what I do.
  15. Oct 1, 2024 at 8:17 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    04' 4Runner, in the past I would often have VSC/TRAC/ABS lights on from I am assuming a bad connection in the rear sensor wiring, but this would never throw a CEL.
    Over the winter I removed the the front speeds sensors and wiring and have put several thousand miles on it with nothing other than the VSC/TRAC/ABS lights on, which do not cause any issues other than the ABS not working, which is great.
    This weekend during a cruise in the mountains I noticed the spedo and odometer stopped working and got a CEL. Yesterday I pulled the code and it is P0500, Vehicle Speed Sensor (VSS). I also noticed that the fuel gauge was going up and down nearly a quarter tank while at a stop.
    The internet tells me I should try putting the sensors back in, but it has been fine for thousands of miles, so I don't think that is it. Anyone have any experience or insight?
  16. Oct 1, 2024 at 8:28 AM
    Y2kbaja
    Sacramento
    Total Chaos
    My truck would do this after the 3rd speed sensor would go out. 1st, 2nd I would get the lights, but the 3rd would disable the speedo and throw mil. I put in a speed sensor in the TC and wired direct to the speedo.
  17. Oct 1, 2024 at 8:31 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Interesting, I have the rears still hooked up (but wanted to remove them as well), so maybe one of them took a shit. Ill check those, then try connecting the fronts again. Thanks!
  18. Oct 1, 2024 at 12:02 PM
    SoCaltaco65
    Wut? really? Mine is the same since 2011.
  19. Oct 1, 2024 at 12:04 PM
    Speedytech7
    Mine are original since 1993,1995,1996 respectively and they've all needed Evaporators :/
  20. Oct 1, 2024 at 12:20 PM
    Sterling_vH111
    Sterling
    socal
    Exactly where mine has split twice now, right at the seam for the tank and fins.
    IvanhoeTaco[QUOTED] likes this.
