Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Feb 10, 2025 at 7:07 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Swap one of the "bad" coils with one of the two good coils. If the code follows the coil to the cylinder that didn't previously have a code, then it proves that the coil/s are in fact, bad. In which case, replace them with OEM. If the code does not follow the coil to the new cylinder, then you need to start tracing wires until you find the issue.
  2. Feb 10, 2025 at 7:19 AM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Thanks you
    colinb17[QUOTED] likes this.
  3. Feb 10, 2025 at 8:22 AM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Coming up on the first maintenance for my Camburg UCAs. I know I need to loosen the crossbolt before greasing. Should I be using Red N Tacky or something else to re-grease the bushings? And the UCA crossbolt torque spec is 100#, even if double-sheared?
  4. Feb 10, 2025 at 8:53 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Super lube PTFE.
    Need to be careful with poly bushings as the wrong grease will eat the bushings.
  5. Feb 10, 2025 at 9:05 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Most common mistake I see people make is greasing up poly bushings with a grease that has molybdenum in it. That will certainly eat them
  6. Feb 10, 2025 at 3:43 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  7. Feb 10, 2025 at 4:09 PM
    MI-FLoffroader
    MI-FLoffroader Brett
    Brett
    Merritt Island, FL
    12' T4R LE/2003 SR5 SPORT V8/1988 DLX 22RE AUTO
    2012 T4R LE -Shoreline Blue Pearl 2003 T4R SR5 Sport V8 -Stratosphere Mica
    My Son bought a Solo mid travel kit for his Tundra, and iirc the bushings that ship with the kit are not of very good quality, so I suggested we install some Delrin. They have been good on my DK kit with the prothane grease that they recommend. I use Super Lube on the rear poly bushings, and Triflow on the uniballs and heims.
  8. Feb 10, 2025 at 7:49 PM
    JTFisherman
    JTFisherman Well-Known Member
    Jake
    Texas / Missouri
    4Runner
    Wish this conversation happened a couple months ago before I put cv-2 on a brand new set of bushings lmao
    colinb17 likes this.
  9. Feb 11, 2025 at 2:23 AM
    906taco
    Cory
    08 Taco
    This talk has surfaced several times in here lol
    JasonT87 likes this.
  10. Feb 11, 2025 at 9:46 AM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I'm using the Sweet Mfg hub. It's pretty nice, but it's also weld on. My only gripe with it is that it can go on any direction, so you could put the steering wheel on off-center. However it's a quick way to "fix" your alignment haha.
    That's crazy, when I had JD sua and H70HD I had an RTT, fridge, and all my camping gear in the back and it dropped less than two inches. Had to be around 500lb. Still had at least 7" up travel. However when I loaded it with a pallet from work, it was sitting on the bumps big time haha. My friend now has my old front/rear suspension on his truck and runs his tools, rtt, spare and whatever else in the back of his with no trouble. Doesn't run the RTT in the whoops though.
  11. Feb 11, 2025 at 9:50 AM
    906taco
    Cory
    08 Taco
    That’s the product of their geometry that I don’t feel inclined to debate again. All I know is this rear has never felt so good. It’s going to be on another truck that is currently JD rear so we shall see what the verdict is.
    But my 300cu/ft tank definitely squats it out good.
  12. Feb 11, 2025 at 10:04 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    You saw all the crap that I carried when we were in Moab..still had plenty Bump Travel to go.
    Finally getting around to rebuild the First Diff that let go in Moab..this is the one that started to have the noise after we did Kane Creek, not the one that blew up on Metal Masher or whatever that trail was called..
  13. Feb 11, 2025 at 10:04 AM
    WormSquirts
    Braeden
    BC
    I'm curious about the performance difference. We shot my friends trucks in the whoops last week with the JD +2.25 and SUA and spent a week and a half ripping it around ocotillo and johnson valley. Works really well. We never spent any time tuning the shocks yet either just cuz we were busy with different video projects.
    https://www.instagram.com/reel/DF0qVLnywDE/?igsh=MzRlODBiNWFlZA==
    MonkeyProof likes this.
  14. Feb 11, 2025 at 10:08 AM
    MonkeyProof
    SoCal- SGV
    Ian and I plan on going down to Ocotillo after when we finaly get my front end dialed. Will be cool for Ian to now have something to compare with
  15. Feb 11, 2025 at 10:11 AM
    WormSquirts
    Braeden
    BC
    I don't think Ian ever actually rode in Ollies truck. Should have made that happen!
  16. Feb 11, 2025 at 10:43 AM
    906taco
    Cory
    08 Taco
    A ride in my truck sold them on it. So we shall see what they have to say on their own. Their truck also has excessive wrap which is the main reason for parting ways. But the ride quality and handling is also undoubtedly better.
    WormSquirts[QUOTED] likes this.
  17. Feb 12, 2025 at 10:54 AM
    SoCaltaco65
    Hopefully Ian will have my truck soon for a deep dive tuning session after my new rear end and new rear shocks install.
    MonkeyProof[QUOTED] likes this.
  18. Feb 12, 2025 at 11:03 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    After a couple days driving with the new power steering pump I can say it makes a hell of a difference in how easy the truck handles, and the install was worth it - but it was a pain in the ass.
    Might need to make a thread/post addressing the shortcomings from their instructions using photos from @Airdog and @airkewled
    JasonT87, MonkeyProof and Airdog like this.
  19. Feb 12, 2025 at 11:10 AM
    MonkeyProof
    SoCal- SGV
    That would be rad!! The pump is quickly moving on up to the short list of things that is getting done
    SoCaltaco65 likes this.
  20. Feb 12, 2025 at 11:23 AM
    SoCaltaco65
    Same, hopefully 74 Welds Tacoma rack solution will be available.....:bananadead:
    Impoy47, Naveronski and TWTaco like this.
