Long Travel Steering help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trevair1497, Aug 12, 2017.
  1. Aug 12, 2017 at 8:26 AM
    Trevair1497
    Trevair1497 [OP] New Member
    Trevor
    1450 race truck 1st gen tacoma
    ls1 th400 swap, 9" rear end full spool 4 linked long travel full cage etc etc race legal SCORE or BITD truck
    Any one have any good ideas about upgrading their steering in a 1st gen truck? I blow through racks a lot. well mainly the Clevis bolts and end up messing up the end of the rack. Have a fully build 1450 truck LS1 swap linked cage the whole 9 stock steering is the last item.
    Any ideas out there or anyone already solved this issue? rear mounted rack limits my options
  2. Aug 12, 2017 at 11:00 AM
    doyouquaxu
    doyouquaxu Well-Known Member
    put a Howe rack in with a custom bump steer bracket. Nobody builds a kit or a solution for these trucks so it will have to be 100% custom.
  3. Aug 12, 2017 at 1:00 PM
    Trevair1497
    Trevor
    That's what im leaning towards. Its getting the u joints from the wheel to the center of the rack that's the issue. Max out the joints to make such a tight angle.
  4. Aug 12, 2017 at 5:46 PM
    doyouquaxu
    Stole these from another forum, have zero info about it other than the owner posted them and said it works great. Appears to be fully hydraulic.
    COMAtized99, chrslefty and ThunderOne like this.
  5. Jun 17, 2020 at 11:11 AM
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    2017 Barcelona Red Tacoma TRD Pro
    Where did you steal these from? I would like to see more.
  6. Jun 17, 2020 at 11:18 AM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    Its a brace that slides left to right to reduce flex. There was a post in LT bs thread a couple weeks ago. TNT Fab I think is the company mentioned. There a couple guys on here that have ones similar but they are custom
  7. Jun 17, 2020 at 11:20 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
  8. Jun 17, 2020 at 11:21 AM
    BikerinBlak909
    SoCal
    96 LT 5 lug
  9. Jun 17, 2020 at 11:52 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Hit up Solo Motorsports. They work on a lot of Tacomas and they'll give you some ideas.
