Long Travel information.
Discussion in 'Long Travel Suspension' started by mjp2, Oct 13, 2009.
  1. Apr 15, 2013 at 3:23 PM
    #281
    esbyota
    esbyota Well-Known Member
    B-Rad
    AZ
    05 4x4 Taco
    Thats what I was looking for! Thanks for doing the leg work!
  2. Apr 15, 2013 at 9:38 PM
    #282
    csuviper
    csuviper Moderator Moderator
    Brian
    Broomfield, CO
    2012 Tundra Rock Warrior 5.7L 4x4
    3" Toytec Ultimate Lift, 315/70R17 Duratracs, RW Wheels, Grillcraft Grill, Toyota "Raptor" Lettering and more
    I was thinking it would work because all the db does is lower the lca and add a taller beefier spindle. Was just thinking of improving the travel for the trails vs going with an expensive conversion to solid axle. The added 3-4 inch height is not favorable for the COG. Guess its not the most practical.
  3. Jul 2, 2013 at 8:00 AM
    #283
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Except you lose ground clearance and throw your centre of gravity way up in the air.
    All it does is give you the option to run bigger tires. (Which I do realize will give you more ground clearance, but I'd rather have smaller tires and more GC than larger tires and the same GC.)
    However it's your money and your rig. If you like it, rock it.
  4. Aug 21, 2013 at 4:51 PM
    #284
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    so long travel on an '04 prerunner converted to 4wd w/ 255-85-16 tires will bite the front and rear fenders unless i trim them or swap to fiber werks. or can i get away with out having to trim anything?
  5. Aug 21, 2013 at 6:07 PM
    #285
    SargeSlapnuts
    Nick
    Pooler, Ga
    anyone wanna help?
  6. Sep 5, 2013 at 11:43 PM
    #286
    yumyumtaco
    yumyumtaco Well-Known Member
    Kevin
    SO-CAL
    96 preRunner, 2.4L
    Total Chaos Suspension RaceRunner Shocks w/ reservoirs Flared carbon fiber front pushed-out rear fenders
    Sooo... i hate to change direction... but im an "A$$" kinda guy...and i gotta question about DEAVER or ALL PRO rear springs? i have been doing a little research and the deaver setup is about 785$ and theALLPro is about 389$.... why such a big dif in price? and I am piloting a standared cab 96 taco that i am in process of making LT. does anyone have experience with the "3 leaf pack" from Deaver? or either of these 3 springs? i found pricing on the companies sites...http://www.deaverspring.com/products/leafstoy.html
    __________________
  7. Sep 5, 2013 at 11:49 PM
    #287
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    The deaver spring pack is a full LT pack, you have to make new mounts and new shackles and it pulls 16-18'' of travel
    The link you put for allpro doesn't work, but I'm assuming it's a bolt in pack=less travel
  8. Sep 5, 2013 at 11:50 PM
    #288
    kbauman92
    kbauman92 Well-Known Member
    Kyle
    North Bend
    98 tacoma ext cab
    King 2.5x6 RR coilovers eibach coils Light Racing UCA Spidertrax spacers Fiberwerx fenders
    if your going for LT you want a SUA (spring under axle) pack which would be the deavers, i dont think all pro makes a SUA leaf pack but i could be wrong
  9. Sep 6, 2013 at 12:16 AM
    #289
    yumyumtaco
    Kevin
    SO-CAL
    96 preRunner, 2.4L
    oh ok.. correction... and the all pro leaf pack shows "Long travel" thats why i was curious if anyone has used the all pro springs and what theyr take on them is? I dont plan of doing much HEAVY off roading... just enough to play around and go fast on them desert roads. lol and cant i convert the all pro to a SUA anyways?
    and ok as far as deavers are concerned.. so i will need to fab and weld in new shackles for them correct? both front mount and rear?
  10. Sep 6, 2013 at 12:30 AM
    #290
    TC yota
    Tyler
    Escondido
    Ha
    any LT leaf pack is going to need new front and rear mounts, and they will be SUA, I wouldn't waste my time with any pack that's not
  11. Sep 6, 2013 at 12:55 AM
    #291
    AK 08TACO
    AK 08TACO Well-Known Member
    Kyle
    Wasilla, AK
  12. Sep 6, 2013 at 4:13 PM
    #292
    yumyumtaco
    Kevin
    SO-CAL
    96 preRunner, 2.4L
    ok i see... so my ultimate goal is going to be 1) get LT springs and fab some mounts and go SUA. 2) THEN build a bedcage to house my 16" bypass shocks. and im assuming there is going to be a need for bump stops for the rear? anyone care to share their experience with bottoming out or rubbing with LT springs? i have Metal rear panels that were pushed out. maybe i need more room still? my build thread pics might show how far it is pushed out...
  13. Sep 6, 2013 at 4:15 PM
    #293
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    sounds like you have a looooooot of reading yet to do
    bumps and straps!
  14. Sep 6, 2013 at 5:02 PM
    #294
    yumyumtaco
    Kevin
    SO-CAL
    96 preRunner, 2.4L
    aint that the truth... so I want to hear about everyone's experience with the AP leafs... why dont you like them?:confused: I dont plan on jumping my truck anytime soon. just want to be able to handle the trails in the desert a little better.. lol
  15. Sep 28, 2013 at 8:29 AM
    #295
    Jyam180p
    Jyam180p Member
    Fort Bragg,CA
    '11 Taco 4X4
    All Pro LT kit, All Pro Expo leafs, u bolt flip kit, Fox 2.5's, Trail Ready bead locks, Owens tool box, Timbren bumps, Mc'Neil 3"x3" fenders,Relentless Fab bumper.
    Ok, so don"t shoot me down too quick but i've been trying to fiend a thread on here about uni balls on LT setups. I have a All Pro Lt kit on the way (just waiting on FOX to get the shocks together) And I was hoping to fiend out if anybody had any luck making dust caps for the uni balls? If so, some pics would be great! Like I said, I'm still waiting on the kit in the mail, so i haven't had a chance to see whats posable. I just would like to get started on putting something together so its ready for install day. Thanks!
  16. Nov 26, 2013 at 5:51 AM
    #296
    Apex
    Apex Member
    SoCal
    98 Tacoma SR5
    Whats going on guys. So I am currently on deployment and have been looking at the TC long travel kit. Im kinda new to this suspension business, or more spacifically, the high end suspension business. I have a few questions regarding the springs for the system. I am going to be getting the Fox 2.5x8" remote resi coil overs to run with the kit. My main question is on the springs to use. I know that I want the 600lb spring, but what I dont know is what length to use. I have found some folks that use a 16" spring and some that use a 14". Is a different length spring used for a bigger lift for the truck? I dont need the full 3.5" lift that this kit offers. Prob only 2" at that max. Just want to know the pros and cons for different lengths and what would be the best length spring for the setup.
    Also, I heard that you must have the 3.0" springs with the 2.5" coil over. Just want to confirm that.
    Another question is what springs are best to use with fox? I have heard a lot of great things about the fox/eibach set up. I was also contemplating getting the sway a way springs just because of the color (red). A bit rediculous, but thats what happens when your a grom like me.
    I hope that I was specific enough to get an accurate answer. Thanks a ton in advance. Registered just to ask these questions.
  17. Dec 24, 2013 at 2:23 AM
    #297
    J Prich
    J Prich Well-Known Member
    London, UK
    04 Prerunner
    I had the All Pro 50T pack on the truck that was my daily driver and became a race truck. Its a tall back in the rear but worked out ok for us as my truck has two spares in the back, 32 gallon fuel cell, and full cage. Truck worked fine and it ran 180 race miles with that pack without issue.
    We switched to a Deaver pack earlier this year and the advice I would pass to you is that the difference maker to me is product support. Especially as a So Cal guy Deaver is the best in the business. Their products are very high quality and you will have no problem getting support after the fact. If the pack doesn't sit the way you like, they can help you. If you break a leaf, they can repair it.
    Whether you are racing or playing, in my personal opinion Deaver is by far the best choice when it comes to leaf springs.
  18. Jan 27, 2014 at 1:03 PM
    #298
    desert guy
    desert guy Well-Known Member
    Bryan Blagg
    o.c.
    toyota offroad truck
    FiberWerx Tacoma front fiberglass clip, currie rear 9 inch, 35 Spline axles, sick nicks fab steering, Beard Seats, King Coilovers, Bypass, & Hydraulic Bumpstops, DEAVER Springs
    I totally agree with Jason. Deaver has helped me with racing springs for a while now. They have been around for a long time and know whats up. I loved the 50T pack but you don't have all-pro owner helping you out like Jeff does at Deaver.
  19. Sep 18, 2014 at 10:48 PM
    #299
    n.gardner
    n.gardner Spacer Hater
    Nick
    Hawaii
    '13 SR5 4x4
    OME 3" 887s + Dakars 1" 4 Crawler BL Pro-Comp Uniballs Nitrochargers + Super Bumps Diff Drop + Drive Shaft Drop
    So... why is the diff drop bad? does it not correct CV shaft angles?
  20. Sep 19, 2014 at 8:24 AM
    #300
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    It doesn't achieve anything worth while on 2nd gens. 1st gens is another story.
