Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Nov 5, 2024 at 3:46 PM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    Imo perfecting mig welding first is kinda backwards at least; a waste of time at most. It's great if you have welding down already and want to do a few quick n dirty welds or knock out dozens of parts in a day. For structural stuff where weld quality matters, like suspension parts and cages, stick and tig are much less voodoo magic to learn on and that'll lead to better welds on more projects done earlier on. Also i find it's not that hard to get a decent machine without spending a lot which is usually the case for most starting with mig. The tombstone style stick machines go less than a dollar a pound anywhere and everywhere, and old transformer tig machines even less assuming ya got the space
    Run what ya brung more than anything. Still better off than people unwilling to learn shit and develop skills. Just stating my opinion on the ideal way to go with welding based on this threads main subject matter
  2. Nov 5, 2024 at 4:08 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    For most MIG is 100% the most commonly used type of welding. It’s user friendly, quick to learn and get good results from. It’s also about 5x faster than TIG, on a bad day.
    TIG is my preferred method of welding. But it took YEARS to actually be good with it. Sitting at a bench is one thing. Twisted up like a pretzel trying to do a cage or something under a vehicle. Totally different.
    Not to mention. TIG should ALWAYS be double pass welded if it’s a critical component. Root/Cover.
    The prep for good quality TIG welds, is also a bear of a task in its self.
    There is a reason basically no welding school will ever start someone on TIG. Because it is absolutely not easy for a new guy.
  3. Nov 5, 2024 at 4:28 PM
    906taco
    Cory
    08 Taco
    WIY bumpers that come out looking bad are totally different than a control arm breaking and killing a family of 5. The liability issues are interesting in this world. You’re responsible but not at the same time. Meaning, if you sold a WIY long travel kit to someone that didn’t know how to weld and they kill someone. A good lawyer is going to take you for a ride.
    sicki likes this.
  4. Nov 5, 2024 at 5:13 PM
    mauctopa
    mauctopa Well-Known Member
    That's been my line of thought too tbh. I've seen WIY bumpers with hitches and hitches only. I imagine pulling a trailer or luggage carrier coming loose on the freeway can cause an accident too.
  5. Nov 6, 2024 at 1:36 PM
    TruckAbuser
    TruckAbuser New Member
    2014 TRD Sport
    Soon to be LT
    Curious about your thoughts on someone doing their own LT leaf spring "kit" (shackles and hangers.) Was planning on making my own for my build. I think it will be cheaper but the overall goal would be to learn and enjoy the project. You saying this though makes me wonder if it may be a larger undertaking than I'm expecting, especially with the lack of resources available in regards to leaf spring geometry online.
  6. Nov 6, 2024 at 2:14 PM
    906taco
    Cory
    08 Taco
    Anything is possible. SUA would be about the easiest suspension project one could tackle in terms of not really needing jigs if it’s a one off deal.
    TruckAbuser[QUOTED] and Airdog like this.
  7. Nov 6, 2024 at 4:00 PM
    906taco
    Cory
    08 Taco
    Anybody in here know if any of the big manufacturers will sell bypass tubes individually? I’m looking at the possibility of adding trim tubes to my bump zone in the rear. Something I know I could tackle and would much rather not send out to be done.
  8. Nov 6, 2024 at 4:00 PM
    not_nick
    Leaf spring geometry isn't too complicated since there really isn't much you could change even if you wanted to. They either cycle cleanly or they don't. Then you get a small window of shackle length and pinion angle to play with and that's about it. Plan for a lot of time spent breaking down the leafs and cycling the suspension with it tacked together - then about double whatever you came up with. Other than that it's not more involved than any other weld on part. Everything is out in the open and easy to get to n that jazz
    TruckAbuser[QUOTED] likes this.
  9. Nov 6, 2024 at 4:09 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    I've got a guy at work that use to work for a company that welded on the tubes for King....think he may still do side work for them so I may be able to get what your lookiing for. Any particular length. I'm not actually sure how they are manufactured.
    906taco[QUOTED] likes this.
  10. Nov 6, 2024 at 4:23 PM
    TruckAbuser
    2014 TRD Sport
    Soon to be LT
    Yeah, it seems there is a large amount of general rules of thumb out of there, and the consensus is just cycle everything 1 millions times until you get it right. Ideally however I would like to get it designed on the computer, send it out to get laser. Bend everything weld what I can and then only have the truck down for less than a week. Just how I like to do things, because I'm good at the computer work... not so much on the torch, need practice. So when I say lack of info I'm talking about optimal shackle angle at ride height, whether its best to have the shackle in tension vs compression(spring above the shackle or below), and stuff like that. All of this stuff probably isn't super important but I'd like to get it as dialed as physically possible.
  11. Nov 6, 2024 at 4:34 PM
    906taco
    Cory
    08 Taco
    I would have to measure the length to be positive. But probably 3”
    Airdog[QUOTED] likes this.
  12. Nov 6, 2024 at 4:41 PM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Any suggestions on pumping 85w140? I’ve tried drill pumps, two different hand pumps, penis pump etc. and it never ends up working well.
    colinb17 likes this.
  13. Nov 6, 2024 at 4:52 PM
    906taco
    Cory
    08 Taco
    Soak it in a scalding hot bucket of water first. Should see what 250 is like lol.
    Dayman Karate[QUOTED] likes this.
  14. Nov 6, 2024 at 5:31 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    The reason so many things lack details (general rule of thumb) is because of the number of variables. How do you want it to perform, what are your expectations, where do you want it to be its best, how much power, how much travel and the list goes on. Commercially available products from quality reputable experienced MFG's are always going to shoot for generalities based on their own experiences of testing. So, if you want something very specific you need to do it yourself or pay for custom. But you will first have to define exactly what you want that cannot be accomplished by what is already available. And the only way to get there is normally from vast amounts of experience of trying everything available as well as your own outside of the box experiments.
    not_nick likes this.
  15. Nov 6, 2024 at 5:38 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    i mean its just a piece of tubing thats bent at either 90 to make one or 180 and cut in half for two with another piece cut and welded at the top and some holes drilled and a oring adapter fitting for the bypass itself to go into welded on, but honestly if they would sell them it would take way less time than trying to make two of them yourself...
  16. Nov 6, 2024 at 7:58 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    well shit…I only had one suggestion and you pretty much covered it
  17. Nov 6, 2024 at 8:30 PM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Great minds think alike :rolleyes:
  18. Nov 7, 2024 at 5:54 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    When I’d do gear installs, I’d set the bottles in the sun or in front of a space heater. This would get em nice n easy flowing. If Lucas would come out with the squeeze bag like other brands have, it would be so much easier.
  19. Nov 7, 2024 at 6:45 AM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    love the amsoil squeeze bags.
    Bandido and SoCaltaco65 like this.
  20. Nov 7, 2024 at 7:02 AM
    906taco
    Cory
    08 Taco
    Lube in a bag is the best invention since sliced bread. Errrbody needs to get on board. Don’t even get a nipple with my redline bottles.
