Long travel fenders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cl251, Aug 30, 2023.
  1. Aug 30, 2023 at 4:27 PM
    cl251
    cl251 [OP] Well-Known Member
    New jersey
    2010 Silver Tacoma TRD Sport
    3in Bilstein lift w ucas 17x9 Falcon Wheels and 35s Viper cut Stereo upgrade Lighting
    I have recently been looking into running a long travel kit. One thing I would like to avoid is running fiberglass fenders because I don’t really like the look of them or the idea of cutting apart the body. My question is whether or not I would be able to run a +2, +3.5, or even a +4 long travel kit without doing fiberglass fenders? For reference I don’t plan on jumping the truck or anything extreme and for most of the time probably not even using the full range of travel. Thanks for any info as I’m just getting into this type of thing
  2. Aug 30, 2023 at 4:33 PM
    mauctopa
    mauctopa Well-Known Member
    Two things to consider,
    First you will have to limit your bump travel as the wheel well arch will be roughly in the middle of your tire and won't be able to tuck in.
    Second depending on the kit if it has built in caster you'll rub when turning.
  3. Aug 31, 2023 at 10:51 AM
    cl251
    New jersey
    So I can run these kits if I limit travel? Also what would I rub on when I turn. I plan on having a different front bumper along with it?
  4. Aug 31, 2023 at 10:59 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Why not just keep it mid-travel and not have to worry about all the headache that comes along with LT?
  5. Aug 31, 2023 at 11:10 AM
    soggyBottom
    soggyBottom Well-Known Member
    I'm 1/2 way done with a +3.5 camburg install. I just measured it and if you were to use the stock bumps, 31" tires would hit the stock fenders. moved down the stock bump point by 1/2" you should be able to clear 32" tires and possibly 33".
  6. Aug 31, 2023 at 11:11 AM
    cl251
    New jersey
    Would you be able to send pictures?
  7. Sep 5, 2023 at 3:24 PM
    Taco_badger
    Taco_badger Member
    Ashton
    2023 black Tacoma SR
    Going back to real simple
    I was about to go LT suspension. Even had the fenders bought and ready to be vinyl wrapped. Then had a change of plans and am now going back to college so I need all the money I can get. I’m selling a set of fiberglass fenders if you end up choosing to go that route
  8. Sep 5, 2023 at 8:14 PM
    Watermallon
    Watermallon ID Tacooo
    Zach
    Idaho
    2006 TRD Sport
    Why spend all that money and time if you’re not going to do anything related to what the kit is intended for? Like someone else mentioned, get a solid MT set up and be done with it.
