long travel kit
Discussion in 'All-Pro Off Road' started by woodbutcher, Jun 22, 2012.
  1. Jun 22, 2012 at 8:44 PM
    woodbutcher
    woodbutcher [OP] Well-Known Member
    san jacinto ca.
    02 prerunner sr5 trd
    k&n intake, aftermarket wheels 16"
    i live off of palm and 7th looking to put together a long travel kit i use my truck for work so needs to be somewhat comfortable. i drive the ortega hwy. to and from work and will frequently wander off the beaten path our jobsites are dirt and rocks so when it rains it turns to soup, and i love to hit the mud. i did a 3'' body lift in the front to get more clearance on my tires not enough don't want it to high because i still like to corner on paved roads. i fugured if i push the wheels out i can get what i need to have a ride that will function well anywhere not interested in climbing rocks. i want to haul ass through the mud and dirt. do you install also or just a vendor since your local i will give you first opportnity to meet my needs thanks i would appreciate any advice or info i have an 02 tacoma crew cab
  2. Jun 22, 2012 at 10:02 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  3. Jun 22, 2012 at 10:09 PM
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
    :rofl:
  4. Jun 22, 2012 at 10:11 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Ok.
    OP, were you trying to send them a private message or get opinions?
  5. Jun 23, 2012 at 12:07 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
  6. Jun 23, 2012 at 8:59 AM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    i want to see your truck if you did a body lift on only the front...so your cab sits 2-3 in higher then your bed ???
  7. Jun 23, 2012 at 9:17 AM
    woodbutcher
    san jacinto ca.
    my short term goal is to lift my truck pre-runner stance. long travel suspension. tube steel bumper front, and back. i have fiber glass fenders on the front gonna do the rear soon. i have 30'' bfg m/t km2 tires. purpose for my build i work construction some job sites require you to go off-road which is fine i see a lot of guys getting stuck all the time the rear locker kicks ass saved me countless times. i drive the ortega hwy to and from work it's paved and has tons of twists and turns, and if you drag ass through there you might aswell pull over. i also beat it up pretty hard and its not going to hold up forever. i figured i could gain more overall wheel travel widen the stance which could help in corners and give me more clearance in my turning radius so i can keep the lift to a minimum. im open to opinion.
  8. Jun 23, 2012 at 9:18 AM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    :worthless:
  9. Jun 23, 2012 at 9:23 AM
    Trigo
    Rodrigo
    San Diego
    1st gen
    :popcorn:...... Btw you do know how much LT goes for right?
  10. Jun 23, 2012 at 9:31 AM
    woodbutcher
    san jacinto ca.
  11. Jun 23, 2012 at 9:40 AM
    woodbutcher
    san jacinto ca.
    what do you mean
  12. Jun 23, 2012 at 9:48 AM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    ok so you mean a spacer lift not a body lift two totally different things. and long travel is no joke it will cost you upwards of 4-5 grand just for the front if done right and even more for the rear sence your a first gen. my suggestion to you would be a solid mid travel set up like im running so you would need new upper control arms i prefer total chaos then you should get new coils and get rid of the spacer that will make your truck ride 10x better then you can get wheel spacers which will help fill out your fiberglass fenders and give you the wider stance you want
  13. Jun 23, 2012 at 9:51 AM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    but i thought they dont really make a sua kit for the first gens like they do the second gens( defined, dmz) so it cost more to get all the parts separate and takes alot more fab work ?
  14. Jun 23, 2012 at 9:54 AM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
  15. Jun 23, 2012 at 9:55 AM
    Trigo
    Rodrigo
    San Diego
    1st gen
    Like Corey said above, just get a good mid travel kit and some spidertraxx
  16. Jun 23, 2012 at 9:56 AM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Their first gen kit isn't that bad. its the 2nd gen kit we aren't fond of per say
  17. Jun 23, 2012 at 10:00 AM
    Trigo
    Rodrigo
    San Diego
    1st gen
    Who are these"right people" you speak of? :evil:
  18. Jun 23, 2012 at 10:01 AM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    then he should go that route i really have no clue how much first gen LT kits runs for i have never looked into it, 2k just seemed really cheap compared to the TC 2nd gen im looking at lol
  19. Jun 23, 2012 at 10:09 AM
    woodbutcher
    san jacinto ca.
    if i knew what the hell i was doing i would probably be half way through it lots of valuable info. so what steps would you take first. i will build up to the lt i did read that the rear is important to do first for lt to keep the rear from coming around on you aswell as other problems. i got spacers i wasnt ready to commit to any given height just yet. if i go to high i will definately roll it. i tend to push it sometimes as it is. 3'' is okay but im rubbing on the inside when im hard over one way or the other 3'' more in the front may 2'' in rear what do you think i really dig the front being higher
  20. Jun 23, 2012 at 10:17 AM
    Trigo
    Rodrigo
    San Diego
    1st gen
