Long Travel Taco Build MRK 2
Discussion in 'Long Travel Suspension' started by IFS4LIFE, Jan 4, 2015.
  1. Jan 14, 2015 at 5:40 AM
    Mad T
    Mad T Well-Known Member
    Thomas
    Georgia
    :popcorn: This is worse then seeing a trailer to a movie and having to wait for it to come out! I can't wait to see this all done.
  2. Jan 14, 2015 at 9:47 PM
    IFS4LIFE
    IFS4LIFE [OP] Well-Known Member
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    More welding on the trailing arms
    After the cover plates
    Shock towers completely welded and bolted on to the frame
    Not a bad night for a fire either
  3. Jan 17, 2015 at 9:54 PM
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    There's definately some bailing wire and duck tape action going on, but it is mobile and it drives straight and nothing fell off or broke on it's maiden voyage.
    There is still a lot of work to be done, but from here on out it's all small stuff and as soon as I clean up the fuel lines, the brake lines, and some wiring under the hood I can start wheeling again.
  4. Jan 19, 2015 at 8:06 PM
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    Adjustable bump can mounts mocked up tonight. The truck is sitting about 3" below right height so the pads will be further from the axle tube when it's sitting level.
    Pirhett likes this.
  5. Jan 20, 2015 at 6:01 PM
    FD15COLLI
    FD15COLLI Active Member
    Andover, CT
    Subbed, when i get my '16 I'll have to hit you up for some advice, hopefully be similar dimensions...
  6. Jan 20, 2015 at 7:02 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    I'm digging that adjustable bumpstop mount.
  7. Jan 20, 2015 at 10:24 PM
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    Got the sliders and bumper bolted back on tonight. None too much room to spare, but enough.
    It's headed to ADS tomorrow to have some spring and shock work done and I'll get the reservoir cans mounted. First wheeling trip is planned for Saturday morning. Won't have the bed on by then most likely but I don't need it to wheel.
  8. Jan 21, 2015 at 9:30 PM
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    So I took the night off and sent ol' girl off to the guys at ADS to have their way with her.
    Replaced the springs with 300/250/100 tenders, adjusted the valving, re-routed the resi hoses and added some billet clamps to put the resi bodies where they belonged in the first placed. Also fixed my ghetto rigged fuel line so now it's semi-safe to drive. So far she rides like a dream. Can't wait to hit the dirt in a few days.
    Pirhett likes this.
  9. Jan 22, 2015 at 10:37 AM
    TacoBran
    TacoBran You're Unique, Just Like Everyone Else
    Brandon
    Peoria, AZ
    2023 Double Cab Trail Edition; 03 Double Cab 4x4 TRD SOLD
    2023 Bone stock... 2003 - Icon coilovers, TC UCA, icon shocks w/resi's, deaver leafs - 4x4 swap in progress
    Wow looking great! We should duplicate this on a double cab :D
  10. Jan 22, 2015 at 11:08 AM
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    Do those have a carrier bearing?
  11. Jan 22, 2015 at 11:20 AM
    JerryTaco
    JerryTaco Well-Known Member
    Wow, nice fab work!!
  12. Jan 22, 2015 at 11:42 AM
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    Thanks.
    Tonight I'll mount the bump pads and lower limit strap tabs and figure out how I wan to to make the upper strap mounts adjustable. I'm probably going to re-design these trailing arms for future runs as there was way too much welding involved and they could be much more easily fabbed. I'm going to put a manual proportioning valve up front for the rear brakes and then drive and test and tune for a bit while I fab up a new rear axle housing using the Toyota 3rd member. Should be a bolt in job with this system, if I do my part correctly and design it well.
  13. Jan 23, 2015 at 3:42 PM
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    Passed emissions this morning and put it up on the ramp. It has more travel left in it, but I have to trim the bumper side pieces before they eat the tire I learned. I'd never planned for this much travel when I built that 5 years ago.
    Pirhett likes this.
  14. Jan 24, 2015 at 10:41 AM
    edgerat
    edgerat Well-Known Member
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    Hahahaha, that is so ridiculous! Love it! Can't wait to see some trail pics!
  15. Jan 25, 2015 at 6:52 PM
    #35
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    Took it easy on day 1 this weekend just to get a feel for things. I adjusted the bump height last night and the pressure before heading out again today. A few photos from the trip.
    885542_1580859915459501_8347606734575832_200bfe9c41660f6d5062d5f840ec2bff426e7941.jpg
    I laid into it pretty good today to really test the strength and durability of the arms. No dents, but a few good scratches and I bumped them pretty good on a couple climbs. Broke both front CV's but no other failures.
    I've achieved my goals. Drove 90 to and from the trail with 1 hand on the wheel and it drives really nice in the dirt. I might change of the crossmember design just a bit for revision 2 but nothing major.
  16. Jan 25, 2015 at 7:06 PM
    #36
    302
    302 I love Taylor Swift :D
    Lawrence
    302
    07' DCSB TRD Sport SSM
    Bedside decal
  17. Jan 25, 2015 at 7:46 PM
    #37
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    My other baby. Built that one from the ground up.
    1932751_10103289541629102_16738878453497_8664a2a9f1a9cd82996217d98f2a86ae2ef6d872.jpg
    Powertrain is era made performance upgrades only so it makes between 23-25hp for now. I have a few other things planned but they'll be era made parts as well. The sheetmetal is all me because I didn't have anything to start with. 1923 Model T Speedster. Run a couple races a year in it and tour in it about once a month. The rest of the time it's my grocery getter and yes I have to start it with the hand crank up front. lol. It'll run about 62 mph on flat ground, but that's cooking on a tire that's only about 4" wide and a spindle that about 1" in diameter.
    not_nick and Guerrilla like this.
  18. Jan 27, 2015 at 6:23 PM
    #38
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    SUBD!
    why are you trying to make everything bolt on?
  19. Jan 27, 2015 at 6:33 PM
    #39
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Sub'd. Awesome build!
  20. Jan 27, 2015 at 9:24 PM
    #40
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    Because 90 percent of the average builders don't know how to weld, or own a welder, or shouldn't be welding when it comes to life, limb, and property and because nobody else has done it. If it can be bolted on, it can be welded on should you choose, but not the other way around.
    not_nick likes this.
