Long Travel information.
Discussion in 'Long Travel Suspension' started by mjp2, Oct 13, 2009.
  1. Nov 26, 2013 at 5:51 AM
    #301
    Apex
    Apex Member
    SoCal
    98 Tacoma SR5
    Whats going on guys. So I am currently on deployment and have been looking at the TC long travel kit. Im kinda new to this suspension business, or more spacifically, the high end suspension business. I have a few questions regarding the springs for the system. I am going to be getting the Fox 2.5x8" remote resi coil overs to run with the kit. My main question is on the springs to use. I know that I want the 600lb spring, but what I dont know is what length to use. I have found some folks that use a 16" spring and some that use a 14". Is a different length spring used for a bigger lift for the truck? I dont need the full 3.5" lift that this kit offers. Prob only 2" at that max. Just want to know the pros and cons for different lengths and what would be the best length spring for the setup.
    Also, I heard that you must have the 3.0" springs with the 2.5" coil over. Just want to confirm that.
    Another question is what springs are best to use with fox? I have heard a lot of great things about the fox/eibach set up. I was also contemplating getting the sway a way springs just because of the color (red). A bit rediculous, but thats what happens when your a grom like me.
    I hope that I was specific enough to get an accurate answer. Thanks a ton in advance. Registered just to ask these questions.
  2. Dec 24, 2013 at 2:23 AM
    #302
    J Prich
    J Prich Well-Known Member
    London, UK
    04 Prerunner
    I had the All Pro 50T pack on the truck that was my daily driver and became a race truck. Its a tall back in the rear but worked out ok for us as my truck has two spares in the back, 32 gallon fuel cell, and full cage. Truck worked fine and it ran 180 race miles with that pack without issue.
    We switched to a Deaver pack earlier this year and the advice I would pass to you is that the difference maker to me is product support. Especially as a So Cal guy Deaver is the best in the business. Their products are very high quality and you will have no problem getting support after the fact. If the pack doesn't sit the way you like, they can help you. If you break a leaf, they can repair it.
    Whether you are racing or playing, in my personal opinion Deaver is by far the best choice when it comes to leaf springs.
  3. Jan 27, 2014 at 1:03 PM
    #303
    desert guy
    desert guy Well-Known Member
    Bryan Blagg
    o.c.
    toyota offroad truck
    FiberWerx Tacoma front fiberglass clip, currie rear 9 inch, 35 Spline axles, sick nicks fab steering, Beard Seats, King Coilovers, Bypass, & Hydraulic Bumpstops, DEAVER Springs
    I totally agree with Jason. Deaver has helped me with racing springs for a while now. They have been around for a long time and know whats up. I loved the 50T pack but you don't have all-pro owner helping you out like Jeff does at Deaver.
  4. Sep 18, 2014 at 10:48 PM
    #304
    n.gardner
    n.gardner Spacer Hater
    Nick
    Hawaii
    '13 SR5 4x4
    OME 3" 887s + Dakars 1" 4 Crawler BL Pro-Comp Uniballs Nitrochargers + Super Bumps Diff Drop + Drive Shaft Drop
    So... why is the diff drop bad? does it not correct CV shaft angles?
  5. Sep 19, 2014 at 8:24 AM
    #305
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    It doesn't achieve anything worth while on 2nd gens. 1st gens is another story.
  6. Nov 14, 2014 at 11:27 PM
    #306
    Lyle430
    Lyle430 Well-Known Member
    Montana
    2015 DCSB TRD Sport Tacoma
    All pro long travel with Fox DSC's, defined sua, Engage bed cage, glassworks fiberglass fenders, dtf front bumper, method wheels,
    Not sure if this is the right section to ask this. But I'm thinking about putting a long travel kit on my 15 tacoma dd. I was thinking of just doing the allpro kit but now thinking of just doing the camburg 3.5. I will be daily driving the truck so I'm not sure about the 3.5" kit. I travel on dirt roads to get to work and if the roads are rough I don't want to slow down. What are you guys thinking? I don't want to do a mt kit either.
  7. Nov 16, 2014 at 8:19 AM
    #307
    kyle7201
    kyle7201 Active Member
    kyle
    1998 Tacoma 3rz sr5 4x4
    Will camburgs 2wd drive race kit work on a 4wd 1999 tacoma
  8. Nov 16, 2014 at 12:26 PM
    #308
    kyle7201
    kyle
    Will camburgs 2wd race kit work on a 4wd 1999 tacoma
  9. Nov 16, 2014 at 1:23 PM
    #309
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2000 ext. cab 4x4
  10. Dec 6, 2014 at 10:20 PM
    #310
    surfermatt
    surfermatt Well-Known Member
    CA
    04 prerunner, ext cab
    Front long travel custom: king 10" CO, solid lowers, fabbed spindle, heimed everything ect. Rear still in progress, waiting to be put on: bilstein 9100s, T100 axle. Stock 3.4 engine, 4.30 gears.
    yes as 2wd
  11. Jan 12, 2015 at 7:54 AM
    #311
    Auzea
    Auzea Well-Known Member
    Florida
    2005 Prerunner Access Cab - V6
    Curious here,
    Do all of you boys out in Cali that run LT prefer 4x4 or 4x2?
  12. Mar 1, 2015 at 12:35 PM
    #312
    usptwins
    usptwins Well-Known Member
    Trey
    Louisiana
    Taco SR5 Stock stock stock
    Kyb shocks/struts, Nitto Terra Grappler G2's in 285/70R17.
    Anyone have the base prices for these kits?
  13. Mar 1, 2015 at 8:55 PM
    #313
    surfermatt
    CA
    Depends what you mean by trails but, yes.
    I'm sure the company your interested in has a website with that information listed.
  14. Mar 2, 2015 at 6:11 AM
    #314
    usptwins
    Trey
    Louisiana
    I went looking, but I may have to contact them in order to find that out. Was hoping to see a price listed on their site.
  15. Mar 24, 2015 at 5:38 PM
    #315
    NORTHVAN08
    NORTHVAN08 Member
    Jake
    Vancouver
    2008 Toyota Tacoma TRD sport (RED)
    18in Rims Leer canopy
    Hey can you run King 2.5 shocks on a Allpro LT kit? cuz I'm not the biggest fan of fox shocks.
  16. Jul 19, 2015 at 5:14 PM
    #316
    white+Peal
    white+Peal Well-Known Member
    Kris
    Henderson, NV
    08 prerunner
    Magaflow catback exhaust, AEM CAI, front bumper made by famous fabrication, JBA long tube headers, All pro back bumper, BPF raptor style grill, 3' toytech lift
    good stuff. :thumbsup:
  17. Sep 14, 2015 at 4:54 PM
    #317
    exilemoto367
    exilemoto367 New Member
    Dave
    2000 white Tacoma extended cab 4x4
    This maybe a silly question. Will a Lt suspension void the factory warranty? From what I understand BDS kits will not void a warranty. Thanks for letting me be a part of TW.
  18. Sep 14, 2015 at 5:11 PM
    #318
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    My understating is it will only void the warranty if they can prove that it directly affected the problem. If you put LT on and the motor blows, you should be good to go.
    Canks likes this.
  19. Sep 14, 2015 at 5:20 PM
    #319
    TC yota
    Tyler
    Escondido
    Ha
    Look up the Magnuson-Moss Warranty Act of 1975.
  20. Oct 8, 2015 at 12:42 AM
    #320
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    A Dealership has to prove that your aftermarket part caused an OEM part to fail. So if you put new suspension on, and your frame is tweaked, or body or something is off, most likely they'll rule that you romped your truck due to aftermarket suspension lol
    Also, subbed :anonymous:
