Long travel install guide?
Discussion in 'Long Travel Suspension' started by joey34mx, Oct 25, 2010.
  1. Oct 25, 2010 at 11:19 PM
    joey34mx
    joey34mx [OP] Well-Known Member
    2005 Tacoma V6 prerunner
    Is there anything you guys have seen that explains how to install an engage front LT kit with the spindle?
    im gonna take it on soon and some good directions would certainly help.
  2. Oct 26, 2010 at 6:26 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Its pretty much unbolt stock and reinstall Im sure. Here are directions for my Total Chaos kit to give you an idea. The instructions in the bottom left hand corner of the page in a PDF.
    http://www.chaosfab.com/86000.php
    Call Engage and Im sure they will help you out.
  3. Oct 26, 2010 at 7:31 PM
    joey34mx
    thanks for the info. is it much harder to install because of the new spindle?
  4. Oct 26, 2010 at 7:53 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    shouldn't be, should be easy since everything is uniball.
  5. Oct 26, 2010 at 8:19 PM
    joey34mx
    yeah the uniball upper and lower appears to be an easy pretty bolt on
    how difficult is it to remove stock spindle from hub and install the engage one?
  6. Oct 26, 2010 at 8:26 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    Just unbolt it. Dont forget to buy a new seal for your hub into the spindle. Thats the way my 4x4 hub/spindle is. Maybe a 2wd is different?
  7. Oct 26, 2010 at 8:31 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Its easy, unbolt, reinstall everything in place of the stock stuff.
    There is no seal between the hub and spindle. At least I don't remember there being one and we certainly didn't replace it
  8. Oct 26, 2010 at 8:39 PM
    joey34mx
    ok cool. any special tools to do the install? things you would not find in your average truck owners home garage?
  9. Oct 26, 2010 at 8:44 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Actually Im not positive but I think you would need a balljoint puller for removing the tierod.
  10. Oct 26, 2010 at 8:45 PM
    cummins6speed
    Or a pickle fork
  11. Oct 26, 2010 at 8:49 PM
    bajamoon
    STEVE
    Whittier
    Or a big fuckin hammer, no special tools that I remember. I did not install my kit but watched engage install the spindle and it toll about 45 min to switch them out.
  12. Oct 26, 2010 at 8:56 PM
    cummins6speed
    A big hammer will work but you have to be careful not to mushroom the stud and mess up the threads.
    I think it took me about half an hour (not including brake lines) to do the spindles and I think I used the hammer method, I just backed off the nut and beat on that till the ball joint popped out
  13. Oct 26, 2010 at 8:58 PM
    ktmrider
    Junk
    I tried the BFH method over the weekend and I couldnt get it.
  14. Oct 26, 2010 at 8:59 PM
    joey34mx
    ive heard you have to bleed the brakes when you do the install? true?
  15. Oct 26, 2010 at 9:00 PM
    ktmrider
    Junk
    if you remove the brakelines and get air in them you do. But not just bolting on stuff. Where are you located?
  16. Oct 26, 2010 at 9:01 PM
    joey34mx
    Down in so cal. Near ventura, simi valley and t.o.....i live in the city of moorpark.
  17. Oct 26, 2010 at 9:02 PM
    ktmrider
    Junk
    did you ever consider having a shop do the front and gusset it up while they are at it?
  18. Oct 26, 2010 at 9:10 PM
    cummins6speed
    You will when you install the extending brake lines
  19. Oct 26, 2010 at 9:11 PM
    joey34mx
    yeah but im just looking to do it on my own. i am interested in doing the bolt on part of the install
  20. Oct 26, 2010 at 9:17 PM
    bajamoon
    STEVE
    Whittier
    Like said above you will have to bleed brakes but that will be the easiest part. Hit up nelsonmatt and see if he can give you a hand, he is up in your neck of the woods.
