Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 30, 2012 at 9:35 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    whats a good price for used 2.5x16 tripples? king or fox
    tia
  2. Mar 30, 2012 at 9:45 PM
    bluetaco80
    bluetaco80 Well-Known Member
    Rob
    fullerton ca
    06 prerunner dc sb longtravel
    Full engage longtravel front and rear
    800 to a 1000
  3. Mar 31, 2012 at 12:48 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
  4. Mar 31, 2012 at 7:02 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
  5. Mar 31, 2012 at 8:07 AM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    What is going on here? If you plan to reuse the balljoint remove the castle nut flip it over thread it back on part way to protect the threads. The hit the nut/ balljoint with a bfh. If you don't plan to save the balljoint use a pickle fork. You can reuse the balljoint with a pickle fork but you are pretty much guarantee to rip the boot. Reason I don't like to use the fork unless I really have to or in replacing the balljoint
  6. Mar 31, 2012 at 9:10 AM
    Trifenix
    so cal
    99 LT 5 lug Taco
    ^ I hate replacing ball joints! And tis true what he says, use a nut to hit the bj out from the bottom.
  7. Mar 31, 2012 at 1:46 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  8. Mar 31, 2012 at 2:05 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
  9. Mar 31, 2012 at 4:31 PM
    lembowski
    Rolando, CA
    Jeeper Creeper
  10. Mar 31, 2012 at 7:06 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  11. Mar 31, 2012 at 7:08 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    oh the memories
  12. Mar 31, 2012 at 10:36 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Motor mount breakers.. Geez what a horrible lip to hit.
  13. Apr 1, 2012 at 8:22 AM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Was thinking the same thing, guess Bob decide it was time:notsure:
  14. Apr 1, 2012 at 8:32 AM
    Tacorunner87
    Chino Hills Ca
    To much to list!
    Sponsored link?
  15. Apr 1, 2012 at 8:33 AM
    theduck911
    Max
    Locked and Geared!
    You must be a on phone or Tapatalk?!
  16. Apr 1, 2012 at 8:56 AM
    08pretaco
    az
    Burg kit on a 05+, can someone please tell me the placement of the lower control arm mounting misalignment spacers? there are 2 different sized ones
    tia
  17. Apr 1, 2012 at 9:06 AM
    Littlebro 5
    Littlebro 5 Well-Known Member
    Tyler
    Wilsonville or
    01 4x4 3.4L sr5 manual all-pro lift
    6" deck plate mod, sweet bed bar.
  18. Apr 1, 2012 at 9:09 AM
    Tacorunner87
    Chino Hills Ca
    To much to list!
    Tapatalk
  19. Apr 1, 2012 at 9:21 AM
    Piratefish
    Piratefish Well-Known Member
    Sebastopol
    2011 Tacoma Off Road
    Sadly None
    Defined Eng kit should be here this week !!!
    Its a start
    Talked to Joey at infamous metal works about the bed saver kit...Looks good!
  20. Apr 1, 2012 at 9:54 AM
    theduck911
    Max
    Locked and Geared!
    When you take off the stock LCA the 2 bolts are different sizes, I'm pretty sure the larger of the two is the front bolt and rear bolt is the smaller bolt, trying to remember from when I did mine
