Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Dec 30, 2010 at 10:28 AM
    #1161
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Thanks. Ill call ICON cause their website doesnt show anything. And yeah I have been to SDHQ before. My only issue is when buying $3500 worth of stuff it is a lot of tax to pay if I buy local. If I buy from somewhere in cali that has free shipping and no tax would basically allow me to get bumps for free. I spoke with Scott at Camburg and it looks like buying direct is gonna be the cheapest. No shipping and no tax. The only shocks Camburg supplies are SAW and FOX though. I am basically ready to buy just ironing out all the details.
    So far from all the info I have came across it looks like Total Chaos uses the standard 2.5x8 shocks that collapse to 16". Camburg's kit requires the shock to collapse to 14 3/8" to get full compression out of the arms. Maybe cause Camburg is boxed arms and are a little thicker?? I'm not sure. But I have spoke to Sonny at Down South and emailed King and no luck on a 2.5x8 that collapses to 14 3/8". Camburg sells a shock with their kit that is that "special" size but only FOX or SAW. Am I missing something or looks like I have to go with SAW or FOX????
    Edit: Just spoke to Marco at Down South and King will make a shock for the Camburg kit. It "utilizes an "Overcap" style top cap to be able to achieve the correct travel". Awesome! Kings it is for me :)
  2. Dec 30, 2010 at 10:33 AM
    #1162
    Cr250jumper
    The moon
    50 shades of tan©
  3. Dec 30, 2010 at 10:43 AM
    #1163
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  4. Dec 30, 2010 at 10:44 AM
    #1164
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    bumps are amazing...and dangerous...it makes you want to go REALLY fast lmao!!! I had a little too much fun
  5. Dec 30, 2010 at 10:45 AM
    #1165
    mjp2
    NJ
    I remember the difference on my mid-travel setup once I had the jounce shocks mounted. Stupid-easy to go way too fast! :devil:
  6. Dec 30, 2010 at 10:54 AM
    #1166
    blackhawke88
    SGV, CA
    07 TRD Offroad
    they are dangerous because they make you think you can go faster than you can
  7. Dec 30, 2010 at 11:10 AM
    #1167
    Cr250jumper
    The moon
    50 shades of tan©
    I'm all freaked out from reading earlier posts that people are going to steal my stuff when I get it. Could you weld the nuts on those bump stop mounts once you have them where you want?
  8. Dec 30, 2010 at 11:17 AM
    #1168
    Cr250jumper
    The moon
    50 shades of tan©
    I think I am going to go with Camburg. I like the bump stops and that the lower inners are uni-balls. I really want Kings though but from my post above I dont think I can find the right length to go with the Camburg LT. Scott at Camburg gave me a smoking price on the kit with shocks (SAW or FOX) shipped to AZ. But I want to try and find Kings before I pull the trigger
  9. Dec 30, 2010 at 12:57 PM
    #1169
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    You could use a 10" shock if you wanted. Just have to cut your shock tower and run a shock hoop. You'll end up running one anyway for the bypass, and it's stronger too.
  10. Dec 30, 2010 at 1:10 PM
    #1170
    Cr250jumper
    The moon
    50 shades of tan©
    Very true. Didn't think of that. That way when I do get a by-pass I just bolt it in. Def something to think about
  11. Dec 30, 2010 at 1:26 PM
    #1171
    Cr250jumper
    The moon
    50 shades of tan©
    X2. Im only just at purchasing front. My rear is a long way off lol
  12. Dec 30, 2010 at 1:33 PM
    #1172
    mjp2
    NJ
    Depends on your setup. If you wanted to you could spend that much on shocks alone, not including fabrication of the mounts.
    You can pick up the Giant kit for $1300.
    http://giantmotorsports.com/index.php?option=com_content&task=view&id=40&Itemid=50
    If you can weld, you can save a chunk of change on the installation. You'll still need shocks, upper shock hoops, lower shock mounts, fiberglass bedsides, etc.
    A lot of labor goes into the rear conversion, which is why you see so many folks not doing the rear until they almost eat it in the desert.
  13. Dec 30, 2010 at 1:35 PM
    #1173
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Hey Guys,
    Looking into LT for the Spring for my truck,
    my dilemma is that I don't really want a SUA rear since the terrain I drive on would probably just eat it the bottom of the springs and what not.
    I've just got my AP 3" Expo leafs for the rear and I'm wondering if I'd be alright with like a Camburg LT kit up front or would the rear just be all over the place when I hit bumps?
    Also, Does anyone know if the AP Fiberglass Fenders (mini) would work with a Camburg kit or only with AP Kit?
    Thanks,
  14. Dec 30, 2010 at 2:28 PM
    #1174
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Pretty sure nobody on this board is rich, but we do have good credit, lol. You could do rear LT for under a grand easy. Find some 3" lift Chevy springs from a junkyard (new they are pretty cheap too), fab up your own mounts, and cruise the RDC classifieds for used shocks and you are good to go.
  15. Dec 30, 2010 at 2:43 PM
    #1175
    Cr250jumper
    The moon
    50 shades of tan©
    Just spoke to Marco at Downsouth Motorsports and King will make a shock for the Camburg kit. It "utilizes an "Overcap" style top cap to be able to achieve the correct travel". Awesome! Kings it is for me :)
    Edit to make the link show correctly
  16. Dec 30, 2010 at 2:46 PM
    #1176
    Cr250jumper
    The moon
    50 shades of tan©
    Damn you blew my cover lol. I should be getting about $3600 for my taxes but I'm getting antsy and just might charge it and pay it off when I get my tax returns
  17. Dec 30, 2010 at 4:46 PM
    #1177
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    yeah, those are nice but i need to be able to still use the back seats for my nieces and nephews when i'm babysitting. the reclining seats will basically be the same as the stock seats only way more comfy
    buy as much shit as you can used of RDC and DR. doing that saved me some money. also dont forget to box the rear of the frame when you do SUA the rear susp
  18. Dec 30, 2010 at 5:47 PM
    #1178
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Downsouth Motorsports can make anything work. Well King can make anything that the customer wants:D
  19. Dec 30, 2010 at 6:31 PM
    #1179
    Cr250jumper
    The moon
    50 shades of tan©
    Yeah thats what I heard. They were the first I contacted but his first email said he didn't have them. He emailed me today though and said he called King and they said if I want it they will build it :)
  20. Dec 30, 2010 at 7:41 PM
    #1180
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    3" shock would be overkill for a DD/ weekend prerunner. no need for that, bypasses are nice buy plenty of people out there run smooth bodies cause bypasses are alot of $$$.
    it is such a night and day difference between my old mid travel set up to my rear LT it's not even funny. i'm running 2.5 triple bypasses w/ 2.0 4" air bumps... it's nice:D
