Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 18, 2012 at 2:13 PM
    Anteupp
    Anteupp Mega Member
    most shims are proprietary also, fox wont interchange with king,SAW, Bilstein and vice versa.... but on the other hand FOA shims will work on king 2.5 shocks and SAW 3.0.
  2. Mar 18, 2012 at 3:24 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  3. Mar 18, 2012 at 3:30 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    GOD DAAAAMN! that was sick
  4. Mar 18, 2012 at 3:35 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    appreciate it :cheers:
  5. Mar 18, 2012 at 6:31 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    SAW 3.0 Shims work on King 2.5.
  6. Mar 18, 2012 at 7:03 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Didn't know that, so the SAW's wall-thickness of their 3.0's must be huge or Kings is thin (which I don't see being the case):notsure:
  7. Mar 18, 2012 at 7:30 PM
    Anteupp
    Anteupp Mega Member
    wall thickness of the shocks body isnt affecting the shims in any way your thinking of the shocks piston? SAW's 3.0 series, King's, and FOA's shims all have the same ID. SAW 3.0 series, king, and FOA shims have an ID of .625
  8. Mar 18, 2012 at 7:33 PM
    theduck911
    Max
    Locked and Geared!
    DOH! :facepalm:
  9. Mar 18, 2012 at 7:33 PM
    Anteupp
    Anteupp Mega Member
  10. Mar 18, 2012 at 8:01 PM
    noSKills858
    Alex
    Poway, CA
    Now that we're getting into pro rebuilds; who runs custom shim stacks on their bump stops..? :D
  11. Mar 18, 2012 at 8:21 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    anyone had DSM valve their shocks? buying from them because they seem to have the best prices. we all know they have good service, but you never hear reviews on their custom valving ability. i'm sure they'll ask for shock mounting angle, spring pack and weight of the rear of the truck kind of stuff. i've just never heard how well their custom valving comes out without being there for them to see or ride in the truck.
  12. Mar 18, 2012 at 8:24 PM
    noSKills858
    Alex
    Poway, CA
    You're going to have to find someone to ride in your truck and do the valving on site, that's all it boils down to.
  13. Mar 18, 2012 at 8:26 PM
    Anteupp
    Anteupp Mega Member
    they sponsor and re valved/tuned my buddies race truck, their TOP NOTCH and know their shit.
    By custom valving what exactly do u mean/want?
  14. Mar 18, 2012 at 8:27 PM
    Anteupp
    Anteupp Mega Member
    x2!
  15. Mar 18, 2012 at 8:33 PM
    amaes
    amaes [OP] Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    The better question is what is the rate for them to go out and tune with you? I'm guessing in the neighborhood of $100+ an hour?
  16. Mar 18, 2012 at 8:37 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i have a boatload of extra weight in the back of my truck when i wheel because most trip last multiple days. some even a week, so i have to cary a lot of water, evtra food, medical supplies, spare parts, recovery gear, welder, and the list goes on. i'd assume when i tell them it's for an 07 tacoma double cab, they have an idea of what that means valving wise, but with all of the extra weight, the calving will have to be adjusted acordingly.
    i'm east coast, so i'll have to have them do their best via information over the phone, and then revalve them myself once they arrive if they are too far off for the bypass adjustments to compensate for.
  17. Mar 18, 2012 at 8:43 PM
    noSKills858
    Alex
    Poway, CA
    Colin, it sounds like you're not going fast enough for what (performance) shocks are made for. Most people don't realize that shocks work well when they're at a hot temperature. Depending on what you're doing you need to put this into consideration.. The hotter the shocks the thinner the fluid. So if you're moving at a slow pace then you may want to order a smaller shim stack to allow the thicker fluid to run through them.
    I can go on for a while but just to clarify these things, it's good to make sure you know some of the minor things.
  18. Mar 18, 2012 at 8:46 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    45-65mph when we aren't doing the technical stuff. i'd go faster, but that's when the rear starts bucking 2-3 feet in the air. no bueno.
  19. Mar 18, 2012 at 8:51 PM
    noSKills858
    Alex
    Poway, CA
    So at those speeds are the shocks working hard (whoops) or just little bumps?
  20. Mar 18, 2012 at 8:51 PM
    Anteupp
    Anteupp Mega Member
    with all that weight in the bed id be more worried about the springs than the valving of the shock. valving is just dealing with movement of the shaft ie: postion of the piston inside the shock body(specificly for bypass shocks) and the speed of the shaft. dont get me wrong valving will help in the bumps at speed but you need to be able to support all that extra weight first. F55's, F67's and that allpro 50t pack arent gunna cut it all these spring under leaf packs are super flexyy. Get a custom leaf pack like this guy did.
