Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jan 26, 2012 at 9:57 AM
    BMiller421
    BMiller421 FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    LT, Kings, Fabricated Trucks Worldwide For The Win, K&N and Doug Thorley LT Headers
    Hi lift on a tv?
    Winning!!
  2. Jan 26, 2012 at 9:59 AM
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    :eek:lol
  3. Jan 26, 2012 at 10:14 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Man that looks sketchy! WAY too long for the narrow attachment points. I could see that UCA easily twisting the coil bucket from the amount of leverage it has.
    Personally, I'd like to see a third attachment/pivot point and additional tube forward of the coil bucket to add some triangulation to the setup.
  4. Jan 26, 2012 at 10:18 AM
    linked2002
    linked2002 Well-Known Member
    san diego
    02 tacoma, 3 linked, 6 over custom arms, cage
    links, custom 6 over arms, full 1.75 d.o.m. cage, 35 gallon cell, etc
    look close... it is set up with two plates on either side of the upper arm inner pivots... tons of plate sticking up with only one weld holding it to the frame... no bracing.. no gussets.... that thing would take one good hit and both those uppers are coming off.
  5. Jan 26, 2012 at 10:30 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Looks like its actually a TV stand/cabinet but still :eek:
  6. Jan 26, 2012 at 10:30 AM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Looks like it has 20'' of down travel and no uptravel=fail
  7. Jan 26, 2012 at 10:49 AM
    BMiller421
    BMiller421 FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    You may be correct..either way..
  8. Jan 26, 2012 at 10:53 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    I'm looking to do something to my rear end to avoid hitting my bump stops all day until i drop the dough for the rear LT. now the question is if i put the all pro expedition leafs with say a 5100 or 5150 is it going to be at least better than my stock rear end and not work against my front LT. or is anything better than stock...
  9. Jan 26, 2012 at 10:55 AM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
  10. Jan 26, 2012 at 10:55 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    just get a add a leaf since its not going to be in for very long
  11. Jan 26, 2012 at 10:55 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
  12. Jan 26, 2012 at 11:22 AM
    Cr250jumper
    The moon
    50 shades of tan©
    You will waste your money. No matter what you do the rear is not going to keep up with the front unless you drop some coin. Its not really worth it if you are going LT in the rear anytime soon
  13. Jan 26, 2012 at 11:26 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    i concur
  14. Jan 26, 2012 at 11:37 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
  15. Jan 26, 2012 at 11:42 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    even if my rear end bottoms out real easily? I'm not looking for it to keep up I'm looking for it to not bottom out as harsh. i understand its a waste but it looks like AAL and some shocks are 300 bucks.
  16. Jan 26, 2012 at 11:44 AM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Would a 2 gen run a 16 or 18 for the rear on a SUA with a flush bed cage to the bed ?
  17. Jan 26, 2012 at 11:47 AM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Most 2nd Gens run a 16" Shock angled toward the cab slightly:cool:
  18. Jan 26, 2012 at 11:50 AM
    jtlachac08
    jtlachac08 Well-Known Member
    Jeremy
    Phoenix, Az
    14's with stock location hangers SUA, with a low rise simple hoops with cross support
  19. Jan 26, 2012 at 11:51 AM
    97yota4wd
    Eric
    Mesa, AZ
    how much travel are you getting out of that?
  20. Jan 26, 2012 at 12:02 PM
    jtlachac08
    Jeremy
    Phoenix, Az
    Full droop to full bump against the frame rail, with no bumps and no shocks was just over 16". Lost about 1/2 inch with the 14's One could notch the frame to get more out of the leaf pack tho. This is comfortable for me.
