Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 1, 2024 at 12:22 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    lol when I was 18 I had nooo idea.
    I now work for a motorcycle OEM doing techline, dealing with some warranty claims when it’s slower.
    I always try and work with our dealers so they get paid proper with flat rate and our other labor code that can be inputted for diag time or testing etc.
  2. Oct 1, 2024 at 1:28 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Oh yeah, you will get dye dripping from evaporator drain. Some cars make it 400,000 miles and others leak at 50k
    Sterling_vH111 likes this.
  3. Oct 1, 2024 at 1:29 PM
    IvanhoeTaco
    Eastern NC
    Lexus' are the worst because they usually have a million modules and sensors. Probably 100 miles of wiring behind those dashes on a fully loaded model
  4. Oct 1, 2024 at 1:34 PM
    Sterling_vH111
    Sterling
    socal
    You think that Toyota A/C cleaner foam does any real work? I thought about doing that on the 4Runner as there’s no filter and it’s oooold. But also most things in a can seem like snake oil
    IvanhoeTaco[QUOTED] likes this.
  5. Oct 1, 2024 at 2:11 PM
    IvanhoeTaco
    Eastern NC
    Meh, it's mildew that makes the smell. My wife's equinox had a reprogram done to let blower motor run with key off to dry the evaporator core. She had evaporator core replaced under warranty because the car would smell like stinky socks.
    Toyotas are good about drain placement but I've def seen standing water in the cases. Hell my tacoma will drip on your feet when it's hot outside
  6. Oct 2, 2024 at 7:44 AM
    sicki
    sicki Well-Known Member
    :thumbsup:
  7. Oct 2, 2024 at 12:22 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    noted, ty
  8. Oct 2, 2024 at 12:25 PM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    New All-Pro LT system looks nice in the limited pics/videos I've seen. 15" of travel. Modular design where you cut off some/most of your factory suspension, weld in their bulkhead (which looks like contains mounts for the LCA's, UCA's, and new coil/bypass mounts). LC200 rack. Rack and diff pushed to make more room. Front tires can go up to 2" forward. No comments on width or pricing.
    Naveronski and YotaFAB like this.
  9. Oct 2, 2024 at 12:37 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    They said it’s 3.5 over
  10. Oct 2, 2024 at 12:50 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    lol Marlin crawler:
  11. Oct 2, 2024 at 2:34 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Yep, I think it’s neat too.
  12. Oct 2, 2024 at 2:43 PM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    Stupid question time. For cycling suspension, drain shocks of nitrogen?
    IvanhoeTaco likes this.
  13. Oct 2, 2024 at 2:45 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Definitely makes it easier
  14. Oct 2, 2024 at 3:18 PM
    SoCaltaco65
    where did you find pics/videos?
  15. Oct 2, 2024 at 3:25 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    Its on their IG page
    SoCaltaco65[QUOTED] likes this.
  16. Oct 2, 2024 at 3:26 PM
    SoCaltaco65
  17. Oct 2, 2024 at 3:32 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Maybe it’s me. But that kit seems pretty meh. I like the modular idea. But to go through all of that trouble just to still have them low hanging diff mounts and what appears to me as a substantial amount of bump steer in a couple of IG videos. Then only yield 15” after cutting the front of your truck off? And is that “cycling” 15 or actual usable?
    Sterling_vH111, not_nick and Airdog like this.
  18. Oct 2, 2024 at 3:34 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    15” of travel might be a bit of a stretch. If I recall from the thread thoroughly testing the Marlin kit, it was more like 10”.
  19. Oct 2, 2024 at 3:38 PM
    906taco
    Cory
    08 Taco
    To be fair if they moved things around it could likely yield more simply because of vertical uniballs. However, if that stuff isn’t properly placed you just end up with a pile of garbage that you really can’t reverse. One of the videos, the front wheels dropped out and the thing toed in like 3”. Unless I’m seeing shit. But the tie rods do not look proper and look as if they were placed to avoid outer heim bind.
    I won’t knock it too much I guess. But after tackling a massive project myself involving much of this geometry, it smells awful fishy.
    SoonToBeOn39s likes this.
  20. Oct 2, 2024 at 3:45 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
