Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jan 28, 2025 at 11:41 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    https://corva.org/
  2. Jan 29, 2025 at 7:38 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Yeah, I understand what it does, I built my own core. My question is what is this going to do at the connection to the body, this is going to be even stiffer than the stock one and any flex is going to end up where the fender mounts to the body, and likely end up just like mine I suspect. Really just moving the weak point as I found out.
    906taco and SoonToBeOn39s like this.
  3. Jan 29, 2025 at 3:34 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    I need to get a new 3rd member I’m on 37s and super charged gen 2 . leaning to 5.29 gears but I don’t know if I should go with spool lsd or lockers arb and such . Anyone have a similar set up ? Any suggestions and advice would help!
  4. Jan 29, 2025 at 6:10 PM
    Pittsy
    Pittsy Ex car guy, currently in rehab
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    I hear good things about the trutrac. That’s what I would do.
    Caboose117 likes this.
  5. Jan 29, 2025 at 6:11 PM
    soggyBottom
    soggyBottom Well-Known Member
  6. Jan 29, 2025 at 7:45 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Love my 5.29’s with my 2nd gen with sc and 37’s. Taken years of abuse. But I’m running a tundra 10.5” housing with a Harrop e locker.
    01 dhrracer likes this.
  7. Jan 30, 2025 at 6:11 AM
    Sterling_vH111
    Sterling
    socal
    A lot more fun for me now, that I know the alternate meanings :D
  8. Jan 30, 2025 at 9:24 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Spools are aweful. 10/10 don’t recommend. 37’s just showed up for the wife’s truck and we are doing 5.29’s with ARB’s
    a2lowvw likes this.
  9. Jan 30, 2025 at 9:27 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Agreed, done spools and welded a couple times, unless it is a dirt only rig that's used in the same conditions... man the spool gets annoying
  10. Jan 30, 2025 at 9:54 AM
    906taco
    Cory
    08 Taco
    You aren’t wrong. Without having a rigid chassis it is simply going to move the load to the firewall. And judging from your pictures, that’s exactly what you experienced. This thin sheet metal cannot handle it.
  11. Jan 30, 2025 at 12:08 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Exactly. I think this would be the less destructive used with a stock body mount, but still likely to blow up the firewall connection over time IMO.
    906taco[QUOTED] likes this.
  12. Jan 30, 2025 at 12:44 PM
    906taco
    Cory
    08 Taco
    Front frame section moves more than the body mounts will allow. So in other words, 100% going to be transferred back to the factory sheet with a rigid front clip. Our core supports don’t crack because of tire contact or anything else. It’s simply flex.
    Once again, cage is the best option. I haven’t broke a headlight or grill tab or anything since the cage. The frames are just too damn floppy without.
  13. Jan 31, 2025 at 6:42 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    20250131_213452.jpg 20250131_213559.jpg 20250131_213836.jpg 20250131_213511.jpg
    Got a new windshield put in today. Couple of rock chips decided they wanted to talk to each other last week with the cold weather.
    Cars and coffee in the am then taking to the beach to hear some bypasses clicking
  14. Jan 31, 2025 at 7:40 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    have you ever tried to put that oe spare rim on your truck ? Seems like the backspacing on it would be a problem front or rear ?
  15. Jan 31, 2025 at 7:48 PM
    IvanhoeTaco
    Eastern NC
    I have spacers in the rear so worst case i could move a wheel around to get me home. This is a "fun is over" spare
    Evenflow[QUOTED] likes this.
  16. Jan 31, 2025 at 9:41 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    yeah ive got 5.29's and a arb air locker, granted its in a ford 9" but its worked great. i like the air locker since occasionally we do get ice in the pnw and i don't want that to ever be a problem.
  17. Feb 1, 2025 at 12:16 PM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    For you guys that have tube front end/inner fender, can you send pictures how you end up mounting your fenders? I feel like getting the correct height/location seems the most difficult part
  18. Feb 1, 2025 at 1:25 PM
    906taco
    Cory
    08 Taco
    Many ways to slice it. But building off of an engine cage is best.
    SoonToBeOn39s[QUOTED] likes this.
  19. Feb 1, 2025 at 1:27 PM
    SoonToBeOn39s
    Is that 1" tubing you use to branch off the cage?
  20. Feb 1, 2025 at 1:28 PM
    906taco
    Cory
    08 Taco
    All 1x.063
