Long Travel information.
Discussion in 'Long Travel Suspension' started by mjp2, Oct 13, 2009.
  1. Jun 20, 2017 at 12:22 AM
    #361
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Some are, but it's recommended to bump off the spindle so you'll need fabricated spindles and an engine cage. Most guys run Wheeler's super bumps up front w/ or w/o a bypass. Otherwise you'll be hitting the bumps for too much of the articulation with hydro bumps off of the lca.
  2. Jun 20, 2017 at 8:32 AM
    #362
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Thanks for the reply. It seems like there is lots of room to locate hydros up further on the frame. So as not to be hitting them all the time. -is there another reason that I'm not aware of to not do that?
  3. Jun 20, 2017 at 8:54 AM
    #363
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    You would need to crank the pressure pretty high to get the hydro to stop prior to fully bottoming out. The better question is what do you hope to achieve by running hydro bumps that you can't get with a super bump? And what kind of terrain are you planning to use the truck the most in?
  4. Jun 21, 2017 at 6:49 PM
    #364
    Radarninja
    Northern California
    06 taco
    I'm desert running. I'm looking to soften those hard impacts and interested in the way hydros are "progressive". Just wanted to know what others have done and learn from them. I'd run bypasses if they weren't so expensive. Thanks again
    Dalandser likes this.
  5. Jun 21, 2017 at 7:53 PM
    #365
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Try valving your coilovers first?
  6. Jun 21, 2017 at 9:06 PM
    #366
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    I'm running hydro bumps off the spindle with amazing results but its a lot of work to do that. I have setup trucks with bumps off the lower many times its fine but not the best option of course . If your desert running fast and hitting big stuff. Then yeah go for it. Just try to mount them so they hit as far possible out on the arm , so they have a better motion ratio and don't strike often. Use a 2.0 x2"
  7. Jun 22, 2017 at 6:40 AM
    #367
    Radarninja
    Northern California
    06 taco
    Anthony can you post a pic of them off the spindle please? Just curious how that is. Also why 2.0 x 2?
    Remember I don't know shit
    But I was thinking bigger is better even if I had to run an internal spacer. Thanks for the reply sorry if my questions suck.
  8. Jun 22, 2017 at 8:24 AM
    #368
    DirtRev.
    DirtRev. Kick the tires and light the fires...
    Oregon
    95 4x4 LT Tacoma
    Blood, Sweat, and Beers
    The reason for the 2in is when bumping off the lower control arm to prevent riding the bump stop through out majority of suspension travel which inevitably kind of happens in that location regardless
  9. Jun 22, 2017 at 10:06 AM
    #369
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Even on the rear you only want to run 2.5" long stroke or 2" stroke because otherwise you ride on the bumps for too much of your travel and the other parts of your suspension that make your ride smooth won't be working for their maximum range and you'll be riding on your bumpstops instead. As far as diameter, 2.0" is pretty much the go to unless you're building a full size truck.
    Here's Anthony's setup. FYI he works for the company that built his front kit, LSK - they're down here in El Monte.
    https://www.tacomaworld.com/threads/anthonys-99-tacoma.175933/page-24#post-14118859
    Radarninja[QUOTED] likes this.
  10. Jun 22, 2017 at 10:37 AM
    #370
    Radarninja
    Northern California
    06 taco
    I saw the build, too nice! wanted to see How the bump hits the spindle. I couldn't figure it out from the pics. The engine cage is badass!
  11. Jun 22, 2017 at 10:44 AM
    #371
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Right on. It's similar to this:
  12. Jun 25, 2017 at 5:10 PM
    #372
    Anthony250
    Anthony
    Rialto CA
    I don't Know if I have a up close picture but its a small rectuangular pad off the top of the spindle uniball cup. But either way if you wanted this setup its major work, need to do a full engine cage and must have a fabricated spindle.
  13. Jul 3, 2017 at 3:26 PM
    #373
    Radarninja
    Northern California
    06 taco
    I got a good deal on a cumburg long travel for 06 taco. Do any of y'all know how glass fenders will look/ fit.
    http://www.roadrunnerfiberglass.net/tacoma-05-08.html
    I was looking at these, price is good. I just don't want them to be too big or small looking. What do you all think or have?
  14. Jul 3, 2017 at 4:31 PM
    #374
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The usual smallest size for long travel is 4" flare so 4.5" is barely bigger. Can't speak about the fitment. McNeil is usually recommended for fit, but I'm sure time and patience can make them fit well unless someone had some bad experience they mention.
    erok81 and Radarninja[QUOTED] like this.
  15. Jul 4, 2017 at 4:02 PM
    #375
    Radarninja
    Northern California
    06 taco
    I posted this before our pm conversation, I'll stay away. Thank you
    erok81[QUOTED] likes this.
  16. Jul 4, 2017 at 6:29 PM
    #376
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    McNeil is 21% off today - I'd buy if you can afford it!
    erok81 likes this.
  17. Jul 5, 2017 at 8:43 AM
    #377
    Radarninja
    Northern California
    06 taco
    I did buy yesterday on the fourth but I didn't see your post here. Not sure if I got discount I paid $350. Seems fair.
  18. Jul 5, 2017 at 4:03 PM
    #378
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    $350 is normal price. There was a discount code you needed to enter at checkout.
  19. Jul 5, 2017 at 4:07 PM
    #379
    Radarninja
    Northern California
    06 taco
    Nooooooo!
  20. Jul 6, 2017 at 10:01 AM
    #380
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Sactown
    Ford Raptor.
    Traded in Taco
