long travel suspension kits
Discussion in 'Long Travel Suspension' started by tacoma #12, May 10, 2009.
  1. May 10, 2009 at 5:25 PM
    tacoma #12
    tacoma #12 [OP] Member
    I was wondering about long travel suspension kits, I am liking total chaos and all pro, but i dont really race in the desert or anything, i just liked them because they had a lot of travel. How are they in the rocks and mud or are they just for the desert? How do they compare to the regular kits like pro comp and fabtech? My granfather has some land and i just go over there in the mud and rocks.
    And if i did get the long travel then what do i have to do to the rear to make them match?? thanks for help!!
  2. May 10, 2009 at 5:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Long travle works fine in the rocks and mud. Much better than a drop bracket lift, ar you have more clearance under the truck.
  3. May 10, 2009 at 6:09 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Heres a video of the all pro LT kit, it made for all types of terrains, as for doing the rear people do deavers or alcan leaf packs and some rear shocks with resi's until you can cage the rear but not nessasary to do.
  4. May 10, 2009 at 6:33 PM
    tacoma #12
    OK thanks, what about towing and hauling stuff? will it be to soft in the rear?
  5. May 10, 2009 at 10:48 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    amount of money you will drop on LT, if not using it in desert conditions, it might be a waste of money...
    figure $3,000 to $5,000 on front end, then another $2,000 on the rear end...
    you could just do a replacement leaf pack in the rear, but that rear wont keep up with the front end.... im finding that out the hard way right now on my truck...
  6. May 10, 2009 at 10:52 PM
    allupinsydeyou
    allupinsydeyou Well-Known Member
    so cal / vegas
    v8 swapped yota. dyno tuned @ 400hp
    modified total chaos uppers and lowers... king coilovers, deaver leafs, full cage, 351w motor swap, etc..
    pro comp and fagtech kits suck balls.... look into bms, chaos, or camburg. best kits for your money. or have one custom done. either way... what are your needs for having alot of travel? you do realize less well dampened travel is better than more shitty dampened travel right? not everything is about high numbers.
  7. May 11, 2009 at 6:09 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    stupid question...is the long travel just for 2wd or do they make a kit for 4wd?
  8. May 11, 2009 at 6:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2!
  9. May 11, 2009 at 6:26 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    both. but normaly you can get more travel out of 2wd
  10. May 11, 2009 at 8:49 AM
    tacoma #12
    what else could i use besides lt that mabe isnt so expensive? but i still want as much travel as possible. i was thinking about sas but it is way to expensive, any suggestions?
  11. May 11, 2009 at 9:22 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    sas would be for hardcore rock climbing.
    If you want a nice front end set up start with total chaos upper control arms.
    http://www.wheelersoffroad.com/05uptacotc.htm
    then add some nice coilovers. if you want the best expect to pay for it.
    Fox makes really nice reservoir coilovers. check them out at allpro
    http://allprooffroad.com/05tacomafrontsuspension/294
    I just ordered the 2.0 set.
    some other companies are King, walker evans, camburg, and Icon.
    For the rear you will want to replace your factory springs with some longer one
    i.e. Deaver or alcan. wheelers offroad also offers a 3 leaf AAl pack that replaces your factory overload leaf and provides better flex.
    Im not an expert or anything but thats a start for you.
    also check out this thread
    http://www.tacomaworld.com/forum/builds/17641-mjp2s-build.html
  12. May 11, 2009 at 9:23 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    also it would help if we knew what year your truck is and is it 2wd or 4wd?
  13. May 11, 2009 at 9:24 AM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    Why not just get something like mid travel fox, king, camburg, icons coilovers in the front with some aftermarket uca's and get some rear resi's with a better leaf pack your ride will be alot better thats my plan for the rear. Definately not as much but works, no matter what you do its gonna cost you.
  14. May 11, 2009 at 11:28 AM
    allupinsydeyou
    so cal / vegas
    cuz he wants that dank ass gnar travel man...
    seriously though... you need to listen.... i have lt front and rear on my truck... front is pulling almost 17 inches... and i was dusted by a guy that only had 12 inches of super clean travel. that showed me that i needed to tune my coilovers a bit better... so i did... and damn. you dont need a shitload of travel unless you are seriously gunna be seeing more dirt then you do street. and im seriously doubting that is your case. so save some coin and just get the bolt on coilovers and some upper control arms and call it a day. socalman22 did that and the ride quality changed night and day. was amazing.
  15. May 11, 2009 at 1:55 PM
    tacoma #12
    My bad, my truck is a 2005 tacoma with TRD and 4x4. I just wanted something reliable with a good bit more travel than stock, i am not gonna be doing alot of desert racing, but the idea with some upper control arms and coilovers sounds nice, does that widen the truck at all? cause with the whole kit from TC i know it widens the truck a little. But then if i get the upper control arms am i gonna have to put a hole through the bed and do a bunch of stuff? i would still like to use the bed cause it will haul around my dirtbikes and things like that
  16. May 11, 2009 at 2:19 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    The uppercontrol arms will have nothing to do with doing the bed, it wont widen your truck if you get uca's and some coilovers you will get some travel but do not expect alot of travel.
  17. May 11, 2009 at 3:45 PM
    tacoma #12
    sorry. i meant that if i do the front like that then will i have to do the rear to cause it will be out of whack, how much travel would i get with the upper arms and coilovers?
  18. May 11, 2009 at 4:01 PM
    tacoma #12
    since LT is so expensive and i am not gonna be desert racing just a weekend warrior every once and a while, would pro comp be a good lift that i can tow with and haul things in the back, but still be able to do some pretty serious stuff? i do plan to try and do the rubicon some day with this truck.
  19. May 11, 2009 at 4:05 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    With just the coilovers i gained Wheel Travel: 1.75" maybe a little more with uca's
  20. May 11, 2009 at 4:23 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    question: Since a nice less expensive setup is uca's + coilovers ( what you guys are saying ) how will my total chaos uca's and 885's with OME shocks hold up? Are there any disadvantages to desert stuff when it comes to not having coilovers?
