Long Travel Taco
Discussion in '2nd Gen. Builds (2005-2015)' started by sytfu510, Sep 8, 2011.
  1. Aug 8, 2012 at 8:02 PM
    #201
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Da fuq is going on in here?
    If the springs are already negative arch with the existing shackles, longer shackles are just going to require even longer bumps or even more premature spring wear due to overtravel. If you want to run a longer shackle you'll need longer springs with more arch to accompany it. And while you're at it....don't forget about pinion angle.
  2. Aug 9, 2012 at 8:28 AM
    #202
    sytfu510
    sytfu510 [OP] Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    lol all I know is I may still need longer bumps. FYI OEM hangers are back on. AND the DE brace is on order.
  3. Aug 9, 2012 at 8:40 AM
    #203
    Manwithoutaplan
    ID
    how do you like the ato flip kit??? is it worth it??? I am getting my Swing bumper this WEek :D
  4. Aug 9, 2012 at 8:43 AM
    #204
    sytfu510
    Alex
    Bay Area
    Oh I don't have it, jandrews does. Congrats on the bumper, can't wait to see it, only thing I've found that kinda sucks is when you park, you have to hope someone doesn't pull up close behind you or else you can't open the tailgate lol.
  5. Aug 9, 2012 at 8:44 AM
    #205
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Riding better now?
    What valving did you end up going with on the shocks?
    He had the fab junkie flip. OEM is back on.
  6. Aug 9, 2012 at 8:45 AM
    #206
    Manwithoutaplan
    ID
    ohh my bad :S
  7. Aug 9, 2012 at 8:46 AM
    #207
    Manwithoutaplan
    ID
    I could see that. Is your bumper powder coated?? I am going to get mine rhino lined.
  8. Aug 9, 2012 at 8:53 AM
    #208
    sytfu510
    Alex
    Bay Area
    The ride is about the same or a slight bit rougher, since there are speed bumps where I live, I've been gauging the ride by running through them. But I need to go drive up a ramp again and see what happens at flex. The valving was setup from DSM after answering a few questions, according to the tag they are 12/8 valving.
    Negative, mine is sprayed with spray on bed liner. Easy touch ups. [​IMG]
  9. Aug 9, 2012 at 8:57 AM
    #209
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Perfect! I was expecting .012 on compression since you're second gen and the weight you normally carry. .008 on rebound has been proven over and over for leafs. Double check all your spring bolts that they are not over torqued and preventing the shocks from rebounding like they should. You want them around 50-60 lbs so they can still move free. May seem a little light, but just load up on red loctite.
  10. Aug 9, 2012 at 9:02 AM
    #210
    Manwithoutaplan
    ID
    have you had to touch it up yet??
  11. Aug 9, 2012 at 9:17 AM
    #211
    sytfu510
    Alex
    Bay Area
    Cool, I actually have the All Pro Lock Nuts on all of the bolts so I'm not too worried about them backing out, I'll be sure to check the TQ today,thanks.
    Yeah, last trip to slick rock, I got on the throttle hard and it kicked up hella rocks, but a couple seconds with the spray can and good as new.
  12. Aug 9, 2012 at 2:21 PM
    #212
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Do you just leave it on and mask off the rest? Or take it off?
  13. Aug 9, 2012 at 4:53 PM
    #213
    sytfu510
    Alex
    Bay Area
    I just leave it on and mask over stuff.
  14. Aug 13, 2012 at 1:32 PM
    #214
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Where is your back-up camera mounted? What kind is it?
  15. Aug 13, 2012 at 6:03 PM
    #215
    sytfu510
    Alex
    Bay Area
    It's mounted in-between my rear bumper and tailgate. It came with my OttoNav Radio.
  16. Aug 14, 2012 at 9:24 PM
    #216
    sytfu510
    Alex
    Bay Area
    Still need to dial in everything..but:
    :spy:
  17. Aug 15, 2012 at 3:43 PM
    #217
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    wow I've never even seen a bumpstop like that before! :eek:
  18. Aug 17, 2012 at 9:27 PM
    #218
    sytfu510
    Alex
    Bay Area
    Defined Engineering Brace. Installed. No pics yet.
    Just the pre install:
  19. Aug 17, 2012 at 9:28 PM
    #219
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
  20. Aug 18, 2012 at 1:44 PM
    #220
    sytfu510
    Alex
    Bay Area
    Installed:
