Long travel for a beginner
Discussion in 'Long Travel Suspension' started by RYANBORN, Mar 22, 2014.
  1. Mar 22, 2014 at 12:54 PM
    RYANBORN
    RYANBORN [OP] Well-Known Member
    RYAN
    FERNIE BC CANADA
    14 TACOMA TRD OFFROAD
    I am looking for a little advice. I am buying Total Chaos 3.5 long travel kit. I am buying axles too from TC. Fox shocks too. When buying bypass shocks do I need to buy upper hoops? Besides buying fiberglass is there anything I'm missing for the front for my 14 Tacoma Access Cab 4x4?
  2. Mar 22, 2014 at 1:09 PM
    SoCalRoadie
    SoCalRoadie Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    Are you only going front LT? If so skip the bypasses for now. Save that money on the eventual rear LT.
    We have a few threads for new LTs and those thinking about LT. Make sure this is where you want to go. Some mods are permanent.
  3. Mar 22, 2014 at 1:28 PM
    RYANBORN
    RYAN
    FERNIE BC CANADA
    Thanks for quick response... i would like front and back... but was going to put Deaver springs in back until i spent the money on the LT rear. Right now just focused on buying that TC 3.5 LT kit with shocks. That plus axles and glass = $5000.00 Canadian...lol.
  4. Mar 22, 2014 at 1:55 PM
    SoCalRoadie
    Jim
    Burbank
    If you are already going LT then don't waste your time and money on a MT rear. If money is an issue you will get a more consistent performance with a MT front and a LT rear. LT is not cheap and you don't get the full effect unless you dive in. Half-effort this and you will be selling your truck in a few months.
    Think about what you are trying to achieve before dropping $5k on just your front end.
    $5k is a really solid full MT setup with cash to spare.
  5. Mar 22, 2014 at 3:24 PM
    RYANBORN
    RYAN
    FERNIE BC CANADA
    Thanks... i need more time to save I guess...
  6. Mar 22, 2014 at 3:40 PM
    TCprerunner
    TCprerunner Well-Known Member
    What are you planning to do with the truck? Honestly a good mid travel will do more then what a lot of people would be doing with there trucks
  7. Mar 22, 2014 at 4:31 PM
    SoCalRoadie
    Jim
    Burbank
    Also, think about how much you will realistically use the truck. I use mine 5-8 times a year if I'm lucky. The rest is DD street queen. I'm ok with that return on investment but would you be?
  8. Mar 22, 2014 at 5:06 PM
    RYANBORN
    RYAN
    FERNIE BC CANADA
    I live the Rocky Mountains on the Montana border. There is such diverse terrain around me... I like the idea of driving fast over the open rolling hills, logging roads... but also going on trail rides... I'm stuck on the long travel...its just so badass.
  9. Mar 22, 2014 at 5:11 PM
    TCprerunner
    Mid travel will do everything you just listed for less the 1/2 the price work and worry's
  10. Apr 7, 2014 at 7:24 PM
    Chadparker
    Chadparker Active Member
    Chad
    14 dcsb off road
    Everyone pushing MT here what is a good setup in your opinion?
  11. Apr 7, 2014 at 8:17 PM
    TCprerunner
    Icon extended travel with control arms up front remove sway bar and progressive aal or a full pack in the rear with whatever shock you want icon makes full kits where you can get everything check out down south motorsports
  12. Apr 19, 2014 at 10:01 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Boom. This is what Im running and it crushes rutted out bumpy fire roads. I dont think you need LT until you are jumping or running 45mph+ in the desert.
  13. Apr 19, 2014 at 10:08 PM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    What rear shocks would you guys recommend if doing a shackle flip in the back?
    And would that be considered MT or LT?
  14. Apr 19, 2014 at 10:15 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    op I feel like for what your gunna be doing a midtravel front and long travel rear would suit your needs nicely
  15. Apr 20, 2014 at 5:10 AM
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    This is what I currently am running till I have the funds for the front. Very capable but the front mt set is definitly the limiting factor. I'd recomend doing the rear LT first. So much nicer with LT rear vs my old mt setup. Felt like I was on the bumps all the time and really didn't flex that well. You might be able to get away with hoops in the rear and not do a full bed cage. Maybe look into the pelfreybilt rear setup? That would probably suit your needs pretty well. I just really like my DMZ rear set up as it's great with some speed (front is limiting factor here) and did really well crawling around a few rocks on the trail.
