Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jan 16, 2025 at 6:17 AM
    Pittsy
    Pittsy Ex car guy, currently in rehab
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    Pleeeeeeeeeease
  2. Jan 16, 2025 at 6:20 AM
    Pittsy
    AZ
    here’s my BTF setup:
  3. Jan 16, 2025 at 6:24 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    what are you trying to achieve?
    I have a set of Tundra shackles that I put new bushing in I’ll sell you for cheap.
    I think they’re 3.7” length? Longer than stock but not as long as the Archive SUA
  4. Jan 16, 2025 at 6:34 AM
    desertjunkie760
    Shane
    Check My Sig.
    Do you happen to recall what they charged you?
  5. Jan 16, 2025 at 6:41 AM
    Pittsy
    AZ
    Like a 1/2” drop in ride height
  6. Jan 16, 2025 at 7:23 AM
    desertjunkie760
    Shane
    Check My Sig.
    PM sent
  7. Jan 16, 2025 at 7:38 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I want to say like $700 for everything, I dropped the truck off Lateand picked it up the next morning
  8. Jan 16, 2025 at 7:40 AM
    Sterling_vH111
    Sterling
    socal
    What length shackles do you have?
  9. Jan 16, 2025 at 8:43 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Remember a longer shackle is going to push the spring forward as it moves. Not really ideal to lower the truck that way. Better option would be a shackle flip setup. Or just leave it be because it LOOKS fine.
    4runnersr569 and colinb17 like this.
  10. Jan 16, 2025 at 8:53 AM
    YotaFAB
    YotaFAB Well-Known Member
    pretty sure its the 3.6" PM coming
  11. Jan 16, 2025 at 4:05 PM
    Pittsy
    AZ
    True but I figured since this truck isn’t seeing big numbers anyways that it’s not the end of the world. And it’s not a huge amount either.
  12. Jan 17, 2025 at 9:47 AM
    YotaFAB
    whats a ball park cost for a shop to install a DMZ SUA?
  13. Jan 17, 2025 at 9:51 AM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    I was quoted $1200 for a shop but their response was "we never done anything like this but we'll give it a shot". Needless to say i didn't use that shop.
    Ended up paying 2k for extended rear brake lines, frame box, and removal of stock bed mounts at a different shop.
    YotaFAB[QUOTED] likes this.
  14. Jan 17, 2025 at 9:58 AM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I'm assuming it comes with a bolt in bed cage, which means cutting off the front leaf mounts, rear hangers, and the shock mounts on the frame and axle, installing new hangers, cutting holes in the bed, installing the bed cage, breaking apart the leaf pack, setting pinion angle and shock mount location, cycling for shocks and bumps, welding perches and shock mounts in, and then paint, reassembly of leaf pack and install, and replacing rear brake lines and bleeding brakes. That's assuming no hydrobumps, I'd probably quote around 18 hours or so, just as a reference.
  15. Jan 17, 2025 at 1:20 PM
    IvanhoeTaco
    Eastern NC
    Tim told me they don't even do installs anymore, but he would charge 40hrs of labor to install that kit.
    SoonToBeOn39s likes this.
  16. Jan 17, 2025 at 1:35 PM
    YotaFAB
    I spoke to Tim as well. He said that’s including bed cage frame box ETC
    IvanhoeTaco[QUOTED] likes this.
  17. Jan 17, 2025 at 1:46 PM
    Pittsy
    AZ
    906taco likes this.
  18. Jan 17, 2025 at 1:54 PM
    IvanhoeTaco
    Eastern NC
    My bedcage has about 16 hours in it, frame boxing and install/cycling cleaning/painting I've got around 16-20. First one I've ever done or probably will do so I'm sure it could be done quicker
  19. Jan 17, 2025 at 1:55 PM
    IvanhoeTaco
    Eastern NC
  20. Jan 17, 2025 at 4:15 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    I would drive that one!
