Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 7, 2012 at 8:57 AM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Now time to decide how I wanna do the bed cage..
  2. Mar 7, 2012 at 8:57 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    originally i had F55 then most recently F67 and now i have 50T
  3. Mar 7, 2012 at 8:59 AM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    What length shocks? and what size?
  4. Mar 7, 2012 at 9:02 AM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    yeah but your truck weighs alot more then matts acces cab 1st gen
  5. Mar 7, 2012 at 9:02 AM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    What did you think about the F67's?
  6. Mar 7, 2012 at 9:04 AM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    You think 550 would be too soft cause of the weight?
  7. Mar 7, 2012 at 9:04 AM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Not sure yet, gunna get the truck into the shop and try a couple different things.
  8. Mar 7, 2012 at 9:06 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    they were good, but i need something with a lot more arch to them. hence the 50T
    you won't want the 67's for your truck, especially if your going to run lift spindles up front
  9. Mar 7, 2012 at 9:07 AM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    im not sure but im just saying if they are perfect for nelsons truck i would assume they are to soft for your truck
  10. Mar 7, 2012 at 9:07 AM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    so whatchyu thinkin? a 50t?
    And why wouldnt i want the 67?
  11. Mar 7, 2012 at 9:08 AM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    i would think the 50t would be good for you rj unless your going to have alot of weight in the rear
  12. Mar 7, 2012 at 9:10 AM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    I think it would be fine..
    But what does everyone else think? Will the 550 be able to handle the weight?
  13. Mar 7, 2012 at 9:10 AM
    dirty dangler
    dirty dangler GFO DMC LBR
    adam
    simi valley,ca
    86 4runner bone stock
    wiper blades and a new battery
    damn it rj...call jeff and tell him exactly what you want..he will get your ride height perfect
  14. Mar 7, 2012 at 9:11 AM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    haha alright, alright.
  15. Mar 7, 2012 at 9:12 AM
    dirty dangler
    adam
    simi valley,ca
    does the race kit run 8's 10's or 12's
  16. Mar 7, 2012 at 9:13 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    generally speaking, the F67 pack was designed for 1st gens and old pick ups running the shackle over the frame. 2nd gens have an inverted shackle.
    go with either one of the many kits out there: giant, defined, DMZ or get some 50T and run the shackle above the frame or offset or get a custom pack... which would prob be your best option
  17. Mar 7, 2012 at 9:17 AM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Im not getting the race kit anymore.. But im contemplating doing the 12's.. Going to do an engine cage either way.. But wont i have to get new coil buckets if i do the 12?
  18. Mar 7, 2012 at 9:19 AM
    dirty dangler
    adam
    simi valley,ca
    cut that pos bucket off..have an engine cage built that you can run 12's and a bump off the upper...eliminate a tacoma weak point and have the ability to run a dual rate spring
  19. Mar 7, 2012 at 9:27 AM
    Supermoto
    Landon
    Fallbrook
    x1000
    If you are running a race spindle bump off the upper
  20. Mar 7, 2012 at 9:30 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    do you guys prefer to bump off a strike plate on the upper control arm or bump off a plate on the upper uniball itself?
