Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. May 21, 2012 at 8:05 PM
    Sunner
    Sunner Well-Known Member
    Thank you sir. Quick question for you, do you still activate your 4x4 from time to time? Is it safe to do so with the setup you have? I ask because I read elsewhere that it is recommended to do so just to keep your front diff opperating correctly.
    Almost. Just almost did for a second there. :D
  2. May 21, 2012 at 8:13 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    It's not gonna hurt anything. I blew one of my CV's and pulled the axle out and kept both the inner/outer cv cups in place and finished the day off (some of which was in 4 low...actually 2 low at that point). The recommendation on putting it in 4wd is just to keep all the moving parts lubed up and moving.
    Honestly, my suggestion would be to save your money or collect your parts and do it all at once. Impatience causes more problems than it solves. That...and why bother pulling the truck apart again just to install the axles.
  3. May 21, 2012 at 8:16 PM
    Sunner
    Thanks man. Still on the fence, we'll see if I do it or not.
  4. May 21, 2012 at 8:16 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    this stuff did wonders on all my bushings
  5. May 21, 2012 at 8:18 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    my bushings werent noisy because I havent touched my UCA as far as greasing since install, just the heims/uniballs. Ill give that stuff a go and see if it requires less to keep it quiet lol
    It actually make me a little nervous thinking something was broken lol
  6. May 21, 2012 at 8:19 PM
    rcfreak201
    rcfreak201 Well-Known Member
    How do you wash it off? It gets super thick and doesn't even come off with the pressure washer.
  7. May 21, 2012 at 8:21 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    tri-flow >
  8. May 21, 2012 at 8:22 PM
    rondog
    Ronnie
    Escondido/San Diego
    I haven't needed to yet, dun dun dunnnnnn
  9. May 21, 2012 at 8:23 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    This stuff right?
  10. May 21, 2012 at 8:25 PM
    BMOC
    Paden
    Phoenix, AZ
    yes
    you can get it at any bike shop
  11. May 21, 2012 at 8:40 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Dont tell me what to do Paden.
  12. May 21, 2012 at 8:41 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Don't use lithium grease on your heims/uni's. Good way to destroy them.
    Dry lube only. Pick your poison, triflow, finishline, dupont. Doesn't really matter as long as its a wax dry lube.
  13. May 21, 2012 at 8:50 PM
    BMOC
    Paden
    Phoenix, AZ
    do it now.
  14. May 21, 2012 at 8:53 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    okay :pout:
  15. May 21, 2012 at 10:10 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    I used it on my old burg uca unis and it worked great. Got mine from wheelers.
  16. May 21, 2012 at 10:11 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    There is a bike shop down the street from my house, Prolly gunna walk over there tomorrow and stock up
  17. May 21, 2012 at 10:48 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    Race truck parts make race truck noises. This topic has come up so many times over the years. Overall consensus is deal with it ha. Most lubricants will only do harm by attracting dirt. Good uniballs and heims are self lubricating. If you don't like the noise you shouldn't be running them :) IMO Teflon dry lube is the only one that is ok
  18. May 21, 2012 at 11:32 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    What would you guys lube your shackle bolts with? I'm replacing the nuts with some locking ones to reduce the torque on the bushings.....the springs are used so the bushing where already lubed originally and thinking I should put some lube on the bolts? I have some synthetic grease I use for my uca bushings?
  19. May 22, 2012 at 12:00 AM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    you shouldn't need lube on the bolts, the inner sleeve is what pivots
  20. May 22, 2012 at 12:28 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Thanks man, that'll make it simple!
    Thought I was in the mid travel thread actually, lol!
