Long Travel on 3rd Gen Tacoma
Discussion in 'Long Travel Suspension' started by erok81, Jul 4, 2017.
  1. Jan 13, 2021 at 10:47 PM
    #41
    erok81
    erok81 [OP] Well-Known Member
    Imposter
    Thanks. They are 6” McNeil. I wish back then they would have had smaller. I don’t like the look of them.
  2. Jan 23, 2021 at 4:02 PM
    #42
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    BMiller421 likes this.
  3. Jan 25, 2021 at 11:33 PM
    #43
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  4. Feb 3, 2021 at 10:31 AM
    #44
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
  5. Feb 12, 2021 at 9:36 PM
    #45
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  6. Mar 1, 2021 at 8:29 PM
    #46
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Your snorkel is that coming out the top of the fender? If so I take it would not work with stock fenders.
    CocaineAndCreatine likes this.
  7. Mar 1, 2021 at 11:24 PM
    #47
    erok81
    Imposter
    Nope. it’s kind of tight. Using my method you’d probably be hard pressed to even fit it with a 3” fender.
    Well. Actually it might work. You won’t have a flat spot like I did so it will have to come out at a different angle than the fender. It’s been a while since I’ve seen the inside of a stock fender.
    01 dhrracer[QUOTED] likes this.
  8. Jun 2, 2021 at 6:08 PM
    #48
    KaizenOffroad
    KaizenOffroad Member
    Huntington Beach, CA
    2018 White Tacoma TRD OR
  9. Jul 3, 2021 at 10:13 AM
    #49
    dezrtdood760
    dezrtdood760 Active Member
    Palm Desert, CA
    2008 Tacoma 8P4 AC 6SPD w/85k miles
    Nice truck!
  10. Nov 28, 2021 at 8:53 PM
    #50
    Epic3rdgen
    Epic3rdgen Well-Known Member
    A-A-ron
    2016 ACab OR
    +2 TC LT Fabtech 6’’ bracket w/4link on 40’’ KM3-s Raceline Wheels
    Some nice trucks in this thread.. here is my long travel 82671F99-A451-4FC6-A469-DDB8351C63C0.jpg849BC7A3-FDAB-4CC4-AFDE-EA2239377FAF.jpg
  11. Dec 10, 2021 at 3:42 PM
    #51
    youngster77
    youngster77 Well-Known Member
    2017 TRD OFF-ROAD
    Saw your rig at Ryan's. Beastly! He's working on my black 3rd gen as we speak.
  12. Dec 10, 2021 at 3:54 PM
    #52
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    What wheels are those?
  13. Jan 10, 2022 at 8:31 PM
    #53
    Epic3rdgen
    A-A-ron
    2016 ACab OR
    Your truck is bad ass. That rear end is massive. 10’’ 40 spline ? Wow ,do you have a build page?
  14. Jan 11, 2022 at 3:45 PM
    #54
    youngster77
    2017 TRD OFF-ROAD
    Thanks man! The rear is a 9" full floater with a Gearworks 10" 3rd. 40 spline HT axles. If you're on IG you can peep the build @thatblackyota
    Epic3rdgen[QUOTED] likes this.
  15. Jan 11, 2022 at 9:34 PM
    #55
    Epic3rdgen
    A-A-ron
    2016 ACab OR
    What computer thing are you going to use to mimic the wheel sensor?
  16. Jan 11, 2022 at 10:54 PM
    #56
    youngster77
    2017 TRD OFF-ROAD
    That's a work in progress...
  17. Feb 13, 2022 at 1:41 PM
    #57
    TacoJohn12
    TacoJohn12 Well-Known Member
    Jonathan
    Escondido, CA
    '16 Tacoma - JD Fabrication Long Travel Build
    4" LT, LCA Pivot Kit, SUA, Howe Steering Pump, Switch Pros, Baja Designs lights everywhere, Fabricated Inner Fenders, Custom bumpers, bedcage Fox shocks: 2.5x8 COs, 2.5x8 bypasses, 3.0x16 bypasses, 2.0x2 bumps on all corners... & more
    The rear setup on this is beautiful! Just wondering what's the reasoning behind the fabtech lift on the front end??
    DocME and Key-Rei like this.
  18. Feb 14, 2022 at 9:52 PM
    #58
    Suicyco
    Suicyco Well-Known Member
    14 ac 4x4
    I was wondering the same thing. I thought they were raceline avengers at first but i think they may be pro comp beadlocks
  19. Feb 14, 2022 at 9:55 PM
    #59
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    :ohsnap:
    That Ivan inspired livery is just perfect.
  20. Feb 19, 2022 at 12:18 PM
    #60
    Epic3rdgen
    A-A-ron
    2016 ACab OR
    That is so the 40 tires will clear real easy. Also to get the frame up out of the rocks. I have a ton of ground clearance. And they sponsored the truck so it was free parts. I broke 2 stock full weld gusset spindles .. and boom no more problems with broken spindles using the beefy Fabtech spindle. Lots of reasons I did it…
