Long travel OR SAS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ShadowT, Sep 25, 2011.
  1. Sep 25, 2011 at 1:45 PM
    ShadowT
    ShadowT [OP] New Member
    Shadow
    East Texas
    08 tacoma 4x4,Cocked locked and ready to rock
    3'' front springs, custom bumper, billet grill, adda leaf rear, 3'' body, cat back exhaust, 1000 watt amp pushin 1 12'', K&N Filter, Spooled Rear axle, 33'' mud grapplers, 17'' moto metal 909 wheels
    I am soon goin to make some major changes to my 08 single cab. i have old man emu springs and a 3'' body lift, and i moved the cab mount immediately behind the front tire up 3'', which allows me to fit up to 35'' tires. Im running 33's now, but i want to run 36's. So i need more lift, but dont want my axles in a bind... a long travel suspension would help that some right? But will the IFS be strong enough to handle 36's?
    OR will i be better off with a SAS to a dana 44?
    thnx for any help
  2. Sep 25, 2011 at 1:47 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Easy, do you want to rock crawl, or dessert-run?
  3. Sep 25, 2011 at 1:56 PM
    ShadowT
    Shadow
    East Texas
    I live in east texas we dont have much rock, mostly mud and hills to climb. I would prefer the ground clearance of the long tavel but am concerned about the stength ot the front diff.
  4. Sep 25, 2011 at 1:57 PM
    KPT
    09 Prerunner
    So you don't go up to Barnwell much then?
    I can't imagine where you could really need long travel around here other than some lease roads.
  5. Sep 25, 2011 at 1:58 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
  6. Sep 25, 2011 at 2:27 PM
    RockRescue
    RockRescue Well-Known Member
    Oregon
    2007 TRD Sport
    SAS and use a diamond axle with 30 spline longfeilds
  7. Sep 25, 2011 at 2:40 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    lets see this body mount. :popcorn:
  8. Sep 25, 2011 at 2:46 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x2
  9. Sep 26, 2011 at 8:09 AM
    Kayak Taco
    Kayak Taco Member
    Auburn , AL
    11 4x4 DCLB TRD Sport
    I have no experience on the strength of the Toyota front Diff for 36s if you go long travel. I did however run 36" TSLs on my former rig on a Ford High Pinion Dana 44. Without Chromoly shafts, I broke (or stretched) the U-joint Ears off of the stock Dana 44 Shafts on just about every run. If you go SAS with 36s, plan on an extra $1000 or so for Chromoly shafts. Or go on up to a D60 or some sort of Hybrid Axle...
  10. Sep 26, 2011 at 8:19 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    how much money you want to spend, and as said above rock crawling or fast desert running?
